To Close
hav2trot
Reg. Apr 2007
Posted 2007-05-11 10:27 AM (#60683)
Subject: To Close
Short Bed, 8' Trailer....you know the drill. What do you think is better? The Ball extension or the coupler extension??
Posted 2007-05-11 10:36 AM (#60684 - in reply to #60683)
Subject: RE: To Close
I like the coupler extension ... check the previous posts on short bed trucks
ridinhigh
Posted 2007-05-12 7:15 AM (#60710 - in reply to #60683)
The ball extension would be the only one that would give you extra room.  If you think about it, with a coupler extension on, and a trailer @ 90 deg. to the truck, you've done nothing to add clearance.  However, with a ball extension @ 90 deg., you've moved the trailer back 4".
Posted 2007-05-12 9:25 AM (#60714 - in reply to #60710)
Originally written by ridinhigh on 2007-05-12 6:15 AM
With a "ball extension" one might as well mount the ball in the truck bed the several inches rearward instead of paying for the extra.  This does move the applied load.
HWBar
Reg. Nov 2005
Posted 2007-05-13 8:02 AM (#60726 - in reply to #60714)
1000100100252525
Originally written by hosspuller on 2007-05-12 9:25 AM
On GM trucks this is not an option as the crossmember for the bed is above the axle. So the ball cannot be. I know this cause I just put one in less than a month ago. I bought the extend-a-ball, it's called from B/M.
mingiz
Reg. Jul 2004
Posted 2007-05-13 3:27 PM (#60735 - in reply to #60683)
I got the pop up hitch extender. Moved the trailer back about 9 inches and I can jack knife it without a problem. I have a short bed F250.
http://www.mrtruck.net/popup.htm
