Solar Fencer
Charmer88
Reg. Feb 2007
Posted 2007-04-02 6:17 PM (#58329)
Subject: Solar Fencer
I bought my first solar fencer last year and it's dead...8 months old maybe? I read the battery is suppose to last 3 to 4 years. It doesn't have any shock and I unhooked the fence but left the ground to check it and still no output. Changed fences (to one that works) Nothing.
The light blinks consistantly and I'm assuming the battery is ok...is their anything to fix on those, worth sending it in?
Posted 2007-04-02 11:16 PM (#58362 - in reply to #58329)
Subject: RE: Solar Fencer
1000500100100100252525
most of the charger only have a battery to change out. what is the name?? Check to make sure that the charger is in full sun as much as possable. then check the ground rod it should be at least 3+ feet long  also check the wire if it is old it may have so many bracks in it  the wire is useless and last the charger could be just brocken it happens good luck
