      Location: Home of Wild Turkey Whiskey | I have a 2005 Dodge Cummins Dually looking for info on changing the rear leaf spring set-up to air bags. Anyone done it? Who's system? I've seen some 4 Link type set-ups do they still carry the load. I pull various trailers with the truck looking for something that you can adjust ride hieght with air pressure. Thanks in advance for all info. | |
| Originally written by HWBar on 2006-01-30 4:53 PM
I'm currently going through it right now with a Chevvy Duallie, though not with the "ambitious" 4-link set-up.
From what I've heard, read and know;
4-link systems are about $2K
straight air bag systems start at $240
add another $250 or so if you want an on board pump, another hundred or so if you want auto levelling.
Installation extra - I only price parts and estimate knuckle skin co-lat damage.
I'm starting simple, will put the basic kit in first and evaluate it.
SOME folk suggest/recommend taking out a leaf from the main stack, I may check into that again according to how things go with the initial install.
I have an option on a compressor for low (no ?) cost, other than de-installing it from it's present owner's vehicle + maybe 3 beers after the fact.
I doubt that it is worth the bother, I can add air bag pressure check/adjustment to my usual truck and trailer tire check before each trip.
Check the diesel forums, there is a DIY and projects page there somewhere.
DO know if your truck started life as a pick-up, a chassis/cab, or a "pick-up with box delete". On the Chev/GM the underguts are VERY different and if you web order the wrong kit... return shipping, maybe re-stock charges, etc.
Check the Firestone site as well as whoever you order from.
Firsestone tech support are very good, I have their 800 number if you need it.
2229 kit looks right for what you have, but check this for fit;
http://www.ride-rite.com/installation_instructions/2299.pdf
Good luck, let us know what you decide and how it goes. | |
      Location: Home of Wild Turkey Whiskey | Thanks for the info, three beers for the compressor is a good deal. I'm also a member of the busted knuckle garage and will be doing all the install myself, I really have a problem paying anyone to do something that I have the tools to do. | |
  Location: Delta Junction, Alaska | I have added a airbag system to my dually and love it. I did get the compressor and love it. I have used it from everything to airing up a friends tire that they fixed up after a nail to cleaning tack. It is a great add on that I am glad my boyfriend talked me into. I use it alot and the airbags are great on both my dually and his 3/4 ton. | |
