Location: California | I have a 2002 Nissan Xterra - rated to tow 5000 pounds. I'm interested in pulling a 2 horse. Found one for sale -small 2H straight load- short length, no dressing room - 1900 pounds, hydrolic brakes, no load leveling bars. I have never pulled with this vehicle. My horse probably weighs in at about 1000 pounds. I want to take local trips 25 miles +/-, freeway, low hills. I've towed a lot when I was younger but always with a dully truck and a big trailer. Anyone out there ever pulled with a Nissa Xterra? Any suggestions on the hydrolic breaks? I don't know anything about them. Load Leveling Bars? I don't want to do this if it's crazy. Thanks in advance for the advice! |
Location: Newnan , Georgia | I pull trailers for a living and my personal opinon is to have electric brakes. There is an upside and a downside to both for instance with the electric brakes you have to have a brake controller. But the good thing about that is you can adjust your braking from inside the vehical whereas with hydrolic you cant. As far as I know you should be alright pulling short distances but keep in mind that summer is right around the corner so keep an eye on those gauges ( temp ). |
  Location: Claxton, Ga. | I have pulled a car trailer (Uhaul) with car (VW Beetle) with a 2001 Nissan Frontier. It had the supercharger so it had decent power. I have pulled alot of loads. This one was not that fun. I went slow because I had to. It didn't feel very comfortable going over 55 MPH. I could only imagine doing it with a load that moves around. I would recommend not to do it. Oh yeah, I am a nissan nut also, so it is nothing against the product. I have a Dodge 3500 dually to pull my GN horse trailer with. The only thing Nissan has that will pull a 2 horse BP is the Titan.
Edited by Spooler 2007-03-21 1:29 PM
| Xterras, Navagtors, Escalades, whatever other of those fancy vehicles are not physically equipped to pull things like horse trailers --- even two horse trailers. 1. Length of wheel base of the towing vehicle is crucial to stability. 2. Braking system is crucial - they aren't all created equal, even on 1/2, 3/4, 1-ton pickup trucks. 3. Transmission cooling system is crucial if the vehicle is an automatic. 4. Horses aren't boats. If the trailer starts to sway for whatever reason (wind gust, driver error, very nervous horse), the live weight of an animal can further perpetuate the sway. I have been pulling a 4-horse open stock for 30+ years and I've moved my own horses cross-country twice. So I have the experience to say that I also don't think the Xterra should be pulling even a one horse trailer. |
    Location: Denver Colorado | The Xterra is shorter than a Frontier King Cab or crew with the same drivetrain. I don't consider it a tow vehicle except for a tent trailer or ATV trailer weight. I think they are a great off-road vehicle. |
  Location: Louisville, KY | Originally written by PAWALKER on 2007-03-21 1:20 PM Xterras, Navagtors, Escalades, whatever other of those fancy vehicles are not physically equipped to pull things like horse trailers --- even two horse trailers. 1. Length of wheel base of the towing vehicle is crucial to stability. 2. Braking system is crucial - they aren't all created equal, even on 1/2, 3/4, 1-ton pickup trucks. 3. Transmission cooling system is crucial if the vehicle is an automatic. 4. Horses aren't boats. If the trailer starts to sway for whatever reason (wind gust, driver error, very nervous horse), the live weight of an animal can further perpetuate the sway. I have been pulling a 4-horse open stock for 30+ years and I've moved my own horses cross-country twice. So I have the experience to say that I also don't think the Xterra should be pulling even a one horse trailer. An Escalade or a Navigator would do just perfectly fine pulling a horse trailer. I've done it plenty of times. An Xterra is much much smaller...an Escalade has a 6.0 V8 and is basically same as a Suburban or a Tahoe...not a problem. I agree that the Xterra shouldn't even pull one horse for a mile!
Edited by Ms. Trailer 2007-03-22 12:46 PM
| "An Escalade or a Navigator would do just perfectly fine pulling a horse trailer" After I wrote that I realized I should've qualified that comment I have always had a 4-horse open stock and have pulled up into the moutains on 15% grades and have hauled my horses cross-country twice. When those 15% grades go on for more than a mile or two, the brakes need to be manly-man brakes and in great working order. I wouldn't recommend doing any of that unless one owns a pickup truck built for towing. My old heavy 3/4 4wd, logger truck doesn't pull my trailer as good as my husband's dually. The dually has a longer wheel base and much more stability. I err on the conservative side and I guess my thinking was if someone has to ask about an Xterra, I figured I'd eliminate everything that didn't come with a Cummins and wasn't built to pull a freight train The driver's common sense and abilities also plays a part in what they can get away with as a tow vehicle. I apologize if I offended anyone. |
        Location: Vermont | Originally written by PAWALKER on 2007-03-22 6:53 PM I apologize if I offended anyone. For penance...You will have to muck stalls at my barn for one month... |
     Location: sc | Originally written by PetPet on 2007-03-20 6:23 PMI have a 2002 Nissan Xterra - rated to tow 5000 pounds. I'm interested in pulling a 2 horse. Found one for sale -small 2H straight load- short length, no dressing room - 1900 pounds, hydrolic brakes, no load leveling bars. I have never pulled with this vehicle. My horse probably weighs in at about 1000 pounds. I want to take local trips 25 miles +/-, freeway, low hills. I've towed a lot when I was younger but always with a dully truck and a big trailer. Anyone out there ever pulled with a Nissa Xterra? Any suggestions on the hydrolic breaks? I don't know anything about them. Load Leveling Bars? I don't want to do this if it's crazy. Thanks in advance for the advice! no its not crazy, in fact its perfectly safe. set up correctly, wdh, brakes (persnally id pass on that trailer and look for one with electric brakes) it will be fine. come on people were talking about 3000 pounds, ~1000 less than the xterra weighs (no tail wagging dog here), and thats only 60% of the tow rating........even comes in under this silly 80% rule everyone is so fond of. i towed 6000 pounds for several years with the trailblazer (close to an xterra) IT DID FINE. experience is one thing, understanding is quite another. make all the excuses you want but if you guys need/recommend a 1/2 ton or larger for ONLY A 2 HORSE BP what in the world are you going to pull a big trailer with?
Edited by chadsalt 2007-03-23 6:37 AM
| "For penance...You will have to muck stalls at my barn for one month: Oh crap (excuse the pun |
  Location: pensacola, fl | I had to rent a Nissan Xterra when my truck was in the body shop, and I would have to say "No". I wouldn't think that it would be a good or safe vehicle for towing!! JMO!! |
    Location: Denver Colorado | Chadsalt, usually I sympathize with your logic. TrailBlazer has a little longer wheelbase though and feels safer to me when towing. I appreciate you bringing up all the safety things you need for towing with smaller vehicles like wdh. When I go to media launches for new trucks and SUVs, I can usually tow with most of them. I know something's up when they don't have one set up for me to try. Had this problem with Honda Ridgeline, couldn't find one with a hitch. When I do get a smaller truck/suv with a hitch, I end up using a Brenderup to be safe. I've pulled a Brenderup with a Jeep Liberty diesel last summer in the high country off-road on a mountain trail.
