   Location: Cheshire England | I was looking at buying a salvage 2005 f250 ps superduty it needs front end parts hood, fender,rad condenser and other parts anyone know if there was many changes year to year to look out for when im shoping for used parts??? thank you...
Edited by perfect11s 2007-02-13 3:57 PM
   Location: Tipton, IN | 2004 to 2006 should be interchangeable body parts. |
  Location: White Lake, MI | There was a minor change in the front end for 2005-2007. The front bumper, grill, headlights and (I think) radiator support are different from 2004 and earlier. Also, 4x4 front suspension changed from leaf to coil springs in 2005. I believe the hood and fenders are the same. |
         Location: South Central OK | Seeing as your located in England, you really may need to settle with what you can get your hands on! |
        Location: Vermont | Make sure the frame isn't bent...or your cost of repair will rise appreciably... |
   Location: Cheshire England | Hey thanks for the info its very helpfull Im going to look at the truck see how bad it is , |
   Location: Cheshire England | Well been to look and its a lot worse than it looks in the pics!! the frame is bad and has kinks as far back as the B pillar the wheel is back about 4 inches cab mounts shered off.. its a mess , real glad i didnt buy off the pics , Hey thanks again... |
