Going bigger
dgeesaman
Posted 2007-08-07 11:44 AM (#65320)
Subject: Going bigger
Hello everyone.  I'm looking at a towing rig larger than our current 95 F-150 / 2 horse slant, and I have several basic but important questions.  As is sometimes the case, my googling efforts have found everything *but* the answers I'm looking for.
My wife would like to move up to a living quarters trailer, probably a 3h slant load and quarters on small side.  Maybe even 2h.
1) What do these bad boys weigh, practically speaking, with cargo what's a reasonable number?
For the truck, I'm actually considering using it as a daily driver since we're also planning to move and shorten my commute.  I can tolerate that if it gets above 15mpg and isn't dually width.  So I did some digging and have my eye on a single rear wheel 3/4 or 1 ton 4x4 with diesel and automatic.
2) Does driving a diesel less than 10mi each way on a daily basis cause problems?  If so, what maintenance might solve that issue?
3) Is this enough truck to pull a living qtrs like I described?  We're in the east, so I don't anticipate big mountain passes, but it's not Kansas either.  Is the wheelbase on a crewcab shortbed enough?  I'd like 3.73 final for the daily driving but will it tow like a pig?  Does this kind of rig get unstable without a dually rear?
4) Is there any practical difference between a Ford F-350 SRW and F-250?
Thanks for any responses.
Dave
Edited by dgeesaman 2007-08-07 11:45 AM
Posted 2007-08-07 12:39 PM (#65323 - in reply to #65320)
Subject: RE: Going bigger
Simple .. NO ... unless you count a few hundred pounds of name plate a practical difference
Edited by hosspuller 2007-08-07 12:40 PM
mingiz
Reg. Jul 2004
Posted 2007-08-07 12:53 PM (#65326 - in reply to #65320)
I have a 06 F250SD EXT cab SB with 6.0. I tow a exiss 2 h slant with LQ no problems I did though have to get a hitch extender for the trailer which wasn't too much and works great. I drive 12 miles each way each day and I have had no problems with the truck.
Rich M.
Posted 2007-08-07 4:02 PM (#65341 - in reply to #65320)
I tow with a regular cab F350 SRW. Difference is likely only in the springs from a 250. My DoubleD 2 horse straight load mid tack 6' LQ weighs about 6000# dry. This trailer is 18.5' on the floor. I have no problems towing, it's stable and comes in under GCWR and GVWR. Unloaded my 7.3 diesel gets about 20 mpg and low teens towing.Other than keeping it plugged in in the winter ( you'll freeze before you get to work with a short commute) you should be fine. Ps, shameless plug my trailer is for sale, advertised on this site.Rich
farmbabe
Posted 2007-08-07 6:07 PM (#65351 - in reply to #65320)
1000500100100
My trailer is a 3 H with small LQ and midtack.I have a Ford 250.I should think you would have enough truck for the trailer your thinking about.  I also get low teens when pulling and not much better on the road. I don't know of any problems with short runs on a diesel but you could probably ask on a diesel forum.
Maximizer
Reg. May 2007
Posted 2007-08-07 7:27 PM (#65362 - in reply to #65320)
I have a 06 Chevy Duramax and pull a 4 horse with a 4 foot shortwall with the lq's finished..  Its a 2500HD crew cab..  I don't have any problems.. It has a 3.73 rear-end and it doesn't tow like a dog..  It will get up and run..  Plus I am getting 20 mpg not pulling and I can get 15 - 16 mpg pulling the trailer if I keep it around 60 mph..   60 may seem slow but with the price of fuel i'm going to go slower..  Good Luck!!!
Posted 2007-08-08 6:25 AM (#65382 - in reply to #65320)
I pull a 4 Horse with a 8' LQ with a 2006 F350 SRW. The trailer has a 26 foot box.
The trailer loaded with 4 horses and gear weighs 16,000lbs and maxes out my GCVW. Any heavier and I need to buy a Dually.
Depending on the trailer you buy, Aluminum vs Steel, How much the LQ conversion weighs, I'd expect your 3 horse LQ to weigh 12,000 to 14,000 loaded.
Truck pulls trailer great. I did add an exhaust brake to healp slow it on the mountain roads I drive here in UT.
My previous 3H weekender trailer weighed in at 12,000 - 13,000 lbs had a 24 foot box. Same truck pulled it fine.
The main difference between a F250 and F350 is the nameplate and "D" rated vs "E" rated tires.
I am a building contractor, I run from project to project to lumber yard to plumbing store etc. I do nothing but short stop and go driving. I am on my 3rd F350 with a Powerstroke engine. I put around 90,000 miles on each truck then sell them. I've had no problems with short trips. I get around 14 mpg daily chasing and can get around 18-19 mpg if I get on the hiway and for a longer trip. I've run both the normal diesel fuel and a lot of B-50 bio diesel in the summer months.  Also consider UPS and other delivery services. They run diesel engines and do nothing for short drives. Start stop all day long.
The Ford SRW pickups ONLY come in a 3.73 rear end with the diesel engine.  No choice here.
Dwight
Posted 2007-08-08 7:46 AM (#65384 - in reply to #65320)
We have a 1997 F-250 Powerstroke diesel, 4WD, crew cab that now has nearly 200,000 miles on it.  It has single rear wheels.  We pull a steel 3H GN with a mini LQ (3' SW).  We recently took a trip to the mountains of eastern KY and it pulled like a dream.  As a matter of fact, we had to wait on our friends at the top of each hill.  They were pulling a similar trailer with a newer GMC one ton gas.
Yeah, our truck is 10 years old and it has a lot of miles.  But it's PAID FOR and it still runs like a scalded dog.  We do a lot of hauling with it and I also drive it to work about three days a week.
I think the key to the longevity of any vehicle is proper and regular maintanence.  We regularly change the oil, fuel filter and air filter and don't run the fuel tanks all the way to empty.  Other than when our son dropped it off into a ditch and broke a tie rod, we've had no major repairs.
RIDE ON!
hav2ride
Posted 2007-08-08 7:54 AM (#65386 - in reply to #65382)
1000500100100
It's really impossible to say how much a 3H LQ would weigh without taking the trailer brand and the LQ brand and size into consideration. My 3H, mid tack, LQ wieghs about 16,000 loaded up with 2 horses and everything else. I've had someone else pull it with a 350 dually amd it sank to the axles and literally shook foing up my hilly driveway. It pulls fine with my 4500 because it is geared down and has the weight and brake size to carry and stop it. But I don't think I would ever tow a larger LQ without a dually, for safety that is.
rose
Posted 2007-08-08 9:29 AM (#65395 - in reply to #65320)
10005001002525
Have a Merhow 3 horse alum over steel 8 foot short wall lq with slide out, usually only have 2 horses in it;  third stall used for storage of all my junk that I can't live without;  pull it easily with a Dodge 2500 4x4 diesel regular cab long bed.
Rich M.
Posted 2007-08-08 10:42 AM (#65404 - in reply to #65320)
Same as Rose, just got 3 horse Merhow, 8' LQ w/slide. Shipped weight was 5749' (before LQ added) I forget someone had a rough # for added weight per foot of LQ. 22' but the added length over my straight load is behind the axles. " Feels" about the same as the straight load towing. Mine is an Equilite, steel frame,aluminum skin &roof ( no longer made, basically an optioned up Equistar). Hav2 you must have a pretty long long wall ?.Rich
laxpatrick
Posted 2007-08-08 10:45 AM (#65406 - in reply to #65320)
As noted above, if you get a short box pickup, you'll likely need either a tapered nose trailer or the hitch extender.
I drive a Dodge diesel and get 20 or so unloaded, 12-15 towing our 4H LQ trailer.  I'm right at the max for my truck based upon the trailer's gross weight tag (50 lbs. to spare, actually).
To do it over, I'd have gone for the long box - if you're not sure about whether or not to go long, take one out for a drive, do some Wal-Mart type parking lots and park each one.
LAXPatrick
Spooler
Reg. Aug 2006
Posted 2007-08-08 11:18 AM (#65413 - in reply to #65404)
50025
Originally written by Rich M. on 2007-08-08 2:42 PM
It's 300lbs per foot of LQ. So if you have a 8 ft. LQ then it is 300x8=2400 lbs for just the living quarter addition.
rockyrider
Reg. Jun 2004
Posted 2007-08-08 11:31 AM (#65414 - in reply to #65323)
100100100
Here are the numbers. Main diff is payload.
WEIGHTS (pounds)
GVWR's available
10,000-11,500(F-350 SRW), -13,000 (F-350 DRW) 16,000 (F-450), 17,950, 19,000 (F-550)
Max. GCWR's available
23,000 (F350 SRW), 23500 (F-350 DRW), 30,000 (F-450), 33,000 (F-550)
Max towing capacity, properly equipped
15700 (F-350 SRW), 16,000 (F-350 DRW), 21600 (F-450), 24,600 (F-550)
All Dimensions are in inches unless otherwise noted.
BASE CURB WEIGHT
<style type=text/css>
F250/350/450 Super Duty Pickup Weight and Towing
Cab
Regular Cab
SuperCab
Crew Cab
Cargo Box
8ft
6.75ft
8ft
6.75ft
8ft
Drive
4x2
4x4
4x2
4x4
4x2
4x4
4x2
4x4
4x2
4x4
Base curb weight
F250 SRW
5675
6135
5925
6385
6050
6510
6100
6560
6225
6685
F350 SRW
5813
6273
6063
6523
6188
6648
6238
6698
6363
6823
F350 DRW
6125
6585
6500
6960
6685
7145
6810
7270
F450 DRW
8290
8687
Max payload capacity 1
F250 SRW
3130
2860
3070
2810
3150
2880
3100
2830
3170
2910
F350 SRW
4220
4220
4040
4070
4210
4140
4160
4090
4230
4170
F350 DRW
5670
5410
5690
5430
5640
5380
5720
5250
F450 DRW
6120
5720
Max GVWR
F250 SRW
9400
9600
9600
9800
9800
10,000
9800
10,000
10,000
10,000
F350 SRW
10,700
11,100
10,800
11,200
11,000
11,400
11,000
11,400
11,200
11,500
F350 DRW
12,400
12,600
12,800
13000
12,800
13,000
13,000
13,000
F450 DRW
14500
14500
Maximum
GCWR
5.4L, 3.73:1 axle
16,000
5.4L, 4.10:1 axle
18,500
6.8L, 4.10:1 axle
21,500
6.8L, 4.30:1 axle
23,000
6.4L diesel, 3.73:1 axle
23,500
6.4L diesel, 4.10:1 axle
23,500
6.4L diesel, 4.30:1 axle
29,000
 6.4L diesel, 4.88:1 axle
33000
Max. Towing 1
F-250/F-350 SRW
F-350 DRW
F-450 DRW
Conventional-Weight carrying
5000(2268)
6000(2722)
6000
Conventional-Weight distributing
12,500(5670)
15,000(6804)
16000
5th Wheel/Goose Neck
16800*
18700
24500
*F-350 SRW only
1Properly Equipped
dgeesaman
Posted 2007-08-08 11:54 AM (#65419 - in reply to #65320)
Thanks to everyone for your responses.  They all helped a lot.
Regarding the long bed, I know we want a crew cab, and I know parking just a shortbed supercab gets irritating.  Longbed crew cab would be unacceptable as a daily driver.  20mpg highway though is not bad at all, and I'm glad to know I probably won't need dually size in the rear.  We'll definitely consider the bed size when choosing the trailer.
Though one can't judge the suitability of a truck without seeing the trailer nameplate, it does help immensely to know that your trailers are in the 10000-16000lb range.  It would have taken multiple phone calls to various manufacturers to reach a similar conclusion.
As for the gear ratio in the F-250/350 SRW, I can always change the diff gearing and speedo.  I suspect that it won't be a big deal, especially since I don't forsee getting a very large/heavy trailer.
Dave
Edited by dgeesaman 2007-08-08 11:57 AM
hav2ride
Posted 2007-08-08 4:02 PM (#65444 - in reply to #65404)
1000500100100
Rich, I should have expained my trailer better. It is a 15' LQ, 3' mid and a 1000 lb slide out (not all slides are made the same!!), 40 gal water tank and holding tanks, 2 larger sized LP tanks and a generator with a 30 gal tank, so it is a heavy beggar but my point was the OPs question needed more info to answer properly.
Edited by hav2ride 2007-08-08 4:05 PM
Rich M.
Posted 2007-08-08 4:30 PM (#65446 - in reply to #65320)
Wow, thats a bruiser in my book !. Comfy though I'll bet.
hav2ride
Posted 2007-08-08 7:41 PM (#65455 - in reply to #65444)
1000500100100
Yea, it's as big as I would ever want to haul. I wish it were about 3'shorter but then I couldn't have my slide out. I don't mind hauling it at all, it's just not too easy to get into tight areas. But the space really helps because I live in it for weeks at a time (with my dog) and sometimes my husband is in there too. He's actually the one who wanted the slider. I was content in my 12' LQ.
happyrider929
Reg. Jul 2007
Posted 2007-08-09 8:18 AM (#65471 - in reply to #65320)
I've pulled a tapered nose GN with an F250 crew cab short bed for over 6 years now, without a single problem, and I've maneuvered in some pretty tight spots before. We also wanted the crew cab (and are VERY happy we got it), but didn't want a long bed either due to daily driving and parking considerations. This truck pulls great!
SLICKRNSNOT
Reg. May 2006
Posted 2007-08-09 10:16 AM (#65481 - in reply to #65320)
On My Trails west,10x15 with slide and angled mid tack 3 horse,Pulled with a 06 Ford crew cab dually long bed.4.10 rear and auto.
weight
front truck 5150
rear truck 8100
both trailer axles 10600 ( 2 horses add # for 3rd)
total 23850 water,food,clothed,beer,...did I mention beer ? oh yea...
that gives a tounge wt of 4850 and trailer wt of 15450
just some info.I also added air springs and air horn, wife loves it.
Terri
Posted 2007-08-09 11:57 AM (#65486 - in reply to #65481)
200050010010010025
Air horn?  I bet that will scare the crud out of people trying to cut in front of you.
SLICKRNSNOT
Reg. May 2006
Posted 2007-08-09 1:55 PM (#65494 - in reply to #65320)
Yea it does !
hav2ride
Posted 2007-08-10 8:01 AM (#65546 - in reply to #65494)
1000500100100
I would like to have an air horn too. Last weel I was on a major 3 lane highway going 65 in the middle lane and I had a loaded dump truck cut me off and hit his brakes. With no where to go, I had to hit my brakes HARD and layed on my horn. I don't think he even heard my horn (or he was just being obnoxious). Now, if I had had an air horn.... :)
