suggestions on bumper pull trailers
endurance rider
Reg. Dec 2006
Posted 2006-12-08 8:25 AM (#52318)
Subject: suggestions on bumper pull trailers
Good Morning:  Looking for some advice.  I am looking to buy a new/used bumper pull trailer.  I am leaning toward aluminum over steel.  I would like a 2 horse slant with rear tack, removable wall between dressing(or door) for access to dressing room.  I plan to use the horse area for camping while at rides. I would like to be able to open up the entire area for a modified living quarters.  Not fancy, but doable. :)
I would like to stay below $10,000.
I will be pulling with a Suburban.
Any suggestions would be greatly appeciated.
rider3
Reg. Sep 2006
Posted 2006-12-08 8:40 AM (#52319 - in reply to #52318)
Subject: RE: suggestions on bumper pull trailers
Shadow makes something like what you are looking for with the removable wall.  If your horses are large though, the stalls may not be big enough.  Good luck!
jillian
Reg. Aug 2005
Posted 2006-12-12 6:44 PM (#52469 - in reply to #52318)
I bought a Shadow 3HBP w/DR last year to pull behind my F250.  It weighs around 2700 and pulls well so far. I don't know alot about trailers, but I am learning some expensive lessons. My horse used to hate the new 2 horse slant steel I had bought him and was constantly refusing to load.  He loads easily in his Shadow slant load and I like it as well.  The slam latches are really quick and easy.  He is a 14.2 hand horse, I am not sure that a much larger horse would fit comfortably.  If you are not very tall, you may want to get a pull out step installed under the drop windows.
