| Hello i have a 2000 sooner the load lights and horse stall lights quit working all other lights are ok?does anyone know what lights they work off? thanks |
        Location: North Carolina | They draw power from your truck's aux circuit. Check your truck's fuses and the connector. |
| Thanks I call myself looking at all fuses that were related to the trailer? i thought they would work off say like tail lights and the switch just broke the wire to turn them off and on thanks again got to go get out the trusty icepick tester Gus |
| Hay Hoss checked everything could not find anything not hot unpluged pluged back up and they work simple things scould be checked first |
        Location: NY | Your trailer plug may need a little sanding sometime rust gets in there and mess with the pluges |
       Location: Hagerstown, MD | Clean your trailer plug on the male/female sides. Make sure all the pins are in good working order, no corrosion, not bent, not missing. Put a little Vasaline on the plugs and pins to protect and lubricate them. Happy trails. |
| Thanks for the good things on cleaning.Now my wife said the lights worked last weekend with out the truck lights being on we just got the trailer so i do not know this for a fact but i know they now only work when the truck lights or on? i have not changed anything? |
Location: Norfolk, Nebraska | On a new Ford the hot lead will not come enless the truck is running. |
