Location: Denton, Maryland | Hello again, I was wondering if I could get some help or advise on the brakes of my horse trailer? It has hydraulic brakes on it but they haven't worked in at least 10 years. We are now in the process of restoring/repairing the trailer and wondered what to do about the brakes. Can the hydraulics be fixed after all this time? Could they be converted to electric? Could we completely remove the hydro and put in all electric? Would it be easier to change the axles? Any Advice, Ideas, or Help that you can provide? Any thoughts would be appreciated! Thanks very much in advance, Willa |
    Location: Lockport, Illinois | You could take the hydraulic brakes off the trailer and replace them with electric brakes. You would have to buy the complete brake assembly, which includes brakes with backing plates, and the drum with bearings. If you don't have a brake control on the towing truck, one will have to be installed. Most states require a break away brake control. |
     Location: Albany, Oregon | I agree with BigT....If you take one of the brake assemblys off and take it to a good RV or any good trailer repair outfit they can tell you what you need to get (drum size and backing plate bolt pattern,and lug bolt pattern). Dexter axle on-line is a good place to look for specs on your own. Added....I was looking at your project on another post....Looks good!...
Edited by xyzer 2006-03-19 10:03 PM
    Location: PA | Hydraulic brakes are sooo good! Why would you want to put electric on? |
Location: Denton, Maryland | Originally written by hav2ride on 2006-03-20 8:38 AM
Hydraulic brakes are sooo good! Why would you want to put electric on? To be honest, I don't know anything about Hydro brakes except that the ones on this trailer have never worked and I have always tripped over the hydro box on the front when stepping over the front of the trailer. From my point of view basically cost is the first thing. Then work. We have to do this ourselves if at all possible to keep costs down. If the hydro brakes are repairable and it's the cheapest option that would work, then lets go! That's why I asked about options. I don't know what's doable and whats not. Willa |
Location: Denton, Maryland | Originally written by xyzer on 2006-03-19 10:48 PM Added....I was looking at your project on another post....Looks good!... Thank you! |
     Location: Albany, Oregon | You can rebuild the hydro brakes....Actualy they work well in normal braking conditions....They are alot safer than none. You would have to do some research and find out what master cylinder,brake cylinders they used and get rebuilt ones. A good brake shop or parts store might be able to tell you what the replacements are off of. It is possible... Some give you a problem if you try and back up a hill or over a bump it applies the brakes....No brakes in reverse... Some have a pin you can put in the accutator to deactivate them for backing. You can look at both angles....Does it have brakes on both axles? |
Location: Denton, Maryland | This is a message I got from a trailer place online: If the axels that are on the trailer now look like they are in good condition then you do not need to change them. I would not use the set up that you have if they have not been used in 10 years. If you do get rid of the setup that you have now, then you can have your choice of what brakes that you want, electric or hydraulics. |
Location: Denton, Maryland | Originally written by xyzer on 2006-03-20 11:49 AM You can rebuild the hydro brakes....Actualy they work well in normal braking conditions....They are alot safer than none. You would have to do some research and find out what master cylinder,brake cylinders they used and get rebuilt ones. A good brake shop or parts store might be able to tell you what the replacements are off of. It is possible... Some give you a problem if you try and back up a hill or over a bump it applies the brakes....No brakes in reverse... Some have a pin you can put in the accutator to deactivate them for backing. You can look at both angles....Does it have brakes on both axles? I assume its only on the one axle, the rear one. In the process of working on the floor these was a brake line (just one) that went down the center and split to both sides of the rear axle. The line actually snapped right off when we moved it, from being so old I guess. When we pull the wheels off to do the bearings (sometime this week) my husband will take a good look around down there and see whats what. Thanks! |
