slant or straight load
kurtk
Reg. Mar 2007
Posted 2007-03-15 9:04 PM (#57129)
Subject: slant or straight load
Just wonder what is a better trailer to have. Is a four horse head to head better than a four horse slant ?  What do you think of Hawk trailer's ?  Any problems with the trailer ?
Thanks
Kurt
Posted 2007-03-15 11:56 PM (#57134 - in reply to #57129)
Subject: RE: slant or straight load
1000500100100100252525
I do not know the trailer ,but straight load is the best way to go. the stall are smaller on any slant load trailer then straight load
chadsalt
Posted 2007-03-16 6:43 AM (#57140 - in reply to #57134)
1000100100100100
Originally written by loveduffy on 2007-03-15 11:56 PM
what difference does it make how big the stalls are? either the horse fits or it doesnt, has nothing to do with slant or straight. slants can be customized to fit most anyone.
Reg
Posted 2007-03-16 8:44 AM (#57146 - in reply to #57129)
2000500100252525
Originally written by kurtk on 2007-03-15 9:04 PM
Thanks
Kurt
Hi and Welcome to the Forum.
Yes, good, no.
There are several other threads on this, I suggest you try the search button.
Edited by Reg 2007-03-16 9:00 AM
Reg
Posted 2007-03-16 8:57 AM (#57147 - in reply to #57140)
2000500100252525
Originally written by chadsalt on 2007-03-16 6:43 AM
Different horses, growing families, upsizing from ponies to horses, whatevers to warmbloods, TBs to TB/draft cross - changing needs.
Most slants would require SIGNIFICANT mechanical changes to go to larger horses than originally planned. True, the bright blue wrench can change a lot of things, but re-spacing the dividers and latches on a slant load isn't something I would want to do or have done say 4 or 5 years into a trailer. In many cases you would just get 3 big stalls instead of 4 smaller ones. IMO better to buy more space in the first place
Then there's the whole "face space" vs head in the corner thing, getting every horse out in any order, front right/rear hind diagonal travel, on and on...
The only thing that slants have going for them is DENSITY !
You can cram more horses into a shorter box length, maybe some marginal benefit/convenience for the driver, but heat builds up quicker when stationary if they're packed in tight.
Oh yes, see other threads for the ad nauseum rants on this )-:
chadsalt
Posted 2007-03-16 10:11 AM (#57159 - in reply to #57147)
1000100100100100
Originally written by Reg on 2007-03-16 8:57 AM
you rant? surely not. i dont disagree with anything youve said. i was only stating acutal stall size can be "similar" when ordered as such.
i suspect if i need a bigger trailer i would look hard at the 4 horse hth, probably the same hawk the OP is talking about. but then if i had open stalls on the trailer people would want to tag along on my trail rides..........and that would defeat the purpose of me getting out in the woods away from it all.
huntseat
Posted 2007-03-16 12:01 PM (#57167 - in reply to #57129)
1000500100100100100252525
I've found my horses perform better when hauled in straight loads.
I think the only real difference is in size, a 4 horse H2H will be longer.  I like having the ability to pull horses out in any order and to get inside and look at them during stops without getting stomped.  Some folks at local HJ shows will tack up and groom inside the center of their H2H trailers, like a mobile barn!
jdzaharia
Reg. Apr 2006
Posted 2007-03-16 4:31 PM (#57192 - in reply to #57147)
1001001001002525
Front Right/Left Hind debate.  This has never made any sense to me.  I am not picking on you directly, as a lot of people use this argument when trying to discount slant load trailers.
The argument only makes sense if you are travelling down a perfectly straight road, driving perfectly straight, and there is no crown in the road.  Then slowing down and speeding up would put more pressure on the horse's front right and left hind legs.  Heck, even in North Dakota the road turns every once in a while.
Okay, drive down a normal road.  You slow down, speed up, curve left, curve right, go uphill, go down hill, accelerate around curves, hit potholes on one side or another, you swerve to miss a skunk, the vehicle sways in the wind, etc.  The horse could be standing any way imagineable, and all legs would eventually get the same amount of stress.  If the vehicle is going perfectly straight on a perfectly flat piece of road, at a perfectly constant speed, the horse feels no more stress than he would standing in his favorite pasture.
Don't get me wrong.  I am not a champion for slant load trailers, but some of the arguments people use against them are ridiculous.
foxpointfarm
Posted 2007-03-16 4:50 PM (#57194 - in reply to #57129)
Depending on how many horses you really are going to pull - I would consider a two horse straight load with a side ramp. This way, you can get at least 3 horses on, maybe 4 if you have two small ponies in the front.
We just recently went through a similar search as you. We were going to get a two horse straight with a side ramp. However, our Hawk dealer had just traded for a 4 horse head to head and a 4 horse "stupid six". A Stupid Six (as the dealer called it) is basically a 6 horse head to head with the 3 stalls on the tail chopped off. So, you have three horses that are reversed loaded in the nose of the trailer with a 8 x 10 box stall on the back. To load, you walk the horse on the trailer and turn them around.
We ended up getting the stupid six - it was about 7 feet shorter than the 4 horse H2H but the body of the trailer was two feet wider. (Hub to Hub width was the same).  Both trailers were Hawks. In my opinion, Hawk is one of the best trailers out there. They WILL be heavier than a same size aluminum trailer since they are steel frame with aluminum skin. They are very well constructed and the attention to detail is amazing. With Hawks, you can have the trailer painted to match your truck plus they will customize floor plans for you.
Reg
Posted 2007-03-17 7:28 AM (#57217 - in reply to #57192)
2000500100252525
Originally written by jdzaharia on 2007-03-16 4:31 PM
If the perfectly straight and flat road model helps you with a simple understanding of the right front/rear hind stress model - you SHOULD be able to extend your understanding to appreciate that it is also a BIAS in all the other instances that you cite. They are ALL accelerations.
The other arguments in favor of the head to head still stand, again the ONLY argument in favor of the slant load is density, and even that is against the interests of the horses in many cases.
Edited by Reg 2007-03-17 7:32 AM
jdzaharia
Reg. Apr 2006
Posted 2007-03-17 9:23 AM (#57223 - in reply to #57217)
1001001001002525
Originally written by Reg on 2007-03-17 7:28 AM
I totally understand stress models, free-body diagrams, and Newton's laws (of which, F=MA most applies here). I could have used the lingo of a dynamics instructor at (insert your favorite engineering school here), but the straight, flat road example was the only one I could thing of at the time where A=0. My point was just that A is actually greater than 0, and that A vector can be in just about any direction, so the the front right/left hind argument holds no water.
Overall, I agree, but I think if I was really assigned to the project, I could find a few more arguments in favor of a slant load. Anyway, no big deal. I will just quote myself this last time.
Don't get me wrong. I am not a champion for slant load trailers...
Tx. Vaquero
Reg. Jun 2006
Posted 2007-03-17 9:33 AM (#57224 - in reply to #57129)
I've read a lot of this about the evils of slant loads and I don't believe any of it is based on fact, just personal preference. The " it's what I've got, so it has got to be the best" syndrome. My horses probably get hauled as many miles as  most, and I depend on them to help me make a living, so I do everything I can to make sure they are as close to 100% as they can be, all the time. I have hauled in slant loads for years and have never had an issue with my horses right front/ left rear legs from hauling. Somebody dreamed that up and it has been repeated so often that now people "in the know" quote it as if it were some scientifically proven fact. It is a joke folks. If you like a straight load, buy one. If you prefer a slant, don't worry about it, just look at what the horses that get hauled 50,000-75,000 miles every year ride in. Don't let the rantings of some part time hauler influence your decision. As far as loading/ unloading, it is all about training. When my horses get to the trailer, I throw the lead rope over their backs and they walk on and wait for me to close the divider. When we unload, I open the divider and they stay where they are until I tell them to back out, then they go stand by the side until I tie them or saddle up. Any horse can learn this with time and patience, so it is not about the trailer configuration.
huntseat
Posted 2007-03-17 10:41 AM (#57225 - in reply to #57129)
Since hauling a horse is not a static situation your acceleration = 0 claim is invalid.  Dynamic situations involve more variables than just acceleration, I'm sure as an engineer you knew that already.
I think an equilibrium calculation better suits this situation, but that is for another time.
You could also ask yourself a quick question, when a horse stops in the pasture do they use both front and hind legs equally?  Or do they stagger sideways and use only the front right and rear left leg?
Posted 2007-03-17 9:25 PM (#57241 - in reply to #57225)
Originally written by huntseat on 2007-03-17 11:41 AM
In the Hills of West Virginia...the answer is YES...
Unless they were born and bred there...then one set of legs is shorter than the other set...
Posted 2007-03-17 9:36 PM (#57244 - in reply to #57129)
Since you don't appeared to have search the forum...
Here are some things to consider...
Loading: Horses don't necessarily load more easily into a slant -- they will load very easily into an open, airy, light trailer of ANY kind. Horses are generally quite happy to load into a Thoroughbred-style front-door trailer: the handler can lead the horse in and then duck under the chest bar. Horses will also load more easily when they have been taught to load correctly - and when they aren't anticipating a rough ride, which has much more to do with the driver than with the trailer design.
Unloading: It's not possible to lead horses out of all -- or even most -- slant-load trailers! If you have a large three-horse slant-load trailer and small horses, you can generally lead the last horse out, but the first two will need to back out unless they are truly small and short-backed. Thoroughbreds and other long-backed breeds will almost always need to back out.
Dropping heads: It's very true that horses travel much better when they can drop their heads, both for muscle comfort and because their respiratory systems can function MUCH better that way. But again, unless you have small, short-backed horses in a slant-load, they won't be able to do this even if you tie them long. There just isn't enough room in most slant-load trailers -- the stall length is measured diagonally, and horses don't stand diagonally! If you measure the stall length from nose to tail, there is usually significantly less space available in a slant-load -- sometimes several feet less -- than there is in a comparably-sized straight load. Again, the horse would be better off either loose in a stock trailer (or in half of a stock trailer) or in a straight-load Thoroughbred-style trailer with only a chest bar in front, and a LOT of room in front of the chest bar to accomodate the horse's choice of head/neck positions during the trip.
It's true that horses will naturally tend to place themselves at a slant; many will turn all the way around and face backward, which is probably the MOST natural way for them to travel in a trailer. Unfortunately, few trailers, and no towing vehicles, are designed to allow this! Horses like to stretch to take up whatever space is available, which is why it's always nice to remove the divider or tie it back if you are hauling ONE horse in a two-horse trailer of any kind. But whether they are expressing a strong preference for travelling at a slant, or whether they are simply standing on the diagonal because that allows them more freedom of movement, isn't entirely clear.
Some people perfer straight-load trailers; some prefer slant-loads. Either way, it's a good idea to learn as much as you can about BOTH types and all the variations available, before you make up your mind to buy one -- whatever you get is something you and your horses will probably be living with for a long, long time.
One other point...if you have Drafts...forget slants :-)
jdzaharia
Reg. Apr 2006
Posted 2007-03-17 9:49 PM (#57245 - in reply to #57129)
1001001001002525
Good post PaulChristenson. One thing that makes a big difference in the "dropping heads" area is whether or not a trailer has mangers. Some straight loads and some slant loads have mangers which make it nearly impossible for a horse to drop their head. The ones common in slant loads often make an already crowded trailer even more crowded. I prefer trailers without mangers.
jdzaharia
Reg. Apr 2006
Posted 2007-03-17 9:56 PM (#57246 - in reply to #57225)
1001001001002525
Originally written by huntseat on 2007-03-17 10:41 AM
If you could haul a horse at a constant speed, in a straight line, down a straight, flat road the acceleration on the horse would in fact be zero.  The horse would be in perfect equilibrium...
...Until a fly bites his leg.  Ha ha.
Reg
Posted 2007-03-17 10:11 PM (#57247 - in reply to #57223)
2000500100252525
Originally written by jdzaharia on 2007-03-17 9:23 AM
As you say (imply) the direction of the vector MATTERS.
There are enough cases in the slant load trailer for the BIAS of the slant position to add to the accel to the detriment of the horse(s). In the cases where it subtracts it doesn't negate the cases where it adds.
This matters about as much as what Capone was actually arrested FOR, it wasn't what they really wanted him for, but they got him.
The slants are already out for the other reasons, many/most of which I didn't list. I really don't see your point in picking on this one detail with nothing to base your argument on.
Perhaps I should have put it more simply for you ?
PS I forgot that stuff about turning them around when they're half in half out and the horse steps backwards off the side of the ramp. TOO many of those little incidents at shows, especially when the Mom lets the kid unload the horse. Yes, a mini center aisle barn IS kinda nice when you're making coast to coast trips and don't want to feed through a window in pouring rain.
jdzaharia
Reg. Apr 2006
Posted 2007-03-18 10:25 AM (#57262 - in reply to #57247)
1001001001002525
Originally written by Reg on 2007-03-17 10:11 PM
Yes, please explain this one a little more for me. In what sense do you mean BIAS?
Okay, fair enough. Then why even bring up the front right/left hind argument? The rest of your arguments are good.
What ramp?
Can't argue with that.
Its all about horses
Reg. Feb 2007
Posted 2007-03-18 12:50 PM (#57268 - in reply to #57129)
Ok I have been gone for a little bit.  (Hauling horses)  Like other posters have stated the type of trailer you get depends on what you want and what you like.  I have hauled in many diferent trailers and have never found a diference in how the horses like a trailer over another.  It all dependes on how well you drive the trailer and how the trailer rides.
As for droping their head in a trailer my big TB/Appy (17.2) can drop his head very well in my slant load traielr.  It not even a custon trailer for him, it just fits him.
And to the person who stated if you have drafts forget about a slant trailer I say you are very wrong.  My clients 2 Shire geldings fit in her sland trailer just fine.  If you try to put them in a straight load you will find yourself in the back 40 with one arm longer than the other and woundering what every posesed you to think of putting that horse in a trailer.  They are two of the nices geldings you will ever meet.  Defently the gentle giant.
Just remember when you are hauling horses be nice to them and don't cut corners, brake hard, or run a red light.  Don't wory when you have a trailer, you are bigger than the other cars on the road, they will move when you want the road.
huntseat
Posted 2007-03-18 6:37 PM (#57272 - in reply to #57129)
I couldn't agree less, most regular drivers try and cut in front of a large horse trailer so they won't be stuck behind it.  Just like folks that use the gas at the diesel pumps...I can only use that one but they could use all of them!
Reg. Feb 2007
Posted 2007-03-19 3:48 PM (#57327 - in reply to #57129)
Oh yes, other drivers will cut in front of you but if you keep right on moving they will get out of your way fast.  I actualy had a cop pull a guy over for cuting in front of me.  Got a ticket for reckles driving.  In the valley the trailers rull the road and when we want it we get it.
huntseat
Posted 2007-03-19 8:46 PM (#57343 - in reply to #57129)
I'd rather not be in a wreck just to prove my point.
cowboyfritz
Reg. Dec 2006
Posted 2007-03-19 9:18 PM (#57347 - in reply to #57129)
you are getting off the subject of slant vs. straight  what is better. My question is do they make a 4 horse straight load  BP.
Posted 2007-03-19 9:29 PM (#57348 - in reply to #57347)
slant loads are from drivers side to passage side the road is only so wide that is the size of the stall on a slant load. In that the size is smaller because the horse or pony does not fit in the corner of the stall
farmbabe
Posted 2007-03-20 7:31 AM (#57360 - in reply to #57129)
1000500100100
Slant vs straight load? I have a slant...like it very much. Horse loads fine, unloads just fine. Performs just fine too. While a slant has draw backs, so do the straight loads so there is no right or wrong...better or best situation here.
jdzaharia
Reg. Apr 2006
Posted 2007-03-20 9:52 AM (#57367 - in reply to #57347)
1001001001002525
Originally written by cowboyfritz on 2007-03-19 9:18 PM
Several manufacturers make a 4 horse straight load BP. Most of your options here are going to be a stock-type trailer. That isn't necessarily a bad thing, but tack storage will be minimal. Most only have a small spot under the manger in the front of the trailer or none at all.
T*H*J
Reg. Mar 2006
Posted 2007-03-21 10:53 AM (#57450 - in reply to #57129)
Personally I prefer a 4 horse h-t-h, for all the reasons that were previously given against slant loads.    They are perfect for those all-days shows where you get the extra shelter of that middle area, plus you can check or get to all your horses should you need to.
As for the 4 horse straight load....my old coach had a Trail-et 6 horse head-tail straight load which was a PITA, especially if you needed to pull the middle horse - you'd have to unload the first or last horses to get them out, although with a 4 horse head-tail it would be a bit easier.   But IMO, the extra room that centre stall a 4 horse head-head gives you is so worth it.
Posted 2007-03-23 8:47 AM (#57560 - in reply to #57450)
the horse huler around here has a head to head I love the trailer I wish some day to get one the exta space is great for setting up and other things
