 | Info may be on the trailer's serial number plate/tag. 7000# axles have 9/16' studs, the 8000" axles have 5/8" studs (uses a larger hub than the 6000# and 7000# axles)and most run 17.5' wheels. At least all of what I own does. If you can get under the tailer there may very well be a tag on the axle with make, model, axle wt. rating and axle serial number. |
