120 Volts through trailer door? :-)
racesarabhorses
Reg. Oct 2005
Posted 2007-02-01 6:43 PM (#54853)
Subject: 120 Volts through trailer door? :-)
I thought my wife was just reacting to the screen door's cold temperature this afternoon when she claimed it was shocking her as she touched it.  I touched it and didn't get much of a buzz if any.
We've had rain here all day, so the ground is very wet.  I have the trailer plugged into a grounded outlet, but the extension cord is not grounded.
I measured the voltage from the trailer skin directly to the ground with a voltmeter... yup... 110 volts AC, clean.  Wonder what would happen if we were barefoot and touched the trailer... :-)
Is this normal?  Would using a grounded extension cord between outlet and trailer help?  Is there a problem with my trailer's wiring?  The wiring is pretty simple--extension cord from outlet plugs into box in side of trailer, which connects 2 outlets inside the trailer and the A/C unit.
Help is appreciated.
Mike
soundhorse
Reg. Aug 2006
Posted 2007-02-01 7:12 PM (#54855 - in reply to #54853)
Subject: RE: 120 Volts through trailer door? :-)
Never use an extension cord that does not have the ground, plug your cord to a GFI plug if possible.  If you plug into a GFI circuit and the plug trips, check your cord and the wiring in your trailer
Tx. Vaquero
Reg. Jun 2006
Posted 2007-02-01 7:22 PM (#54857 - in reply to #54853)
You have a short somehwere in your trailer. Using a grounded cord is not going to solve it. You better get it checked by somebody that knows what they are doing or be prepared to have an Afro doo, or worse. No BS, this is dangerous.
Spooler
Reg. Aug 2006
Posted 2007-02-01 7:36 PM (#54858 - in reply to #54853)
50025
Yeap, seen that before.  You have a wiring issue. Hard to tell what it is from here because I can't see it. I would unplug it before someone gets hurt and have someone check it out. You can try to track it back with your meter.
Posted 2007-02-01 7:52 PM (#54859 - in reply to #54853)
RAH ... A timely posting.
Mr Truck has published my article that explains your problem and a likely cause.
(Please take this as a shameless plug for his site and my article...)
Click here >>  http://www.mrtrailer.com/hosspuller.htm
Posted 2007-02-01 9:03 PM (#54863 - in reply to #54853)
RAH ....
Another thought.  besides the obvious wiring short,  You might have a reversed connection along with the bonded neutral wire.  That would charge the trailer too.
Spooler
Reg. Aug 2006
Posted 2007-02-02 8:54 AM (#54891 - in reply to #54853)
50025
Grounding Loop.... That is very very possible.  Most Electrical boxes don't have the screw in to bond the Neutral to the Ground but some do.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-02 4:30 PM (#54929 - in reply to #54853)
Thanks, EVERYONE, for your replies.  This could be a very serious problem.  I'll try a proper extension cord first, then some other outlets/generator and see if that does not solve the problem.
If that doesn't do the trick, then we're off to Silver Star soon anyway.  I'll post back what we find.  My hunch is that there are wiring issues from the barn, anyway.  We rent a house, barn, and 10 acres... I'm finding that the whole house and other buildings here on the grounds have not been wired the way they should have been.
Thank you,
Mike
Tx. Vaquero
Reg. Jun 2006
Posted 2007-02-02 4:35 PM (#54931 - in reply to #54853)
if you are going to use the process of elimination method of trouble shooting instead of getting it checked out by somebody that knows what they are doing, I would suggest you continue to let your wife open the door
racesarabhorses
Reg. Oct 2005
Posted 2007-02-02 7:23 PM (#54946 - in reply to #54853)
Okay... so I missed going to my endurance horse race this weekend due to some computer issues at work that needed my attention.  Air Force... Service Before Self, HUA!?!?
With all the free time I had after arriving home this evening, I checked into the electrical issue a bit further...
On GENERATOR power, grounded extension cord or not, I get 20 volts from the trailer to the ground.
On A/C power from the barn, I get a full 110 volts from the trailer to the ground WITH a grounded extension cord.
So it looks like the problem is with the barn's electrical wiring and likely lack of a proper ground.  I'll be talking to an electrician...
One question remains: is the 20 volts shown on generator power significant?
Thank you,
Mike
racesarabhorses
Reg. Oct 2005
Posted 2007-02-02 7:27 PM (#54947 - in reply to #54931)
Originally written by Tx. Vaquero on 2007-02-02 4:35 PM
That brought MANY chuckles.  After having to cancel on a race I'd hoped to be heading to today due to work commitments, thanks for making my day.
Edited by racesarabhorses 2007-02-02 7:28 PM
Posted 2007-02-03 10:02 AM (#54976 - in reply to #54946)
Originally written by racesarabhorses on 2007-02-02 6:23 PM
The barn's wiring might not be the problem.  Your trailer's short may not be leaking enough power to trip the breaker.  It'll take MORE than 15-20 amps to trip the breaker with a grounded ext cord.  That kind of power would light your wife's eyes with more than love for you.  The tingle you feel is only several milliamps.  Not even a tenth of an amp.
If your generator is self contained, and you're still measuring 20 volts to ground (which ground?) it's only because of the resistance of the trailer tires.  You have a wiring problem.  Your wife has you. Both are deadly serious problems.  LOL
Edited by hosspuller 2007-02-03 10:08 AM
Tx. Vaquero
Reg. Jun 2006
Posted 2007-02-03 11:21 AM (#54981 - in reply to #54853)
I had a short in the trailer before last. Apparently it started with the insulation on a wire being skinned a little during installation of the LQ. With the constant vibration it got worse with time. I had noticed a little tingle when I opened the doors, but never gave it much thought until I rode my horse up, dropped the reins and unsaddled. Before I put the halter on him he rubbed his nose on the side of the trailer and it damned near knocked him to his knees. Luckily he wasn't tied or it would have been a wreck. I always had rubber soled boots on so I guess I wasn't getting the full effect, but with wet ground and his shoes, he got it. I got it fixed pronto, but I always thought how lucky it was that some little kid walking by didn't touch the trailer. Scared the hell out of me and my horse. It is not anything to take lightly.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-03 11:24 AM (#54982 - in reply to #54976)
Hosspuller,
The voltage was measured the same way when the trailer was run from the barn and when the trailer was run from the generator.  Tires should be out of the loop here because I measured voltage from the metal trailer door through the voltmeter directly to the ground (dirt, earth, etc.)  Voltmeter probes were touching the trailer and dirt directly.  If tires were in the loop for the genset, then they'd still have been in the loop for the A/C from the barn.
My explanation ^^^^^ makes sense to me... so either I didn't explain adequately in my first post OR I'm seriously not understanding what's going on...  :-)
Posted 2007-02-03 1:41 PM (#54988 - in reply to #54982)
Originally written by racesarabhorses on 2007-02-03 10:24 AM
Hosspuller,
I'll bet you a dollar to a Doughnut... that if you measure from trailer to the frame of the genset you'll get 110 volts.  The genset is only sitting on the ground.  A driven ground rod for the genset will truly ground the genset, completing the low resistance circuit.  In this case, it's the high resistance between the genset and the ground that is dropping the 110 volts to 20 volts.
It is not the barn wiring ... it is your trailer.
Edited by hosspuller 2007-02-03 1:47 PM
Posted 2007-02-03 2:44 PM (#54991 - in reply to #54853)
racesarabhorses, Was everything working OK before you started insulating the dressing room? I remember you saying something about some wires pulling loose while you were working around the top rail............Put them back together and fastening them down? Reckon you got a screw through a hot wire and making ground? Got something backwards so the trailer frame and - wires are hot and your + side is now the - ? Just trying to make you think back to when you first started this project, then walk your way back to where you are now. Did you cut or drill something along the way and say to yourself, "man, I hope that didn't get into any of the wiring, naw, it will be OK".........Anything along that line?
racesarabhorses
Reg. Oct 2005
Posted 2007-02-03 6:22 PM (#55009 - in reply to #54991)
Hosspuller, your is a plausible explanation.  I'll try to research it further tomorrow.
Retento... no screws anywhere.  This is something that may have been preexisting from before the insulation project.  I did replace the electrical box awhile back because the unit that came from the factory was messed up--should never have been put on the trailer to begin with, as the connector prongs were broken and moved into the box whenever a cord was connected, resulting in no connection.  I'll pull the box tomorrow and have a look.
Thanks,
Mike
Posted 2007-02-03 10:26 PM (#55018 - in reply to #55009)
Originally written by racesarabhorses on 2007-02-03 5:22 PM
Another wager... The cord you're using has a faulty ground or the trailer's inlet has a faulty ground. (The inlet's ground prong should be connected to the frame of the trailer)
If both of these parts had a working ground, either the genset or barn outlet should have grounded the current you measured.
spinnin and grinnin
Posted 2007-02-04 2:24 PM (#55047 - in reply to #54853)
Another thing to consider before you get the electrical issue fixed is to not tie a horse to the outside of the trailer, especially with a chain...or if he/she has shoes on. Some friends nearly electrocuted their horse due to an issue like this. Knocked the horse down and luckily he survived the ordeal.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-04 4:10 PM (#55048 - in reply to #54853)
Subject: RE: 120 Volts through trailer door?--AN UPDATE
Okay, I got a few minutes to take a closer look at the trailer today. BIG PROBLEM!  When I rewired the inlet, I copied how it was done from the factory without realizing that there was never a ground done!  More than likely, put it on my list of "things to check with the dealer" and got busy/forgot.
There are some pictures at the links below.  What do I need to do to fix the problem?
You will see that the green wires (I assume they're ground) run from the connector at the bottom of the plug (flipped upside down in the picture) to the air conditioner wiring (goes into the box, then up the trailer wall).  There is no connection from the green screw on the inlet to anything.  Does it need to be connected to the plug/receptacle where the other green wires are connected?  Does it connect somehow to the trailer skin?
Help please... thanks to all for their thoughts.  I don't know how this slipped past me when I rewired the trailer box upon installing the new black connector, but can assure you the connection was never done from the factory, either.
http://www.horsetrailerworld.com/forum/photos/show-album.asp?albumid=77&currentpos=7
http://www.horsetrailerworld.com/forum/photos/show-album.asp?albumid=77&currentpos=8
Thank you,
Mike
Edited by racesarabhorses 2007-02-04 4:16 PM
BigT
Posted 2007-02-04 6:22 PM (#55051 - in reply to #54853)
Is the outlet shown in the picture fused or CB? It looks like it is direct wired from the inlet.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-04 6:49 PM (#55053 - in reply to #54853)
The outlet is a GFCI, directly wired.   I've often wondered if this is safe... came this way from Silver Star.
Edited by racesarabhorses 2007-02-04 6:50 PM
efaubert1
Posted 2007-02-04 7:00 PM (#55054 - in reply to #54853)
50010025
Listen to hosspuller, he is an electrician afterall. And the way you are wired right now, you have no trailer ground from the frame. If in fact your green wire is ground, you need to run a ground wire up to your main box, then install a ground block, attach the ground from you main connector as well as your receptacles to the grounding block so ALL your outlets are grounded. If I am misstating something here please jump in hosspuller.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-04 8:27 PM (#55058 - in reply to #55054)
Do you by chance have a part number for such a device?  Where can I get one?
Thank you,
Mike
Posted 2007-02-04 8:52 PM (#55059 - in reply to #55048)
Hello RAH ....
You've found part of your problem.  The ground wire is not connected.  While anything plugged into your GFCI is protected, the whole trailer is left unprotected. (as you found out)
For a start.  Connect the green wires to the grounding terminal of the inlet.  Run another green wire to the frame of the trailer.  All the green wires (ground) should be only connected to other green wires and to the trailer frame.
Can't tell from your photo's... the white wire should be connected to the white terminal of the inlet.  These are your neutral wires.  No where should they interconnect to the green wire.  (As my article stated, this is proper for a house service entrance but your trailer isn't a house electrically)
This could be the other part of your problem if the inlet connections are interchanged.  White wires to white terminal... Black wires to brass colored terminal.
A way to test this is, with all the internal trailer wires removed from the inlet + inlet plugged to extension cord:
1)measure between the white wire and ground... should be zero volts
2) measure between black wire and ground...should be 110 volts.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-04 9:21 PM (#55061 - in reply to #55059)
Hosspuller,
Thank you for your reply.  In the picture, it looks like the black wires are connected to where you say the white (yellow, actually) wires should be connected (I assume the silver screw on righthand side is what you're terming as the "white terminal of the inlet.")  As you can see, the white (yellow) wires are connected to a screw that is coated with rust.
I assume the rusted terminal is the brass terminal is the one with all the rust on it.  The black wires appear to be connected by stainless steel hardware.  Switch them to the place where the white/yellow wires are now?
Thanks again,
Mike
Posted 2007-02-04 9:33 PM (#55063 - in reply to #55061)
Originally written by racesarabhorses on 2007-02-04 8:21 PM
Hosspuller,
 Thanks again,
Mike
Mike ... Sounds like the screws aren't original.  Don't try to go by the color code anymore.  It assumes they are in the right place, and you know where that is going to lead you.  (Although, if it is reversed, it would be charging the trailer frame.  The a/c unit could be a source of your leakage.
Check and measure.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-04 9:48 PM (#55064 - in reply to #55063)
Good advice.  Now here's a thought (I'll still do your tests as described earlier)...  I did some research and found that in a household outlet, the bigger slot on the left side is the neutral slot, the one on the right is the hot one.  The ground is, of course, centered below the two.
If you notice, the green ground screw is at the top of the inlet.  Let's picture the wiring as it leaves the outlet from the barn/generator.  Big slot on left side, littler one on right, ground below.  Now when the extension cord reaches the inlet, we're reversed 180 degrees on the outside of the trailer (ground is top, so neutral slot is on right side and hot is on left side).  Well, if we wire things the "traditional way" inside the trailer to the inside electrical outlet, with this 180 degree rotation at the inlet outside the trailer, then my black wire in the picture is actually electrically neutral.  The yellow wire is hot.  SO... the trailer is most likely reverse-wired.
Again, I'll doublecheck with your test, but I think I've figured this one out.
A couple of grounding questions.  The green wire appears to run up to the A/C...  I don't know how A/C systems are installed, but do they typically have ground/hot/neutral wires?  Short of removing the ceiling, I want to take an educated guess as to where this green wire ends up.  I assume it is NOT screwed into the trailer frame somewhere else, but runs to the A/C.
Also... how can I connect the inlet ground to the frame, short of running a wire out of the box and connecting it to a hole I drill in the frame?  I'll look for other options within the box's mounting hardware... maybe that will reveal some options short of this...  Seems odd that Silver Star would leave this wire unconnected from the factory...
Thank you,
Mike
Edited by racesarabhorses 2007-02-04 10:39 PM
Posted 2007-02-05 6:01 AM (#55070 - in reply to #55064)
Originally written by racesarabhorses on 2007-02-04 8:48 PM
Mike ... The a/c unit will have ground/hot/neutral wires.
For grounding: The best practice is to take a wire to a hole drilled into the frame.  Grind the paint off and dab a bit of anti-oxidant between the bare metal connectors. Steel rusts and aluminum oxidizes.. This is a safety point so you don't want it to fail.  AND you won't know it's failed until you need it.
Look at all the posts on this forum about trailer running lights, brakes, turn signals, etc.  Most are problems based on a poor electrical ground.  These are only the 12 volt connectio.  You might reconsider the quality of the ground connection your life is depending on instead of a short cut.
Edited by hosspuller 2007-02-05 4:55 PM
maccwall
Reg. May 2004
Posted 2007-02-05 1:24 PM (#55093 - in reply to #55070)
500
Mike, I don't this the wrong way, but thanks for having this problem, posting it on this forum, explaing what's going on and making people aware. And hosspuller, your article is going to the front of the electrical page on my site since many people do look at it.
Everyone doing their own trailer should read this article and this post not once, not twice, but three times though and though. I did alot of research when I was doing the electrical in my trailer and I have since put GFCI breakers in it, but my ex-neighbor (I've since moved so we are not neighbors anymore) who is an electrical engineer, told me that I should connect my box like hosspuller is telling you not to do in his article, which was to bond the Neutral and ground. I told him that's not the way to do a trailer and I connected the all grounds together, neutrals together and hots together with the grounds connected directly to the trailer metal itself and the neutrals on a seperate terminal buss in my breaker box. I have not had a problem and hopefully never will. I just hope people take the time to do it correctly as electricity will KILL YOU and YOUR HORSES.
Mike, I'm sorry you missed your ride this past weekend but it was definatley for a reason and I think that reason is obvious now.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-05 5:55 PM (#55105 - in reply to #55093)
Very true!!!  Who knows what would have happened!?!?  I don't get how such a connection could have been overlooked.
I rewired things as I said I would and did some tests.  Everything is ops normal now.  No more voltage leaking through the trailer frame to the ground.  Much better.
This weekend, I am going to buy NEW wiring and a new inlet and re-do this entire circuit with wiring I believe is trustworthy.  Not happy with the workmanship the trailer came with.
I suppose my best option is to run a wire out of the box, drill a small hole in the frame, and use that as my main ground attachment for now.  I'm not familiar with the grounding bus or how to install one.  I assume this would be done by connecting a grounding strap to the frame from the box, then connecting all other grounds internally to the box (the bus would be tied to the frame via the grounding strap.)  I'll see if I can find a grounding box at Lowe's.
Thank you ALL...  Feel much safer now... glad I'm not without my horses or MY WIFE who just happens to be 3 months pregnant with our 2nd child!!
Edited by racesarabhorses 2007-02-05 5:57 PM
