How to tie 3 in 1 rigging?
meggerbegger
Reg. Apr 2007
Posted 2007-04-13 5:38 PM (#59235)
Subject: How to tie 3 in 1 rigging?
Does anyone know of a site that has pictures or any information on how to tie a 3 in 1 rigging saddle.  I am VERY well versed in just the standard rigging, both using the cinch buckle and a standard tie, but my new saddle has a 3 in 1 rigging and I think that a 7/8 might be the way to go as the front rigging is too far forward.  I want to combine the two riggings.  Any help/suggestions would be great!
hconley
Reg. Feb 2005
Posted 2007-04-14 2:50 AM (#59264 - in reply to #59235)
Subject: RE: How to tie 3 in 1 rigging?
use what ever is comfortable for you and the horse.
meggerbegger
Reg. Apr 2007
Posted 2007-04-14 3:45 AM (#59265 - in reply to #59235)
Thank you, but that was the point. I don't know how to set up the 7/8 tie, using both of the rings...I've seen a picture of it, but never any explanations of how to set it up. ??
hconley
Reg. Feb 2005
Posted 2007-04-14 4:36 AM (#59267 - in reply to #59235)
Make a v between the front slot and the rear slot for 7/8
bjhouten
Posted 2007-04-18 9:56 AM (#59530 - in reply to #59235)
5002525
The strap will be attached to the rear ring. Take the strap, run it through the ring on the grith, on the inside, up to the front ring,over the front of the ring, then back down to the grith ring,coming out in front, then back up to the rear ring, and tie if off like you would the westren rigging.Betty
meggerbegger
Reg. Apr 2007
Posted 2007-04-19 10:25 AM (#59600 - in reply to #59235)
Thank you, that is what I thought it was, but wanted to be sure as I have never had to use one before!  :)
