      Location: Columbia, KY | OK this isn't exactly a trailer question but I need some advise, and this seems to be a good place to ask. where can I find running boards (or even just a step) to put along side the bed of my truck? truck is a 2000 F350 duelly. it has factory heavy plastic ones that go under the cab but they end there. I'm short, and to get in and out of the bed have to carry a stool to stand on. Ford tells me they don't make anything like that. I called Line-X and they said I"d have to buy a whole new running board, not just the piece for the bed. surely there is something out there that would work and match what already is on there. any suggestions? thanks! |
      Location: Columbia, TN | They told you right. That is the place you need running boards most. The old duallies you added them to it and you had someplace to stand when hooking up the trailer. |
   Location: Odenville, Alabama | ICI is where my nerf bars came from. www.ici.com |
.jpg) Expert
      Location: Southern New Mexico | I have the same problem, I just ended up using the tire as a step instead of spending lots of $$$$. |
      Location: Columbia, KY | well I've tried standing on the tire or hub but sometimes slip off. I have a bad knee so I figure it's cheaper to get running boards than another knee surgery. will check out the ICI website. thanks |
  Location: Alabama | Try the two links below. One is a step that fits over your tire as needed and the other is a step that fits over your tailgate. This website is just the first one I came across in a seearch so you might can find these items cheaper somewhere else.
http://www.rvshop.com/catalog/product_info.php/cPath/5_37/products_...
In case the above links don't work, go to www.rvshop.com and search for Tire Hopper Step and Tailgate Step.
     Location: KY | got mine (wheel to wheel) boards from autopartswarehouse.com they came in sections, one section under the cab the other for under the bed....happy shopping
Edited by rose 2007-03-19 8:42 PM
