Location: Coloraeo | Well, I went and done it now. Turned to hard -pulled the wires out of the plug.. I know.. I know...Not too bright.. but damage is done. I've got the running lights and turn lights figured out but can't figure out the remaining 3 wires I've got red/black, blue/ black and black Where do these go? Thanks |
   Location: Arkansas | Red is your brake (S) and Black is your ground (GD)...larger hole on side, Blue is your 12v hot auxilary (A) in the center. Hope this helps! (6 hole pattern) |
Location: Coloraeo | hi. thanks it's got a 7-way rec plug on it. Thanks for your help |
   Location: Arkansas | Then wire the color code as mentioned to the symbols for that color......position on plug for 7 not the same as 6, but A still means auxilary, S is for the brake wirem, and GD is still ground.......that should do it..... |
Location: St.George, UT | After you get the plug fixed I suggest putting a plug in the bed of your pickup to prevent this from happening again (if it is a gooseneck). It can mount either in front or behind the left wheelwell inside the bed. Not only does it prevent what happened to you but also looks cleaner. Mark M |
