  Location: Helena, Ohio | Hi Guys!! I just started having a problem with my truck. It is a 2000 F-250 SD 5.4 V8 auto. trans, ext. cab, shortbox. The O/D light started flashing... sometimes is shifts hard into 2nd & 3rd.. & sometimes all gears. I just had some work done on the front end, brakes, rotors, tye-rod end and the G.E.M module had to be replaced. Any ideas??? |
   Location: Danielsville Georgia | Its a hard failure with a code stored. |
   Location: Northern IN. | Yup, if the light's flashin' then it has a trans. code stored, you'll have to take it in and have it scaned then they'll tell ya what the trans. sensors "picked up" and what it'll take to fix it. Good luck with that, talk to y'all later... |
  Location: Helena, Ohio | I had it scoped and they didn't find anything.... Maybe they scoped the wrong location? Is that possible??
Edited by Rockin_horse72 2007-02-23 8:39 PM
