1/2 ton vs. 3/4 ton pulling alum 3 horse GN
Saddlebredlover
Reg. Dec 2005
Posted 2005-12-29 2:08 PM (#34504)
Subject: 1/2 ton vs. 3/4 ton pulling alum 3 horse GN
I have definetely got the cart before the horse...I recently purchased a new aluminum 3 horse gooseneck with a 4 ft short wall LQ that I'll be pulling my horse and pony around in.  I now am trying to decide on a truck to pull it with.  I keep hearing that a 1/2 ton pick-up won't pull a trailer because it will strain the engine.  Is this true?  I prefer buying a 1/2 ton and paying the gas on a 1/2 ton than a 3/4 ton, if possible.  Any advice?
RollinPonies
Posted 2005-12-29 2:24 PM (#34505 - in reply to #34504)
Subject: RE: 1/2 ton vs. 3/4 ton pulling alum 3 horse GN
Originally written by Saddlebredlover on 2005-12-29 2:08 PM
"I have definetely got the cart before the horse..."
In my opinion you don't but eveyone's situation is different: What you want to do  (off road, on pavement, trail riding, shows, etc.), how often you want to do it, how much you have to spend, what you find "acceptable" performance, etc.
I wouldn't be happy without my 3/4 diesel but you might be just fine with a 1/2 ton gasser that is rated to pull your loaded trailer weight.
I started out with 1/2 ton gassers, went to a 3/4 ton gasser. Less than 18 months after getting the 3/4 ton gasser I traded it in on a 3/4 ton diesel.  It was an expensive way to change my mind!  As they say, hindsight is 20-20. I should have gone straight to the 3/4 diesel.  I could have gotten by with the 1/2 ton but I wouldn't have been as pleased with the rig that I have today. I love the torque and virtually effort free pulling.
All depends on what you expect your rig to do.  I certainly understand your desire for economical operation but only you can decide what you will be happy with.
Good luck!
TXAggie
Reg. Dec 2005
Posted 2005-12-29 3:36 PM (#34508 - in reply to #34504)
RollinPonies makes good points.  Ultimately only you can decide what is right for you, your trailer and your needs.  Another point to consider is how often will you be pulling the trailer versus running around empty.  1/2T vs. 3/4T vs. 1T also has a lot to do with GCVW (Gross Combined Vehicle Weight), i.e. how much can you tow and how much weight can the bed carry.  My gooseneck hitch is rated at 30,000# GVW (Gross Vehicle Weight) and 7,000# tongue weight - both of which exceed the rated capacity of my 1T.
I have an '03 F-350 V10 (gas) dually and pull a GN weighing about 6,900 empty and rated at 12,168 GVW.  It does fine on level roads, but I can watch the RPMS jump on hills and the gas gauge drop whenever I pull the trailer.  However, I do a reasonable amount of driving with it empty, so it is a good compromise (not to mention gas is cheaper than diesel).
So 3/4T more pulling power, less gas/diesel mileage (assuming different rear ends 3.xx on 1/2T vs. 4.xx on 3/4T), more money.  But then again, the dealers may be more willing to give a good price on a 3/4T cause they don't move as fast as a 1/2T.  Look around, surf the web, be open minded.
Best of luck in your search.
Edited by TXAggie 2005-12-29 3:44 PM
clyde
Reg. Dec 2005
Posted 2005-12-29 4:09 PM (#34511 - in reply to #34504)
  I have a 1/2 ton, and pull a 16ft stock trailer.  I also have a tranny that has been upgraded and a power chip.  I stugle to pull 2 large horses, in Iowa where its semi flat.  I do agree with the person with the diesel.  I am getting ready to buy a 2500 HD diesel from B.B in Des MoinesThe salesman there was albe to tell me about the truck with no b.s.(I did my homework before I went)So I do have a 1/2 ton pu for a flower pot if anyone needs one.  By the way you will get beter fuel milage out of a diesel  so the price of fuel will balance out.
bobtaildog
Posted 2005-12-29 10:56 PM (#34539 - in reply to #34511)
Go to any horse event where there is a parking lot full of GN Living Qtr trailers and count the number of them being pulled by a 1/2T truck....bet you won't find many....for good reason. 3/4T and 1T trucks are made to haul and pull, not only is a 1/2 T motor not sufficient, neither are the brakes, suspension, or transmission.
KP
cupid
Reg. Dec 2004
Posted 2005-12-30 10:08 AM (#34555 - in reply to #34504)
From my research I did not think any 1/2 ton truck could pull a LQ trailer. From other threads it seems they could MAYBE handle a small regular gooseneck. So the first question is, how much does it weigh?
(I've been admiring the Equispirit 3H "straight load" GN (no LQ of any kind, just a tack) and figured I would need at least 3/4 ton to pull it.)
Edited by cupid 2005-12-30 10:15 AM
RoperChick
Reg. Dec 2005
Posted 2005-12-30 6:48 PM (#34581 - in reply to #34539)
Originally written by bobtaildog on 2005-12-29 10:56 PM Go to any horse event where there is a parking lot full of GN Living Qtr trailers and count the number of them being pulled by a 1/2T truck....bet you won't find many....for good reason. 3/4T and 1T trucks are made to haul and pull, not only is a 1/2 T motor not sufficient, neither are the brakes, suspension, or transmission.
This is exactly right, I almost never see people at ropings or horse shows with ½ ton trucks as their tow vehicles, and with good reason, ½ ton trucks aren’t made for pulling heavy loads like most horse trailers. If you do see them, they are pulling a small bumper pull trailer, I don’t think I’ve ever seen one pulling a gooseneck.
What is even more important than engine and transmission in a tow vehicle is suspension, brakes and wheel base. Of course you need adequate engine power to pull your vehicle, but you also need a truck that can handle the extra weight on the suspension & brakes. Even if the body looks the same, 1/2 ton trucks are very different underneath from 3/4 and 1 ton trucks. They are often on a lighter duty frame and have much lighter suspension and smaller brakes than the ¾ and 1-ton trucks. If something bad happens, a blowout, a bad stretch of road, a horse comes ‘unglued’ in the trailer etc., you can get into very big trouble with a trailer that is too much for the truck.
Because we couldn’t afford anything larger, our first truck was a ½ ton truck, with a tow package. The trailer we chose was a CM Playday, which is a pretty small two-horse trailer, we chose this trailer because we were very aware of our ½ ton truck’s limitations. As soon as we could afford it we moved up to a ¾ ton truck and then eventually to 1-ton trucks. The difference in braking and stability between the ½ ton and ¾ ton trucks was really significant not only under normal driving conditions, but especially noticeable on rough roads or in wind. There is also a big difference in stability between ¾ and 1-ton trucks.
As for the motor and transmission, while you may save a little on fuel, you will probably find a shortened life for both of these items, especially the transmission, if they are two small for what you are pulling or carrying.
If it were me, I would put safety over saving a few $ on fuel and would get the ¾ ton truck. As you can see from my signature, I pull a 3-horse aluminum gooseneck with a 4-foot short wall, I wouldn’t pull a trailer that large with a ½ ton truck under any circumstances, except maybe under the most dire emergency.
Happy Trails,
mrstacticalmedic
Reg. Dec 2005
Posted 2005-12-31 12:18 PM (#34630 - in reply to #34504)
I don't know about the 3 horse gn, but I pulled a 2 horse gn w/living qtrs (26ft long) from Michigan to Boston, Ma and back with 2 16+ hh TB's in there.  I had NO problem whatsoever, no straining through the mountains, and got decent gas mileage.  I have a 97 Dodge Ram 1500 Magnum v8.   I estimate the weight was well over 8000 pounds.  I was able to haul safely, stop safely.  We went through rain, high elevations, you name it.  She hauled beautifully.  I recently hauled the trailer to North Carolina, after selling it.  She hauled great through those mountains as well.  Alot of people use 3/4 tons because that is all they have been told to haul with.   If your 1/2 ton is a new one (90's or later) they are built tougher, and able to do heavier duties.  The magnum v8 in the Dodge Ram is great.  I have never had any problem with it, and I have hauled all over with it.  I currently have over 110,000 miles on this truck and she still purrs like she is brand new.  It is all about maintenance.  If you keep your oil changes regular, replace things before they wear out, have good tires, check your trailer brakes, and get all your joints taken care of, there is no reason you can't haul a 3 horse trailer.  I have seen folks haul a 3 horse trailer here in Michigan.  We have lots of steep hills, and yet you see them at the horse campgrounds alot.   It is just a matter of perspective.  *Also want to add mine is not a 4 x 4 either.
Just my two cents worth.
Linda
Edited by mrstacticalmedic 2005-12-31 12:20 PM
MBRA518
Reg. Sep 2004
Posted 2005-12-31 6:36 PM (#34644 - in reply to #34504)
1001001001002525
Not all 3/4 tons are made equal either... for instance Chevy and GMC through the years have made "lighter" duty 3/4 tons - usually different by 5 bolt wheels on the lighter ones and 8 bolt wheel on the heavy duty ones... the lighter duty ones have the same size brakes (or pretty close) as a 1/2 ton where the 8 bolts do have larger brakes. I was advised to look out for this when looking for my truck (I'm hauling a 3H with 6 ft LQ).You will find 1/2 tons (properly equipped) out there that will haul your trailer ok.... you will not be winning any races but you will be under load limits and safe. We did it for years when I was a kid on the east coast of Canada (read mountains) and never had any problems. As for engine size - you can get many different engine sizes in both 1/2 tons and 3/4 tons. If it's a new vehicle you are looking for have a look at the Chevy 1500HD, it's a beefed up 1/2 ton with heavier suspension and larger brakes (basically a 3/4 ton), I'm sure Ford or Dodge have similar models as well.If you are only hauling sometimes and the truck will normally be a daily driver then my opinion would be to get a truck that will haul your loaded trailer on the upper end of it's safety limits, that way you are not risking safety, but you are also not getting more truck than you need. Or do what I did and buy and older truck to haul the trailer and get a small car for commuting.
Z71
Reg. Oct 2004
Posted 2006-01-01 1:00 PM (#34673 - in reply to #34504)
I have a 96 Chevy Z71 1/2 ton with the 5.7 vortec engine.  It is 4 wheel drive and has the tow package with transmission cooler.  I have over 200,00 miles on it and I pull a 20 ft on the floor steel trailer with 6 ft short wall living quarters.  I usually only have 2 horses, as I use the 3rd stall for storage.  Most of the miles on this truck has been pulling the trailer as I do a lot of trail riding and since I'm in Kansas it's usually a 2 to 4 hour drive to get anywhere with good trails, have also hauled to South Dakota with 3 horses in it.  I have never had any problems with hills or flat land.  I do have my transmission back flushed once a year and have never had any transmission problems.
nd deb
Reg. Apr 2004
Posted 2006-01-01 1:42 PM (#34676 - in reply to #34630)
one thing you have to realize even if your 1/2 ton truck can pull it it might not be legal wt wise.  YOu are most likely gonna be over wt especially with a small lq or wkender 3 h.
I have a 3/4 ton gasser and a 18 ft 3h steel titan renegrade trailer with a 4ft short wall lq/wkender.   After figuring the what the legal wts are i find that I am over my pickups wt limit when I haul 4 horses in it.  I was looking at getting a 4 h and didnt think i would need to get a bigger truck.  I am wrong on thinking that.   I have hauled 5 horses in my trailer with my truck and it pulled it just fine.
If you are ever in an accident and you are over wt you will probably be at fault then.   You want to make sure your truck is gonna be safe when stuck in a emergency situation.  Want to make sure you are gonna be able to stop or handle the truck.
I dont think many people realize this for I often see alot of people pulling trailers that are undertrucked.
Z71
Reg. Oct 2004
Posted 2006-01-01 2:42 PM (#34677 - in reply to #34504)
How do you haul 4 & 5 horses in a 3 horse trailer?  Also if your 18ft trailer is over the limit for your 3/4 ton, you must have an extremely heavy trailer or a very light duty 3/4 ton truck.
mrstacticalmedic
Reg. Dec 2005
Posted 2006-01-01 2:56 PM (#34678 - in reply to #34677)
The thing about legal weight limits threw me off.  I thought that only mattered if you were driving a semi with a cdl license that you had to worry about legal weight limits.  Can someone educate me on this please?  When I bought my trailer I was never told there was a legal weight limit that a non commercial vehicle had to abide by.
N2ridin
Posted 2006-01-01 4:20 PM (#34681 - in reply to #34504)
50010025
Just get a 3/4 ton.  Trust me. . .  you'll be sorry if you try to pull it with a 1/2 ton.  Get a diesel, the mileage is better
3Turns'Nhome
Reg. Dec 2003
Posted 2006-01-01 9:50 PM (#34696 - in reply to #34504)
I agree - the bigger the better -  diesel is also better than gasoline engine for pulling a trailer.
mrstacticalmedic
Reg. Dec 2005
Posted 2006-01-01 11:07 PM (#34698 - in reply to #34504)
Again...it is all a matter of perspective.  I have seen my ram 1500 pass some of the bigger trucks hauling up in the mountains.  As far as diesel is concerned yes it has more pull power to a slight degree, but you are going to pay a lot more in fuel costs and maintenance.  If you can afford it...go for it..why not?  For those of us who do our homework, we know what a good newer vehicle can do.  Todays 1/2 tons are the 60's version of a 3/4 or even a 1 ton.  They are built for more pulling power, longer durability, and more fuel efficient than those in the 60, 70, or even the 80's.
If you intend on hauling Clydesdales, Warmbloods, etc..yep get the bigger truck, but half the time I see folks hauling a 3 horse trailer with maybe 2 horses in it!
Linda
Posted 2006-01-01 11:11 PM (#34699 - in reply to #34678)
Originally written by mrstacticalmedic on 2006-01-01 1:56 PM
Ignorance is not a legal defense, (just try it in court ... LOL)  Trailer places sell trailers, not legal advice
There are two issues with weight.
1- your state's regulations. For example:  A class C (Reg car) license in NC may tow a vehicle up to 10,000 pounds GVWR.  (notice this is the rating, not the actual weight) More than that, I would need a class "A" Generally if your vehicle's GVWR is more than 26,000 pounds you need a CDL anyway.  Besides the fines & hassle... Getting your loaded trailer impounded begets all sorts of problems with your horses.  Even if you can find a driver with the appropriate license.
2-Your tow vehicle's CGVWR must be high enough to pull the loaded trailer.  Otherwise you're over loaded and in a bad spot if involved in a wreck.  Actually, you're in a bad spot already since you're overloaded.
Stuck in NH
Reg. Oct 2005
Posted 2006-01-02 7:42 AM (#34708 - in reply to #34504)
I might beg to differ.  As a class A driver, I find that our class 8 trucks are usually rated for 52k, but are registered for 104k.  At a DOT inspection, all that is checked is the registration to make sure we paid for 104k.
hav2ride
Posted 2006-01-02 7:52 AM (#34709 - in reply to #34698)
1000500100100
It's not how fast you can go upa hill that counts with hauling.  It's how well you can stop on the other side of that hill and how hard you engine has to work to pull you trailer that really counts.  When you make a decision to haul horses, that should be your main focus when buying a tow vehicle.  It should not matter that the vehicle is your run around vehicle too.  Your safety, as well as the safety of those on the road around you!, should be the most important factor in your decision.  It really drives me crazy when people say, "I only tow occasionally so I don't really need to buy the best tow vehicle to suit my trailer."  It only takes one mistake to cause a major accident.
Z71
Reg. Oct 2004
Posted 2006-01-02 7:55 AM (#34710 - in reply to #34504)
Back in the 50's & 60's when I used to go to horse events with my grandpa, most of the people pulled 2 horse trailers with their cars.  And they had 2 horses in them, and I'm sure the trailers were a lot heavier made.  I had an uncle that pulled his with an olsmobile from one side of the United States to the other for several years.  And now it seems everyone thinks you must have a 1 ton diesel to even be safe.  My son is a diesel tech, and as far as the new trucks go they have increased the horsepower so much (way more then needed for most people) that the fuel economy is as bad as the gas trucks.  So you end up paying more in the beginning for the truck and then more for the fuel.
Posted 2006-01-02 11:17 AM (#34722 - in reply to #34708)
Originally written by Stuck in NH on 2006-01-02 6:42 AM
Stuck:  What is your point?
If a truck is rated for 22,000 pounds (GM one ton diesels for example) combined gross vehicle weight rating by the manufacturer.  Is it acceptable to have a trailer & truck weighing 104,000 pounds if your registration says so?
I would say not.  Regardless of the licensing state.  No one ignores the laws of physics without peril.
efaubert1
Posted 2006-01-03 7:29 AM (#34775 - in reply to #34504)
50010025
Ok,heres some clarification of the legal issue for NON COMMERCIAL, PRIVATE USE RECREATINAL PICK UPS.
When your trailer weight exceeds the MAXIMUM ALLOWED towing capacity set by the manufacturer and you exceed your CGVWR by hauling said trailer, any accident you are involved in while MOVING, other than being rear ended possibly, WILL be your fault. As you have the vehicle operating outside the rated limitations as set forth by said manufacturer. In english this means you up the creek, no paddle, and going to lose everything you ever thought of owning because you "CAN" pull a trailer with a 1/2 ton truck. Your insurance company will NOT cover your loss because you made the choice. And WHEN you go to court, not if, and are SUED by the other parties involved for damages, you WILL LOSE. Been there, seen it, don't ever want it to happen to me.
MIfarmbabe
Posted 2006-01-03 7:59 AM (#34781 - in reply to #34504)
5002525
Efaubert1 brings up some really good points on this topic. The thing is, today's horse trailers are not what they were in the 50s and 60s, they are so much bigger!!! So we have to have bigger trucks to safely pull them. Today's pickup truck has also turned into the family recreational vehicle so yes they are being made bigger to accomodate our luxuries. Just about everything has gotten bigger over the years. I guess the saying bigger is better holds true in some eyes. Tractors, motorhomes, boats, Wallyworld, the double wopper, people................
Stuck in NH
Reg. Oct 2005
Posted 2006-01-03 11:06 AM (#34805 - in reply to #34504)
My point is that if we use the manufacturer's GCWR as LAW,  then any commercial vehicle accident would automatically be the fault of the driver & trucking company.
Did you actually read Chevy's definition of GCWR?  I picked it up for you from here       http://www.chevrolet.com/silverado/specifications/
GCWR: The Gross Combination Weight Rating is the total allowable weight of the completely loaded vehicle and trailer. A properly equipped tow vehicle and trailer at the maximum GCWR should be able to accelerate and merge with traffic, climb typical interstate grades at highway speeds, handle the combination on virtually all road surfaces and stop adequately within a reasonable distance
There is alot of room for interpertation there.
I believe that with enough insurance money at stake, any lawyer can eventually get a judgement against a party that failed to control their vehicle.  Overloaded or not.
Stuck believes the laws of physics cannot even be applied if you don't read the fine print.
hounddog
Reg. Dec 2005
Posted 2006-01-03 1:01 PM (#34813 - in reply to #34504)
1000100100
If doing the horse thing with a gooseneck trailer or even a bumper pull of THREE horse configuration AND about to BUY a new or USED truck if even gas GET a 2500.They just PLAIN work better and hold up better towing any kind of weight.SAFER also.I have a 1500.It hauls feed,pinestraw,grocerys.years back I even pulled with a 2500 350 etc.But NOT a 1500 for any serious travel towing anything more then a bass boat.
Champhorse
Posted 2006-01-03 1:25 PM (#34814 - in reply to #34504)
OK, being a 1/2 ton owner, I felt compelled to put in my 2 cents worth. There are several things that would be helpful to know before giving you a definite opinion on your question. First, what kind of engine (towing capacity) are you considering in a truck? How often will you be towing a trailer and for what distances? How much does your trailer weigh? Will you only be pulling your horse and pony or will you eventually want to pull 2 full horses or 3 horses? What type of terrain will you be pulling the trailer on?
I have a 1/2 ton Chevy Silverado with a towing capacity of about 8,100 lbs. I own a 2H GN with dressing room (which could be converted to LQ) and a 4' SW on the Dressing room. Trailer empty weighs 3,500 lbs. I generally haul 1 horse but on occasion will haul 2 (figure 2,300 lbs. for the 2 horses and another 300 lbs. for tack and misc.). Fully loaded I will haul about 6,100 lbs which is completely within the specs of my vehicle. Can I feel the trailer when I'm hauling.......of course. Does my truck struggle to make it up hills.....no. Now, I haul maybe 2 times a month and travel distances of between 15 and 50 miles. My truck is being used as my primary means of transportation about 95% of the time and the 5% that I need it to haul, it's for short distances. Someone suggested going to an event and see how many 1/2 ton trucks you see in the parking lot. Well, not all of us show and use our trucks in that capacity, so not all of us need 3/4 tons or diesels. If I were showing or hauling longer distances, I too would probably get a 3/4 ton truck but for what I am needing it for, a 1/2 ton is just fine. By the way, I get 22 MPG on my little 1/2 ton......hard to justify getting something bigger that gets 15 MPG or less for what I am using it for.
You need to look at the whole picture before deciding what vehicle will fit your needs the best. If you are borderline, it's always best to err on the side of caution. If you plan on adding a horse in the near future, go ahead and plan for that now when you get a truck, but bigger isn't always better for everyone.
Flush
Posted 2006-01-03 5:16 PM (#34830 - in reply to #34814)
The rating that will most often be exceeded first with a Gooseneck trailer will be the "Gross Vehicle Weight Rating" GVWR of the truck.
This is how much total weight is on axles of the truck. This includes: The truck, passengers, cargo in the bed, and most importantly the hitch weight of the trailer!
Most half ton trucks weigh about 5,000lbs and have GVWR ratings of around 6,500lbs depending on bed configuration, 4x4 etc...
As an example: 2006 Chevy 1500 4x4 extended cab 6.5' bed:
GVWR =6,400lbs curb wieght= 5,050lbs: leaving 1350lbs for people, gear, and hitch weight.
so for example in Champhorse's case, you have a loaded gooseneck of 6,100lbs. For gooseneckss you can assume roughly 20-25% of that weight is on the hitch. Using 20%, thats 1220lbs. So... You have a total of 130lbs left for all passengers and any gear you have in the truck.
Champhorse I'm not implying you don't have a safe setup and your particular truck may have higher ratings, but you are likely close to, if not exceeding your GVWR even though you are well below the "maximum" tow rating listed for your truck. Your scenario is very common. And the only way to know for sure is to weigh your rig, since there is no way to exactly determine the hitch weight otherwise.
The Truck manufactures list the absolute maximum tow rating they can to look better than the competition. In reality you can't achieve the max tow rating with a gooseneck as you will exceed the GVWR. You could theoritically do it with a bumper pull since the hitch weight is typically only 10-15% of the trailer weight, not 20-25% for a GN and that is how they get away with listing such numbers.
Whether or not it is safe or even legal to exceed your GVWR I don't know. I choose to follow the manufactures ratings closely, even though they make them slightly difficult to intepret!
Edited by Flush 2006-01-03 5:36 PM
nd deb
Reg. Apr 2004
Posted 2006-01-04 12:38 PM (#34870 - in reply to #34677)
Originally written by Z71 on 2006-01-01 2:42 PM
My trailer doesnt have a rear tack so there is room for me to get 2 avg sized horses in the rear stall comfortably.    To get 5 in I take out the front divider and swing the rear one and latch into the front divider hole.   Then I am able to get 2 avg horses in the front stall comfortably at a slant and 3 avg sized horses side by side facing the head of the trailer comfortably.    With the divider moved up to the first ones hole it make the rear stall square and the front stall kinda of pie shaped.
I cant exactly remember the gvwt for my truck but I have figured it out a few times and with 4 horses I am over.   The limit on my truck might be 12000 lbs.   You usually add the wt of the truck, trailer, horses, tack, equip, hay ect..
hav2ride
Posted 2006-01-04 12:57 PM (#34873 - in reply to #34870)
1000500100100
Please be careful that you don't go over the GVW of the trailer.  The axels and tires are rated for the GVW of the trailer.
Flooper
Posted 2006-01-04 1:25 PM (#34878 - in reply to #34504)
GCWR is an important--but not a legally binding number...it is the recommendation of the manufacturer for the specific combination of components of a truck--gear set, auto/manual tranny/gas or diesel engine, size of engine, 4x4 or 2x4 etc...that's why it changes within the same model of truck depending on how the truck is equipped. In fact, until just recently, it was not even listed in the Chevy owner's manuals (my 1999 manual does not have a GCWR listed.
If you go over GCWR, you are being silly, possibly unsafe, and are voiding your warranty, but you are not illegal. That is because the information is not stamped on the vehicle anywhere, and is generally only listed in the owner's manual which can easily become lost or separated from the vehicle. In addition, components (transmissions, engines, gears, etc. may have been changed by previous owners, etc, which makes even published GCWRs unreliable--at least from a legal standpoint)
The really important LEGAL numbers are RGAWR, FGAWR and GVWR and are all stamped on the vehicle itself!!!!
GVWR IS a legal number. It is the SAME for every version of a vehicle regardless of engine, transmission, etc. It cannot be changed once a vehicle leaves the factory unless it goes through a re-certification process. The number you REALLY have to watch--from a legal perspective-- is GVWR!!!
The only reason I'm posting this is because too many people only pay attention to their GCWR...they stay well under it and believe everything is okay, when in fact they have not checked their GVW, and may be way over on GVWR...especially with a 1/2 ton pulling a gooseneck. And that one the cops can check...because it's stamped right on your vehicle.
PS: Insurance DOES cover you, even if you are at fault by being over your weights. Same as they cover you if you are drunk and run a red light. Your fault in both cases, but you are still covered by your policy up ot its maximums.
Edited by Flooper 2006-01-04 2:14 PM
hav2ride
Posted 2006-01-04 5:33 PM (#34897 - in reply to #34878)
1000500100100
You will be covered by insurance but you can be sued.
efaubert1
Posted 2006-01-05 8:21 AM (#34938 - in reply to #34504)
50010025
Insurance MAY cover to your limits, but YOU are liable. YOU will be sued, and the insurance company will not be a co-defendant with you in the cause, as YOU chose to ignore the vehicle limitations. Actually, with the vehicle being used improperly by YOU, you negate the insurance companies liability by using the vehicle in a manner exceeding what it is bindingly insured for use as. But the fact of the matter is this, why push it to that, just get the truck to do the damn job in the first place.
Flooper
Posted 2006-01-05 9:06 AM (#34942 - in reply to #34938)
Originally written by efaubert1 on 2006-01-05 8:21 AM
efaubert...Not trying to start an argument, but your insurance WILL cover you. . It does not matter if you are at fault, negligent, operating the vehicle in an improper manner, etc. That is part of the risk the insurer accepts when they insure you in the first place. In fact, that is my whole point...people mix up apples and oranges in equating liability with insurance coverage. Yes YOU are personally liable...that has nothing to do with whether your insurance covers you or not. The whole reason you buy liability insurance is to cover...liability!!! Does insurance cover you if you speed, run a stop sign, drive drunk, don't have your vehicle properly maintained? Yes...up to the policy limits. And yes, your are very right--people should NOT push the limits of their truck until it reaches that point...and I agree 100%, get a truck that can do the job in the first place. But that's a totally different issue.
If we're dealing in facts about insurance, the fact is...just because you run your truck over its weights, or with underinflated tires, or over the speed limit, forgot to wear your glasses, dropped a cigarette in your lap, or got behind the wheel drunk does not mean your insurance company can refuse coverage for an accident after the fact because you were doing something improper. They can (and will) of course, cancel any future coverage.
Also, your insurance company WILL most likely be a co-defendant with you. It's not their choice...if they are named in the suit, guess what...they're a co-defendant. What is most likely to happen if you cause an accident while running over your weights? The insurance company will try to settle as quickly with the other party as they can, because they know they will lose in court because of your negligence.
On the other hand--an insurance company may have a strong case not to pay any REPAIR claims for YOUR vehicle. But that's a whole different subject than liability for causing an accident.
Edited by Flooper 2006-01-05 11:24 AM
santelikk
Posted 2006-01-05 10:01 AM (#34947 - in reply to #34504)
Saddlebredlover,
I have an 02 GMC Ext Cab rwd 1/2 ton.  It has the 4.8 V-8 engine.  I pull safetly and within my vehicle specs' a 1995 3 horse Sundowner Sunlite 3' shortwall (no lq and two horses in the trailer).  I live in NW Indiana, so it is pretty flat all around where we go.  You need to find out what your trailer weighs loaded with all your equipment.  Then you can calculate your trailer weight. then you can see if you can get by using a 1/2 ton or if you need to step up to a 3/4 ton.
MBRA518
Reg. Sep 2004
Posted 2006-01-05 11:03 AM (#34953 - in reply to #34504)
1001001001002525
The most important part here is stopping - that's where the limits come in - if you are under limits then your truck's braking system is designed to stop the rig. Don't go over limits - period!
After that is settled, then you come to how it's used, engine size etc. This it for durability though - not safety (remember we have safety covered by not going over limits). For instance IMO if you only haul occasionally and/or short distances - you can go to the limits and be just fine - however if you will be doing a lot of hauling and are at or near your limits - you will have maintenance issues and repairs - that's a fact with machines - they don't like to run at maximum loads 100% of the time - and they are not designed to do it - no machine is - car, truck, photo copier whatever. But if it's mostly a daily driver and occasional tow vehicle - it will last you just fine being at or near limits when hauling.
There is also the speed factor when at limits - not so much with newer vehicles as older ones as it seems engines are better now... for instance I run a 1992 Chevy 3/4 ton (HD model) to pull my 3H aluminum w 6ft LQ... I'm fine as far as weight is concerned - but it has a 350 engine with over 300,000km on it.... it's tired - we don't go over 100km/h on the highway and she wouldn't stand up to high speeds in hilly areas I don't think (the engine that is the rest of the truck handles it just fine). But most of the time it's not hauling, and even then it's usually on slower secondary roads so she's lasting just fine. Though I am thinking of putting a 454 in it when the time comes to overhaul the engine (at 300,000 km that's eventually going to happen). I said new engines are better because friends of mine haul a 3H GN with 4ft dress with a Chevy 1500HD (suspension and ratings of a 3/4 ton) and their engine does not strain like mine does in the same area's.
