Location: AR | I am sure this has been discussed many times before, however I am having some trouble. I just purchased a 2001 F-350 with a towing package. When I hook up to my elite trailer the outside lights work but the inside lights do not. All the fuses are fine, but no interior lights?? Anybody have any suggestions??? |
    Location: THE GREAT NORTHWET, OREGON(THE REAL GODS COUNTRY) | CHECK THE CONNECTIONS SOME TRUCKS KEY MUST BE ON TO WORK TRAILER LAMPS,SOME HOOCKED TO LIGHTS.ALSO CHECK GROUND GOOD.I THINK THESE ARE LABELED RIGHT IF NOT REVERSE THEM.SEE ATTACHMENT FOR COLORS AND WHAT THEY OPERATE. ![[7 way connector]](file:///C:/WINDOWS/Desktop/BUS%20FOLDER/plugs7way_files/7wayte.gif)
TRAILER END ![[7 way connector]](file:///C:/WINDOWS/Desktop/BUS%20FOLDER/plugs7way_files/7wayce.gif)
VEHICLE END
Edited by SLICKRNSNOT 2006-07-21 2:53 PM
    Location: THE GREAT NORTHWET, OREGON(THE REAL GODS COUNTRY) | ALSO MAKE SURE THERE ARE BULBS IN THE SOCKETS AND SWITCHES ARE OK. |
      Location: Nebraska | check voltage at center terminal if no voltage check under the hood ,beside the maxi fuse box there is two relay boxes, The box closest to the firewall is the one you open. The relay box holds two relays, fix up a jumper wire for the front relay, jumper goes left side to right side, check voltage at the center terminal. |
   Location: Kansas City | On my CM steel Dakota 3H slant, the interior lights were wired separately to the aux hot wire from the truck (which I had to add on my truck) so you could use the interior/exterior dome lights without having the park/marker lights on.
