    Location: Dickinson, TX | The carpet on my trailer is glued in VERY well. How can I remove it? So many questions... thanks again. Mike |
 Location: Bridgeport,wv and Gaffney,sc | I am also redoneing a horse trailer, i cut the carpet in a place and starting pulling it up. |
 Location: Lone Oak, Tx | Mine was fairly easy to get up, but I did have to use a large trowel like what they use for doing drywall, to scrape it up. If it's very hard to get up, and you might not want to do this, you can try spraying WD-40 as your scraping to make it easier. the WD-40 will soften the glue. Smell can get to you though.
    Location: Dickinson, TX | No problem whatsoever with WD-40. Thank you for the tip. Mike |
