    Location: Western WA | I am on a waiting list for an RV spot for a show later this summer, and in case I don't get a hookup looks like I'll be generator shopping. I'll probably be using the generator mainly for recharging my RV batteries. How long will I have to run the generator each night to recharge my batteries (roughly)? Need to figure in fuel supply when shopping for a generator. Alternatively, if I plugged the trailer into the truck and ran the truck for a while, how long would I need to run my truck to recharge my batteries? This is a 5 day show so I'll definitely need to plan on recharging batteries at some point. |
        Location: Vermont | The correct answer is: IT DEPENDS... See below for charging theories... http://www.mpoweruk.com/chargers.htm C H A R G I N G T I M E Time To Charge Fully Discharged Battery | | Battery Type | Battery Rating | Charger Output Rating (Amps) | | | | 2 | 6 | 10 | 12 | 30 | | Cars/Trucks etc. | RC | Time to charge your battery (hours) | | 315 CCA | 60 | 20 | 7 | 4 | 3 | 1 | | 450 CCA | 70 | 23 | 8 | 5 | 4 | 2 | | 550 CCA | 85 | NR | 9 | 6 | 5 | 2 | | 850 CCA | 140 | NR | 16 | 9 | 8 | 3 | | 1050 CCA | 165 | NR | 18 | 11 | 9 | 4 | | Note change in ratings below to AH | AH | Time to charger your battery (hours) | small Motorcycle Garden Tractor | 12 | 7 | NR | NR | NR | NR | large Motorcycle Garden Tractor | 32 | 18 | 6 | 4 | 3 | NR | | Deep Cycle | 55 | NR | 10 | 6 | 5 | NR | | Deep Cycle | 80 | NR | 15 | 9 | 7 | 3 | | Deep Cycle | 105 | NR | 20 | 12 | 10 | 4 | | NR = Not Recommended for this size battery. |
from below... http://www.battery-chargers.com/charging_instructions.htm |
    Location: Western WA | At first glance those statistics look pretty dismal, like I'd have to run a generator all night to recharge my batteries. What has everyone's real life experience been? |
      Location: East Tennessee, USA, Planet Earth | Originally written by headhunter on 2007-05-24 6:40 PM
At first glance those statistics look pretty dismal, like I'd have to run a generator all night to recharge my batteries. What has everyone's real life experience been? what will you be using your batteries for? 90% of my horse camping is dry camping (no electric pedestal).i haul with an RV and i use my batteries (bank of two) to run my water pump, lights and ...if it's cold enough the heater fan. i have to run out of "juice". i don't leaving lights running, i use only the ones that i need and shut them off as i move thru the RV.in the morning, i check my battery level, and if it's low, i run my gen for about 30-60 minutes to recharge the battery bank.did you have a battery level indicator? |
    Location: Western WA | It will mainly be for lights and the water pump. And the show is in the Sacramento area the end of August so I don't expect to need to run the furnace, although I might be wanting to run A/C to cool things down before going to bed (I realize that would only happen when the generator is running). I also will need to check my email so will need to recharge my laptop batteries too. |
       Location: Northern Utah | I found that if I turned my generator on for 1-2 hours a day, I never seemed to drain my batteries. So if you turn it on to run the A/C for a couple of hours before bedtime. It'll charge up the batteries enough to get by. |
