 Location: Ottawa, ON | Fall is rapidly approaching. The good news is there are 8-10 weeks of no bugs, cooler weather, and great riding to look forward to. It is also time to think about having my new steel trailer rustproofed or oil sprayed. The local trailer place that does it will not start doing the work for a few weeks, but I should probably book a time soon. Is there anything I should look for in a rustproofing job? Any questions I should ask? Do they just spray the non-galvanized metal parts underneath, or is there more to it? Should they be spraying into all the drainage holes in the tubing? Should they drill more to spray into? Any comments will be appreciated. Chris
Edited by 10Ha.Wood 2006-08-22 9:12 PM
   Location: La Crosse, WI - God's Country | Spray it with OIL? Really? I'd rhino line/line x it ad never worry about it again... Anything softer is still going to be compromised eventually, isn't it? What do other folks have to say about this? LAXPatrick |
 Location: Ottawa, ON | I'm talking about the bottom of the trailer, the frame, the insides of the hollow structural tubing, etc. I've never heard of anyone using Line-x in this type of application. I called the trailer place that does the rustproofing. They use a product similar to Krown or Rustcheck. They will spray everything that is exposed, and into any existing drain holes, but they will not drill new holes. I'm thinking I should remove the interior Rumber liners so that they can spray behind them as well. Any thoughts or suggestions? |
  Location: Canada | My father-in-law owns a Rustcheck franchise; subsequently every vehicle in my family is rustchecked to death!! LOL
We get our trailer Rustchecked too. They usually do the hinges, any tight corners/little areas that moisture can be trapped and cause corrosion, and of course most importantly the underside - supports, everything else. Well worth the money in my opinion. FIL also owns a body shop business and claims that the cars that are rustchecked always show less corrosion over time than those that have not (fully realize here that this could be his sales pitch ;)).
Rhino liner will NOT do the same job as rustcheck. Totally different products. My husband says he would not bother removing the rumber liners (you mean the ones that line the walls, right?) Rust Check and similar products are very good at working their way into corners and crevices. If they apply it correctly, it will work it's way under anything...but they may tell you differently, don't take my word for it. I DO know that the product "drips" a little bit for a couple of days afterward - don't park it on your new interlocking driveway :)
Edited by Gaelic 2006-08-24 10:16 AM
 Location: Ottawa, ON | Originally written by Gaelic on 2006-08-24 11:13 AM
My father-in-law owns a Rustcheck franchise; subsequently every vehicle in my family is rustchecked to death!! LOL Lucky you! I'm somewhat wary of paying to have this work done, as you really have to trust the applicator to do a complete and detailed job. I had my new truck done last summer and found large areas that were obviously missed. It makes me wonder about the details that I can't see.As doing the trailer is a simpler job I may try and tackle it myself. Either that or pay to have it done and then buy an aerosol can or two and make sure that all the details are looked after. Doing the whole job with spray bombs would probably be pricey though, and having the job done will only cost $59. |
