Tire care, tire sealants, "wet" balancing.
Reg
Posted 2007-04-24 7:41 PM (#59889)
Subject: Tire care, tire sealants, "wet" balancing.
2000500100252525
I'm fairly sure that we havn't discussed sealants before
So HAVE AT IT !!!
Who is using what ?, with what results ?, etc.
Here is some background reading;
http://www.landlinemag.com/Archives/2003/Jun03/equipment/tires_life...
{Big rig oriented}
Edited by Reg 2007-04-24 7:45 PM
Posted 2007-04-24 10:40 PM (#59905 - in reply to #59889)
Subject: RE: Tire care, tire sealants, "wet" balancing.
1000500100100100252525
It sounds like the same stuff that you use in a tractor tires?
Reg
Posted 2007-04-25 8:07 AM (#59921 - in reply to #59905)
2000500100252525
Originally written by loveduffy on 2007-04-24 10:40 PM
No, it is quite different and incompatible with liquid ballast.
SOME of the companies also make/market tire ballast for tractor and construction equipment. Many/most sealants tend to stay suspended in liquid ballast instead of coating the inside of the tire.
A good sealant in dry tires COULD save a number of flats & slow leaks and at the same time help with (dynamic) tire balancing.
It is at least worth considering for truck & trailer tires, I have no financial interest in it - just an FYI.
Posted 2007-04-25 10:21 PM (#59974 - in reply to #59921)
Were do they do this? I am interested, I have a draft that i take to park and I help my friend with his drafts
N2ridin
Posted 2007-04-26 12:18 AM (#59978 - in reply to #59889)
50010025
What is "wet" balancing?
