Location: Little Britain, Ontario, Canada | Howdy! HvyHauler Look on the frame of the goose neck, left hand side, some times on the inside of the frame. Or you can ask to look at the ownership. Be sure to crawl under a trailer that is of that era, check the frame and cross members with a screwdriver, if you can push it through anywhere on the frame or crossmembers move on to another trailer. |
