Location: oh | I have just baught a used trailer it has brakes on both axles but their not wired up, how can i tell which wire is which, to wire them to a 7 way plug? |
  Location: North Texas | This is one place to start >>>> http://www.horsetrailerworld.com/home/wiring.asp Then get a circuit tester and go to work . . .
Edited by arroyoseccofarm 2006-04-01 10:01 PM
| Originally written by dovetail on 2006-04-01 9:24 PM
Hi and Welcome.
One wire from each magnet will go to ground, the other will join up with 3 similar ones from the other brake magnets and go back to the connector. The convention is to use a blue wire for this. There is a link on this site's home page, above the forums http://www.horsetrailerworld.com for the usual 7 pin layout. Be sure to also get the stop and tail lights correct.
Location: oh | ok thanks for your help i will try in the morning. |
