Insulation
memory
Reg. Jul 2007
Posted 2007-07-29 2:59 PM (#64583)
Subject: Insulation
Can I use duct tape for the insulation installation or does it have to be aluminum tape? What are the pro's and con's of tape vs. glue?
Dwight
Posted 2007-07-30 10:55 AM (#64645 - in reply to #64583)
Subject: RE: Insulation
I would use glue.  Extreme temp. changes over the seasons can cause tape to lose it's adhesiveness.
RIDE ON!
memory
Reg. Jul 2007
Posted 2007-07-30 11:06 AM (#64647 - in reply to #64583)
Thank- you.  Is a squiggle line down the middle enough?
maccwall
Reg. May 2004
Posted 2007-07-30 12:03 PM (#64660 - in reply to #64583)
500
Hi Memory,
If you use glue make sure you get stuff that won't eat the insulation. Just bead it from top to bottom in a "squiggle". I would not use duct tape as I have experienced that when it gets hot, it will come undone. The aluminum, I've found, works much better.
Edited by maccwall 2007-07-30 12:05 PM
memory
Reg. Jul 2007
Posted 2007-07-30 12:25 PM (#64662 - in reply to #64583)
Thanks.  I will get some special glue today.  Lynn
gabz
Posted 2007-07-30 3:24 PM (#64677 - in reply to #64583)
1000100100100252525
hmmm... that's interesting... glueing the insulation.
I love using the alum tape - it means I can tape to the "beams" and cover any gaps; plus, I can piece together scraps of insulation to completely fill a section.
I bought both the regular on the roll and the stuff that has the backing to it. I haven't had any trouble with it working loose. (I haven't finished paneling over the insulation in the ceiling yet.)
