found a truck is it good enough ?
albert
Reg. Jul 2004
Posted 2007-05-03 3:07 PM (#60369)
Subject: found a truck is it good enough ?
i am going to look at a ford f250 4wheel drive 5.4 engine. it has a towing capacity of 7,100 pounds. i am going to haul a 3,000lb bumper pull trailer with 2 horse's and tack. it shoud be about 5,800 lbs loaded. it this the 5.4 engine big enough to haul this load adequately even though according to the owners manual it looks to have enough hauling capacity?
jdzaharia
Reg. Apr 2006
Posted 2007-05-03 4:39 PM (#60373 - in reply to #60369)
Subject: RE: found a truck is it good enough ?
1001001001002525
That should be sufficient.  Plenty of people haul that same load with much less of a pickup.  The 5.4L Ford would not be my first choice, but I am biased.
rockyrider
Reg. Jun 2004
Posted 2007-05-04 6:08 AM (#60387 - in reply to #60369)
100100100
I think it's going to depend on the rear end. If it's 3:83 or higher you will probably be ok. You might find your self wanting a little more power in certain situations but over all ok.
mingiz
Reg. Jul 2004
Posted 2007-05-04 6:14 AM (#60388 - in reply to #60369)
I had a 03 F250 with a 5.4 in it. It did ok even with my 16ft 4horse stock loaded and my 28ft 3h. I got rid of it and went diesel because if I went to the mnts and had a steep climb it sounded like something was going to blow. It's an ok truck for flat land but not for mnts. With a 2 horse it would be ok anything bigger I would go diesel....JMO
Edited by mingiz 2007-05-04 6:18 AM
SLICKRNSNOT
Reg. May 2006
Posted 2007-05-08 10:43 PM (#60589 - in reply to #60369)
Sound good enuff !!Had a F250 with 5.4 and it pulled My 2 horse all over with plenty of power.
