I have a Kingston Windsor, 2H BP straight load no DR which is a Vnose. I usually haul one horse to shows. 1. Do you all have a recommendation on storing gear such as trunks, tack, etc in this area? How do you keep it secure? 2. Have you ever used one of those water containers (18G), and does it work well in this area vs. a dressing room. 3. Where can I find the vinyl hay feeders that are square instead of corner feeders? It may keep the hay waste and mess to a minimum. I'm trying to use the most of this small space, so any suggestions/words of wisdom are appreciated. |
