Removing Decals from Trailer
CatB
Reg. Feb 2007
Posted 2007-02-21 10:02 AM (#55966)
Subject: Removing Decals from Trailer
Hi - New here, and new to owning a GN after years of hauling a BP. I've been learning a wealth of information from this forum, and am especially interested in ideas for finishing a LQ. But my initial question is - what is the best way to remove decals/stickers from painted steel ('05 Titan Classic 3H)? I was able to remove a small one with Goo-Gone and fingernails, but that's far from efficient. Plus, I now have no fingernails left. The trailer has an 18"x10" feed co. logo decal and a bunch of trailer dealer lettering I can live without.Thanks,Cat
Edited by CatB 2007-02-21 10:05 AM
Posted 2007-02-21 10:18 AM (#55968 - in reply to #55966)
Subject: RE: Removing Decals from Trailer
I was able to remove a 5 x 8 inch decal with the very careful application of a propane torch.  Once I got the separation started, a little heat to the line of adhesive made it let go.  Then a rag and solvent got rid of the stickiness.  If the metal starts to get warm, stop and let it cool before continuing.  This will save the paint.  Be aware, the paint under the decal will have faded less than the surrounding paint.  You WILL have the ghost image of the lettering and decal.
CatB
Reg. Feb 2007
Posted 2007-02-21 10:24 AM (#55970 - in reply to #55966)
Hmmmm, I'm not real good with a propane torch, would a hot blowdryer work? The trailer's white and there was no shadowing from the smaller decal, so maybe I'll luck out?
rick
Posted 2007-02-21 10:31 AM (#55972 - in reply to #55966)
Yah, I would try the blow dryer before the torch, may take a while longer but shouldn't bubble paint like a torch could. I have had good luck doing it on some stickers before. Start with one corner and warm as you pull away. Just a suggestion if ya put on stickers always put on a glass surface, much easier to remove years done the road.
CatB
Reg. Feb 2007
Posted 2007-02-21 10:34 AM (#55973 - in reply to #55966)
and at least with glass you can use a razor blade and save you fingernails. ;-)
kmh
Posted 2007-02-21 11:14 AM (#55978 - in reply to #55973)
Yes the blow-dryer will work. I am in the process of removing a lot of decals from a trailer I just purchased. Leave the blow-dryer as long as you can on the decal so that the glue will stay on the lettering. What glue that is left on will come off with Glue be gone, you can get that at any Walmart. As far as the ghost letter left behind, I bought a gallon of Streak Master (off of the internet) and it gets all of that off and takes the black streaks off of the white skin. It is a lot of work, but you will love the results. Have fun.
Edited by kmh 2007-02-21 11:15 AM
CatB
Reg. Feb 2007
Posted 2007-02-21 11:35 AM (#55982 - in reply to #55966)
kmh - Thanks for the advice and the suggestion on the Streak Master. I don't like the cluttered look and can't wait to remove the stuff. Just hope my blowdryer doesn't overheat!
maccwall
Reg. May 2004
Posted 2007-02-21 11:54 AM (#55984 - in reply to #55982)
500
Something that's cheaper and works just as good as Goo gone or what ever is a can of WD-40 or the Walmart brand. Won't hurt the paint and eats glue like candy. Works awesome for bugs and tar as well. I use it on my trailer and my truck.
kmh
Posted 2007-02-21 12:00 PM (#55985 - in reply to #55984)
Originally written by maccwall on 2007-02-21 11:54 AM
I didn't know that...thanks.
terri s
Posted 2007-02-21 3:05 PM (#55997 - in reply to #55966)
500100100100
YOu might also check with a local body shop. I believe they used mineral spirits to remove ours, but do NOT try this without checking first!
Cloud9
Posted 2007-02-21 4:11 PM (#56004 - in reply to #55966)
100100100
WD-40! Add removing decals to the 1001 other uses for the stuff.
Spooler
Reg. Aug 2006
Posted 2007-02-21 6:16 PM (#56014 - in reply to #55966)
50025
I would wait until summer before getting too carried away.  Stick that trailer out in direct sunlight and 90 deg. weather the stickers will come off very easy. Nothing better than good old sun power. I have 2 decals to put on my trailer and I am waiting for it to get up to 80 deg. before installing them. A little dish washing liquid in a squirt bottle with water and I'll make short work of those rascals. But it has to be hot outside or they will not cure properly.  I know they are probably ugly as can be but I would wait a few more months to tackle that project.
hurley454
Posted 2007-02-21 7:52 PM (#56018 - in reply to #55966)
Use a automotive heat gun. It has various setting and works well.
huntseat
Posted 2007-02-22 1:06 AM (#56033 - in reply to #55966)
1000500100100100100252525
WD-40 will harm the paint finish, in about 5 years you'll cuss yourself for using it.  I learned the hard way with my old stock trailer...(not to mention my BS is in Chemistry.)
If you use it you must wash it ASAP with a good soap and then wax it!
You might try some water softener in water and spray on the decal edges.  The softener should help to break the adhesives down, or rather hydrate them.  If the hair dryer doesn't work you can rent a heat gun, try your paint store.
Good luck, now you know why they didn't take them off!
CRK
Posted 2007-02-23 10:24 AM (#56119 - in reply to #56033)
We use a drill attachment called Big Eraser. It is a 3M product. It will not harm the paint and you can get one at any automotive store that sells auto paint, NAPA, Carquest, Big A (if their still around). Even a body shop may be able to help you out.
We use it on steel and aluminum trailers. Just let the wheel do the work and do not apply any more pressure than to hold it in place and remove the sticker. We use it all the time.
