Location: South Carolina | does one buy brake pads for a trailer? Can I just go to the local auto store? | |
| Originally written by canrunnr on 2006-04-30 8:33 PM
Hi and Welcome to the Forum.
Yes, most NAPA outlets either have them or can get them overnight, so do RV and boat trailer places.
You didn't ask this part, but here's an extra tip;
If the brakes are more than a few years old the chances are good that there will be rust on a lot of the little springs and securing clips.
Many trailer places now carry whole assemblies, i.e. backing plate, shoes, magnet, bearing set.
This saves the problem of flying springs and clips that get found a week later by the lawn mower and you know that everything is NEW and correctly assembled (just in case you doubt your skills).
These are "a few bux" more than just the shoes and can be WELL worth it.
Edited by Reg 2006-04-30 7:51 PM
Location: South Carolina | Thank you so much. I've just bought the trailer and it is used. I'm just trying to figure out ways to save costs. Especially since the trailer place is an hour away. Another question for you.....do I just ask for trailer brake pads? Or assemblies? Or do I need to give them specifics? | |
 Location: Ashland, Ohio | Well, since you're an hour away, I would call first and describe what you have. If they think / say they have it, I would also take at least one assy. apart and take the parts with me. That way you can match up the parts. There's nothing worse than starting a project like that, only to find out you've got the wrong parts. And you've broken some of the springs / clips, And it's 9:00 friday evening with the "big" horse show tomorrow - early!!! At least that's my luck. | |
      Location: Texas | Most trailers have one of a few standard sizes of brakes. Measure the inside diameter of the drum and the width of the brake shoe. Ex: 10 x 2 1/4 or 12 x 2. | |
| Originally written by canrunnr on 2006-04-30 9:30 PM
NAPA, RV centers, marinas, etc will know NOTHING about the specifics that you don't tell them. A horse trailer dealership with a GOOD service department might be able to look it up by make, model, year, etc., although if your trailer is a brand they don't carry you might be out of luck.
As another reply suggested, take a drum off and measure it, also measure the shoe width and look for a manufacturer's mark, e.g. "Dexter".
SOME drums have a machining spec cast into them, e.g.
"Do not machine above 10.186 inches" something like that. Phone ahead and take the drum with you anyway.
re: saving money: If you have SOME lining left and the drum isn't too scored your minimum cost will be a set of shoes, you might be able to get a set of springs and clips for $10 or $15 and if there is a lot of rust you'll need them. One approach would be to buy everything for just 2 brakes and see what you need to actually use. You might not need all the parts on all the wheels, e.g. magnets don't wear evenly, rust seems to visit right hand side more than left side, rear axle brakes wear faster than front axle brakes, etc.
