 Location: Mobile, AL | Why does it seem so difficult to find an actual weight on a trailer, I would like to move up to a 4h lq and get the most useable area, but want to make sure I don't go over my limits. I have a Chevy 2500hd with D/A combo. Owners manual says trailer limit is 12000, which I tend to agree with, but I have also seen a limit of 15600 with the truck set up, and seems like a lot. A new truck is not an option, as this one was just paid off. I would like to get a 8ft sw and as much width as possible, anyone have any suggestions? | |
  Location: Casa Grande Arizona | First off I believe your truck is rated to 15000K+. Actually the limiting factor is not the manufacturer of your truck but the limit allowed by law which is 22K. I believe that your truck could pull more than the 15K. When you look back at the specs make sure you look at the 5th wheel/ gooseneck trailering section. It will tell you that you can pull a max of 22K including your trialer and truck when using a gooseneck. Now try this one for size (I'm sure that quite a few will freek but I don't see the problem). I'm getting a 16' sw 4H sundowner with a 12' slide. It has a dry weight of 11700# and I'm going to pull it with my 2004 2500HD duramax with the allison. I've put airbags in the back (which I may or may not need) and I'm putting the edge (a chip) and exhaust system in my truck. The only real question is can you stop it. I'll know more in a week or so but I don't see a problem. I went looking at toy haulers with my buddy today and they were all around the 11000# mark or higher. That was dry. If you added the fuel and water, ect. then it went up to the 13-14K range. How many times have you seen them going down the road? We have some serious hills in AZ and they go up and down them all the time with no problems in their 2500's and 3500's. I've got another buddy that has a 2500 dodge ram with a diesel. He has a 10' sw 3h. He puts 4 horses in it and a bunch of dogs and all his gear. It is loaded to the max and then some. He has had the trailer for quite awhile now and has blown every tire that you can on his trialer and truck. Sometimes more than one at a time. He said it can be exciting at times but he doesn't see the problem with just one set of back tires. Now keep in mind that he lives in his trailer on the road for about 8 months a year or so. I think trucks are like guns. Most people think they need WAY more than they really need but it makes them feel more comfortable. Later, Chad | |
       Location: Northern Utah | Like Chad said, Make sure you are looking at the Gooseneck and not the bumper pull weights. Your Duramax should be rated higher than 12,000. | |
    Location: PA | "Now try this one for size (I'm sure that quite a few will freek but I don't see the problem). I'm getting a 16' sw 4H sundowner with a 12' slide. It has a dry weight of 11700# and I'm going to pull it with my 2004 2500HD duramax with the allison. I've put airbags in the back (which I may or may not need) and I'm putting the edge (a chip) and exhaust system in my truck. The only real question is can you stop it. I'll know more in a week or so but I don't see a problem." You are joking, right???
Edited by hav2ride 2006-02-28 7:49 AM
  Location: Casa Grande Arizona | Nope. It's the truth. Later, Chad | |
Location: St.George, UT | That weight seems a little deflated unless it is there ALL-ALUMINUM series. Sundowner makes alot of alum on steel trailers and if this trailer is alum on steel it seems a bit low. If you are pushing your weight limits I would have the trailer scaled if you have plenty of wiggle room with your weight limits dont worry about it. | |
 Location: Oregon | 11,700 does not seem all that out of wack for that trailer. According to my 4H 8' SW Charmac (which is steel/alum) it has a weight of 5340. Charmac says add 250 pounds for each foot in the dressing room. So a 16' sw would be 7340 pounds. That would leave 4360 pounds for the 12' slider and LQ, which could be done. My concern would be his weight fully loaded. I can easily get 5000-7000 pounds with 4 horses and all my gear, hay, water, ect. That could put him at about 19k pulling weight. Would I do that with my truck? No way. But then again, I don't want to pull a 33'+ on the floor trailer either. I know that there are some people out there that wouldn't bat an eye at that. | |
 Location: Mobile, AL | It just seems to me that a lot of times a weight of a trailer is like a well guarded secret. The trailer I am looking at is a Featherlite 8547 4h 7'6" wide and tall, 8ft lq. It also has mangers. The weight I was told comes in at 9300, with 4 horses and gear should add up to 13800+/- a little. My trucks GCWR is 22000, so what does everyone think? Thanks,Jeff | |
  Location: Casa Grande Arizona | The gal that owns the trailer said it had a sticker on the front that said the weight was 7900#. When a buddy looked up the weight off of a trailer blue book the trailer was supposed to weigh 11700. The gross is 17K. I figure the worse case senerio is 11700. I also don't plan on putting 4 horses in the trailer. The funny part is I don't even own a horse yet. I'm planning on about 2 horses. Sooner or later I'll get a new truck anyways. Not sure when or how big. Time will tell that one. Later, Chad | |
 Location: desert hills, az | Ok, I asked this same question last week (LQ Size). I have a 2004 1/2 (LLY engine) HD2500 4WD, Duramax, Allison, Long bed extended cab, 3.73 rear end. I have looked at the manual over and over and can only find Maximum Trailer Weight of 12,000. CGVW of 22,000. There is no difference for Gooseneck listed that I can find. Can someone help me find it in the Manual if they find it? Thanks for the input! | |
| DURAMAX 6600 V8 WITH AUTOMATIC AND MANUAL TRANSMISSION |
| Model | Box Length (ft.) | Max. Trailer Weight (lbs.)1 | Required Axle Ratio | GCWR2,3 (lbs.) |
| 2500HD 2WD | Regular Cab | 8 | 15,900 | 3.73 | 22,000 |
| | Extended Cab | 6.5/8 | 15,700/15,500 | 3.73 | 22,000 |
| | Crew Cab | 6.5/8 | 15,400/15,100 | 3.73 | 22,000 |
| 2500HD 4x4 | Regular Cab | 8 | 15,600 | 3.73 | 22,000 |
| | Extended Cab | 6.5/8 | 15,400/14,800 | 3.73 | 22,000 |
| | Crew Cab | 6.5/8 | 14,200/13,200 | 3.73 | 22,000 |
| 3500 Single-Rear Wheel 2WD | Extended Cab | 8 | 15,300 | 3.73 | 22,000 |
| | Crew Cab | 8 | 15,100 | 3.73 | 22,000 |
| 3500 Single-Rear Wheel 4x4 | Regular Cab | 8 | 15,400 | 3.73 | 22,000 |
| | Extended Cab | 8 | 15,000 | 3.73 | 22,000 |
| | Crew Cab | 8 | 14,700 | 3.73 | 22,000 |
| 3500 Dual-Rear Wheel 2WD | Extended Cab | 8 | 15,1004 | 3.73 | 22,0004 |
| | Crew Cab | 8 | 14,9004 | 3.73 | 22,0004 |
| 3500 Dual-Rear Wheel 4x4 | Regular Cab | 8 | 15,2004 | 3.73 | 22,0004 |
| | Extended Cab | 8 | 14,8004 | 3.73 | 22,0004 |
| | Crew Cab | 8 | 14,5004 | 3.73 | 22,0004 |
  Location: Casa Grande Arizona | http://www.chevrolet.com/silverado/specifications/ Try this link. If it doesn't work then go to the chevy site. Look under the silverado, then options and standard, then specifications, then trailering. Then go all the way to the bottom and it will have a section for 5th wheel/gooseneck towing. I'm sure that the specs for the 2004 are very, very close to the 2006. Later, Chad | |
 Location: Mobile, AL | Thanks for the link Chad, that answers the truck part of the question, now if only more dealers would list the trailer weights it would make all of this much less confusing. I also found it interesting the regular cab 2500 has a higher tow capacity than all the rest. The standard bed also beat the long bed by 200 lbs.Jeff | |
  Location: Casa Grande Arizona | The reason that the smaller trucks are rated for more towing capacity is because they are lighter. The max gross weigh can be 22K. It isn't the max load your truck is capabale of towing. GM would rate the truck's towing ability higher if it was legal to do so. I'm with you on finding trailer weights. It is such a pain the in booty to find weights. They are missing the boat when it come to that. I realize that LQ's may have different weights but they could give an average or something. Later, Chad | |
 Location: desert hills, az | Chad, Thank you! I KNEW that trailer wieght would be higher for goosenecks, it only makes sense! As far as I know, my 2004 1/2 is the same frame and engine so those specs help a lot. Guess they just didn't want to put it in the manual. Now I can get a bigger trailer. Thanks again for the help. capt clank | |
| To the trailer weight question that started this;
I think that it is primarily the fact that trailer manufacturers don't have much idea of what the finished camper section will weight when finished.
Even so, I would think a weight per sq ft of finished camper space guideline could be developed. Even a list of component weights would help, sink, fridge, couch, bed, carpet per sq ft., a/c, etc. add 'em up.
FWIW my 30ft (on the floor) 4-Star weighs just about 5500 lbs empty and it is built kinda hefty. My Jamco 2 horse bumper pull is 2870, also a relatively hefty built trailer. Both are "all aluminum", 'cept for some of the underguts, gooseneck sub frame, axles and such.
 Location: Mobile, AL | This is just me thinking, but when a manufacterer makes a trailer, or a conversion company completes a trailer, the trailer would be weighed. That weight would be included on the delivery paperwork. That should be included on the paperwork to be transferred with the trailer (the title). It just makes sense, and would help keep people from being undertrucked. | |
| Originally written by jeffghs on 2006-03-03 2:45 PM
As I understand it that is the process for completing a truck.
You can buy the chassis/cab and have a body builder add a box cube, dump body, ambulance, whatever to it. I think the term is something like "final builder" or "vehicle completer", but part of what they're supposed to do is to weigh it and complete the paperwork for registration. I believe this is far more rigorous for trucks than for trailers.
I still think any reputable trailer manufacturer should be able to quote you an empty shell weight and any reputable camper installation shop should be able to estimate the weight of what you want to have put in it.
.jpg) Expert
      Location: Southern New Mexico | My trailer has the empty weight stamped on the vin plate. | |
| I am only assuming that the gal said that the weight was 7900# just thinking that the only weight number showing on the three trailers that I have is each axle weight is 7900 so that would mean the trailer is rated total of 15,800#. My trailer is weighing in at 13000lbs with the mules which 3000 is on the truck so oddly enough the trailer axles is 10000 lbs and the truck is also 10000lbs. I am o.k. on my ton truck limits but I run a half ton license plate so I went to the drivers license office and told them my problem that I was over 2000 lbs on my truck license but o.k. on my trailer so what they decide for me was stay with the half ton license which is a b-plate here in Illinois and put a R.V. plate on the trailer and no more worries with weights or stopping at scales. They will look at the trailer to see what is in your livingquarters, a week end package may not work.But if I get caught hauling any other type of trailer like a ftat bed hauling hay they can nail me. My dually has 200,000 miles on it now and has lived on a trailer and at 160,000 miles was my first set of brakes, but I do run an exhust brake and I do use it. If used correct I don't need to touch the brakes to stop that is if I know the road I am on. It works great in the mountains. | |
  Location: Zionsville, Indiana | Every Certificate of Origin that the manufacturer supplies with a new trailer (or truck or car) has, by law, the empty weight of the vehicle. When that C of O is turned into a title by the licensing authority, that empty weight is not noted on the title. There may be a few states that do carry the empty weight onto their titles, but I have oviously never had one of those titles. Therefore, a dealer knows what the new unit weighs, because they have the C of O, but a used unit would have to be physically weighed or guessed at. Also, a living quarters C of O has the weight of the trailer BEFORE the LQ was installed. In all the years we have been selling trailers, we have had just one used trailer come in that had the empty weight on it. It was a steel stock trailer built in Georgia, and the weight was on the VIN tag. I don't remember the brand name. There is a new federal law effective 9/1/05 that applies to trailers of all kinds manufactured after that date with a GVWR of 10,000# or less. There must be a label on the trailer that states the tire information and a statement that the cargo weight should never exceed X pounds. A dealer that alters an affected trailer in any way, by adding a ramp or other permanently mounted components must put a new label on the trailer with the updated weight capacity information. The weight capacity is the axle capacity (GVWR) less the weight of the trailer, so you can easily figure the empty weight. However, a living quarters trailer would never have a GVWR of under 10,000#, nor would the average simple three or four horse, so this regulation is not going to help horse trailer owners except for those pulling primarily two horse units. Please also be aware that we have NEVER weighed a trailer that weighed exactly what the C of O said it did. We have had, for instance, two three horse goosenecks of the same brand, one with a 4' dressing room, one with a 6' dressing room. Both C of O's said the same empty weight. We need to use the stated empty weights as a guideline, not as accurate numbers. If you need to be exact, pull the trailer to the nearest mill and pay them a few bucks to weigh it for you. We have allowed customers to take prospective purchases to have them weighed when the weight issue was overwhelming the common good sense. | |
| On our trailer there is a VIN plate with the numbers stamped into it. Now what Kay says is interesting, because of the same weight on the different trailers and same model. Our trailer is an extra two feet in the front, area. Two horse straight load with the extra two feet in the box stall in front. I am wondering now if the tag is a generic one and for interest should get the trailer checked at a scale. Will not make a difference for us as we will never exceed total weight they place on the VIN for allowed weight in trailer. Well we shouldn't as that is stated on the VIN tag as 4950.
      Location: washington | I notoced that on the registration for my trailer, the weight (used to calculate the cost of the annual vehicle tabs) is right on the registration... 3800 lbs. I have a 3 horse gooseneck, with the high-sides style and tapered nose... no living quarters but a good size tack room. Do other states list the weight on trailer registrations? * | |
