    Location: Gallatin, TN | My son's TWH gelding has developed an allergy to something in our pasture. He has broken out on his face, chest and shoulders and rubs until the hair comes out. Does anyone have any suggestions to help alleviate his condition? We are using a granulated antihistamine but that doesn't give him much relief. Thanks in advance for all the wonderful words of wisdom. JacciB  P.S. It is NOT rainrot.
Edited by JacciB 2007-06-01 10:36 AM
.jpg) Expert
      Location: Southern New Mexico | My appy mare has those exact symptoms. I have been giving her the Triple Crown Rice Bran Oil Plus for about a month now. It has really seemed to help with her dry itchy skin and the hair is comming back. I have also started my old mare on it for her really dry skin. It's a bit pricy, but so far the results have been good. http://www.triplecrownfeed.com/12percent.php Click on the rice bran oil plus and it will tell you what is in it. |
  Location: Claxton, Ga. | Get some ground flax seed and feed'em 4oz a day. I normally did 2- 2 oz. feeding when I was feeding it. I now use feed that has ground flax seed in it. A 50 lb bag will cost about $36 and last a long time. 3-months or greater. You need to figure out what is causing the problem. Flies, gnats or whatever and try to prevent the problem but the ground flax seed will help. Keep him coated with fly spray. I have a TWH mare that has the same problem. Her damn had the same problem also. Oh yeah, he will be shinny as a dime after a couple of months. His skin/coat will be unbelievable. |
.jpg) Expert
      Location: Southern New Mexico | Thats why I started my mare on the Triple crown stuff. I couldn't find any of the flax seed and it's in the oil. |
| Are you sure he doesn't have Sweet Itch from the bites of Midge flies? Many horses are allergic to midge fly bites and if left go by the unknowing horse owner, can result in misery for the horse and a whopping vet bill ---- ask me how I know that If you are, in fact, dealing with Sweet Itch (horses can develop that allergy later in life as I have found out), be prepared to have to deal with it almost daily until those nasty little creatures go away for the winter Regardless of whether I am treating scratches, sweet itch or rain rot, I wash the area with water and provodine or betadyne or iodine, keeping the mix dark brown. I slather WalMart's brand of diaper rash cream on it because: That zinc oxide seems to make everything eventually go away and diaper rash cream is thick enough to keep the flies off the sore and won't easily wash off in the rain. That all being said, were it my horse and never having dealt with something like this before, I would call the vet to be sure |
      Location: East Tennessee, USA, Planet Earth | Have you called your Vet? |
    Location: Kansas | I've had good luck with Pawalker's method but there is a little twist. I mix it about half and half with Noxzema, which has some medication to add to it. For me, it has worked better than straight zinc oxide, which I've also used. Many uses from girth galls to sunburn prevention. |
| "I mix it about half and half with Noxzema" I am smacking myself on the forehead for not thinking of that myself Wal-Mart here I come for a big jar of Noxzema |
     Location: KY | generic benadryl for people; give him 10 (25 mg each) capsules twice a day; after 2 doses, he'll probably be a little sleepy but should have major relief from the allergic reaction.... if no relief, then call the DOC. |
    Location: Gallatin, TN | I have taken him to our Vet. He got us started with granule antihistamine, but advised us it may not provide as much relief as we hope as we did not want to spend the $$$$ on endless allergy tests that may reveal nothing. After reading the post about the Midge flies, I do believe that is our problem. My husband noticed that there are many more flies on this particular horse than our others and it does, in fact, clear up in late fall early winter. I will definitley try the Noxzema / zinc oxide combo. Thanks to all for your words of wisdom and experience. JacciB  |
     Location: KY | Are midge flies the same as "no see ums"? If you have a sewing machine, you can make "body armour" for the horse to wear....get the cheap nylon fabric that is breathable (has tiny holes) sew the front shut, pull over horse's head, then using stick on velcro, stick the fabric shut under the belly and under the tail. Once the velcro is adjusted, then you can sew it on for permanency. On the other hand, there are many excellent turnout suitable fly sheets for sale at all the on line shops. We use our homemade under saddles since it does not have any hardware on it. Best of luck to you in fighting the wicked biting pests. |
Location: Oklahoma | More than likely your horse has a reaction to insects, what kind may never be known. If you have a good vet clinic, I would suggest taking your horse to them, typically they will reccomend a steriod shot which will bring some relief, may require anouther shot in 30 days. Also a antigen can be made from the horses own blood serum to prevent reoccurance. This may sound expensive but usually is not (depends on clinic), my personal experience has shown this to be a good course of treatment, if not cleared up this may turn into a continual problem with time of some remission and then getting worse again. Good luck! |
     Location: Fort Worth, Tx | A steroid shot (prednisone) may be helpful but it is fraught with side effects, some very dangerous. For short term relief use flax seed-I have also had good luck with "sweet itch" by putting horses with it on Source Micronutrients, although it takes a good while to see results. |
   Location: Coconut Creek, FL | FYI: A good friend who had a horse that had been having a lot of breathing issues, her vet had pretty much tried everything and nothing was working. She kept suggesting allergy testing and the vet said no, not worth the expense, but meanwhile the horse was on several expensive medications. She decided to get a 2nd opinion and the new vet suggested allergy testing. Guess what - poor ol Earnhardt was allergic to timothy hay, corn, carrots, and other things she'd been feeding him for the past 5 years. She changed his diet and he looks like a new horse! No breathing issues, skin is great, and he's not on any medications. Just stopping the medications saved her in one month the cost of the allergy testing. So don't always rule out allergy testing, sometimes it's better to pay a little to find out the real problem and cure it.
Edited by Dunoir 2007-06-06 11:23 AM
    Location: Gallatin, TN | That is a very good point, Dunoir. If zinc oxide/noxzema mix combined with the flax seed and a good fly sheet to help, I believe I will "bite the bullet" and schedule the allergy tests. Afterall, it's not fair to the horse to suffer because of a vet bill. Thanks again to all. JacciB |
 Location: FL & up-state NY | Please check out this product: BugCheck! It can be ordered through TheNaturalPetVet.net or it is for sale through Smartpack. Even some feed stores are starting to carry it, at least here in FL. I am vet poor from my gelding. He has a terrible time with hypersensitivity to 'no-see-ums'. So bad that if the steroids didn't work there was talk between the vets & university that the final outcome might be to put him down because he was so bad and getting worse each year. Oh, he was only 4 at the time. He lived year round as a bloody sore with secondary infections. Sorry to cut it short, my daughter just woke & is crying. Good luck! |
Location: Indiana | My vet ran a blood test on my mare that was real bad last year with hives and loosing her hair.She's allergic to grass hays,oats,molasses,black flies,deer flies,cullicoides(?)some fungus,cotton and about 15 other things.She had to be on steroids last year sveral times along with daily doses of hydroxyzine.We changed her diet ( corn,soy,beet pulp,and alafala hay.)Had to get her back on hydroxyzine when bugs came,but very controllable.She may get a few bumps when she gets bit,but they don't spread and get bigger.We get the cheap hydrocortisone cream from the dollar store to put on the bites.Her access to outside is limited during bug season and she wears a fly sheet indoors.It was worth the $200 it cost to send her blood to be tested.The emergency steroid shots to stop her nostrils from sweeling so she could still breath were more than the test. |
