what can my truck handle?
stanger92
Reg. Sep 2006
Posted 2006-09-23 5:13 PM (#49005)
Subject: what can my truck handle?
I have a 2006 3/4 HD GMC with the duramax and right now I am pulling a 4 horse slant exiss w/ unfinished 4ft quarters.  looking to buy a trailer with larger finished lq's.  how big could I go without buying a dually?  I don't like them at all, but if absolutely necessary I will buy one.  If I could get by with my truck I would be much happier.  Won't be doing any cross country or anything, just weekend runs and at the most 8 hour drive a couple times a year.  Usually within 100 miles of home.
also was thinking about a 6" suspension lift for my truck.  Would this effect the pulling too much?
Rik
Posted 2006-09-23 6:00 PM (#49006 - in reply to #49005)
Subject: RE: what can my truck handle?
The best thing I can suggest is to pick up a towing guide from your local dealership. This will have the towing specs for your vehicle. You should also have a sticker on the vehicle with its GVWR and front and rear GAWRs. As for the lift kit, if you plan to put on bigger tires, they will effectively lower your final drive ratio.
rose
Posted 2006-09-24 7:58 PM (#49054 - in reply to #49005)
10005001002525
Should be able to pull an 8' short wall lq with 3 horses, without any problem.
Posted 2006-09-24 8:29 PM (#49059 - in reply to #49005)
Originally written by stanger92 on 2006-09-23 4:13 PM
Hello Stanger... Welcome to the forum.
The 6" lift will be detrimental to towing.  You either lose truck/trailer clearance or you overload the trailer's rear axle.
The rest of your question is simple.  Do not exceed the GCVWR  or rear axle ratings of your truck.  Those two pieces of hard information are worth more than a hundred opinions of "It'll handle it" from internet haulers or parking lot cowboys
rose
Posted 2006-09-25 7:51 AM (#49078 - in reply to #49005)
10005001002525
ditto
