Originally written by Reg on 2007-05-28 7:31 AM
I dunno Paul, that looks like a kemmi book quote about elemental Aluminum. Parking under power lines, near substation transformers, running a generator, washing with chlorinated water ? I think I'd get a pocket knife out and scrape a few shavings for a metallurgy lab to check. HOPEFULLY it isn't just 1xxx series sheet that they just threw down as a floor, but knowing what it is could be helpful. And here I thought I would never use any of those college physics courses dealing with the structures of matter... All you wanted to know about Corrosion on Aluminum alloys... Effects of Composition and Microstructure on Corrosion1xxx Wrought Alloys. Wrought aluminums of the 1xxx series conform to composition specifications that set maximum individual, combined, and total contents for several elements present as natural impurities in the smelter - grade or refined aluminum used to produce these products. Corrosion resistance of all 1xxx compositions is very high, but under many conditions, it decreases slightly with increasing alloy content. Iron, silicon and copper are the elements present in the largest percentages. The copper and part of the silicon are in solid solution. 2xxx wrought alloys and 2xxx casting alloys, in which copper is the mayor alloying element, are less resistant to corrosion than alloys of other series, which contain much lower amounts of copper. Alloys of this type were the first heat-treatable high-strength aluminum base materials and have been used for more than 75 years in structural applications, particularly in aircraft and aerospace applications. Much of the thin sheet made of these alloys is produced as an alclad composite, but thicker sheet and other products in many applications require no protective cladding. Electrochemical effects on corrosion can be stronger in these alloys than in alloys of many other types because of two factors: greater change in electrode potential with variations in amount of copper in solid solution and, under some conditions, the presence of no uniformities in solid solution concentration. However, that general resistance to corrosion decreases with increasing copper content is not primarily attributable to these solid-solution or second phase solution-potential relationships, but to galvanic cells created by formation of minute copper particles or films deposited on the alloy surface as a result of corrosion. 2xxx Wrought Alloys Containing Lithium. Lithium additions decrease the density and increase the elastic modulus of aluminum alloys, making aluminum-lithium alloys good candidates for replacing the existing high-strength alloys, primarily in aerospace applications. 3xxx Wrought Alloys. Wrought alloys of the 3xxx series (aluminum-manganese and aluminum-manganese-magnesium) have very high resistance to corrosion. The manganese is present in the aluminum solid solution, in submicroscopic particles of precipitate and in larger particles of Al6(Mn,Fe) or Al12(Mn,Fe)3Si phases, both of which have solution potentials almost the same as that of the solid solution matrix. 4xxx Wrought Alloys and 3xx.x and 4xx.x Casting Alloys. Elemental silicon is present as second-phase constituent particles in wrought alloys of the 4xxx series, in brazing and welding alloys, and in casting alloys of 3xx.x and 4xx.x series. Corrosion resistance of 3xx.x castings alloys is strongly affected by copper content, which can be as high as 5% in some compositions, and by impurity levels. Modifications of certain basics alloys have more restrictive limits on impurities, which benefit corrosion resistance and mechanical properties. 5xxx Wrought Alloys and 5xx.x Casting Alloys. Wrought Alloys of the 5xxx series (aluminum-magnesium-manganese, aluminum-magnesium-chromium, and aluminum-magnesium-manganese-chromium) and casting alloys of the 5xx.x series (aluminum-magnesium) have high resistance to corrosion, and this accounts in part for their use in a wide variety of building products and chemical-processing and food-handling eguipment, as well as applications involving exposure to seawater. 6xxx Wrought Alloys. Moderately high strength and very good resistance to corrosion make the heat-treatable wrought alloys of the 6xxx series (aluminum-magnesium-silicon) highly suitable in various structural, building, marine machinery, and process-equipment applications. 7xxx Wrought Alloys and 7xx.x casting alloys contain major additions of zinc along with magnesium or magnesium plus copper in combinations that develop various levels of strength. Those containing copper have the highest strengths and have been used as constructional materials, primarily in aircraft applications, for more than 40 years. The copper-free alloys of the series have many desirable characteristics: moderate-to-high strength, excellent toughness, and good workability, formability, and weldability. Use of these copper-free alloys has increased in recent years and now includes automotive applications, structural members and armor plate for military vehicles, and components of other transportation equipment. The 7xxx wrought and 7xx.x casting alloys, because of their zinc contents, are anodic to 1xxx wrought aluminums and to other aluminum alloys. They are among the aluminum alloys most susceptible to SCC. Resistance to general corrosion of the copper-free wrought 7xxx alloys is good, approaching that of the wrought 3xxx, 5xxx and 6xxx alloys. The copper-containing alloys of the 7xxx series, such as 7049, 7050, 7075, and 7178 have lower resistance to general corrosion than those of the same series that do not contain copper. All 7xxx alloys are more resistant to general corrosion than 2xxx alloys, but less resistant than wrought alloys of other groups. Although the copper in both wrought and cast alloys of the aluminum-zinc-magnesium-copper type reduces resistance to general corrosion, it is beneficial from the standpoint of resistance to SCC. |
