Steel Trailer Lining?
grayland
Posted 2006-06-10 10:20 AM (#42820)
Subject: Steel Trailer Lining?
I want to pull the plywood lining out of my steel trailer and replace it with something that will protect the inside of the walls but not hold or absorb water.  I got some samples from Rumber last year and they sent a sample of a product that was 3/8" thick and came in 4 x 8 sheets, but none of their listed dealers carry it, plus it sounds like the thinner stuff they do carry is pretty pricey ($95/sheet - ouch).  Any other ideas out there?  Thanks
Reg
Posted 2006-06-10 9:13 PM (#42847 - in reply to #42820)
Subject: RE: Steel Trailer Lining?
2000500100252525
Originally written by grayland on 2006-06-10 10:20 AM
Marine ply, but that is probably even more expensive.
How many sheets ?
Given the labor that you'll be putting in and how long it SHOULD last, does the cost of the material matter THAT much ?
grayland
Posted 2006-06-11 8:30 PM (#42875 - in reply to #42820)
Never gave marine plywood a thought.  Pressure treated is out, due to reaction with steel.  I've never had much experience with marine plywood.  Will check into it.  As far as cost, you're right - if it does the job, then it's worth the money - I just hate to spend anymore than I have to - I can always think of ways to spend my "extra" money - vet bills, farrier, horse dentist, etc., etc. :-).
Thanks for the suggestion!
