Location: Yellow Springs, OH | I have a new 2006 Exiss 304 Weekender that I ordered at Congress and just took delivery of a couple weeks ago. I bought a medicine cabinet with a mirror to attach to the wall that divides the living area from the horses. What's the best method of attaching it? I have both toggle bolts and metal hollow wall anchors. |
        Location: North Carolina | Originally written by Distarte on 2005-12-08 11:31 AM
I bought a medicine cabinet with a mirror to attach to the wall that divides the living area from the horses. What's the best method of attaching it? I have both toggle bolts and metal hollow wall anchors. Carefully .. lol There are as many methods as types of fasteners. I like self drilling metal screws myself. Either type that you have will work. They will require large holes to insert the anchor or toggle. Therefore I like the above screws better. Look for the supporting members inside the wall. Either look for other fasteners or push on the wall surface to find the supports. It's just like hanging stuff on the walls of your house. You want the fastener to be supported by the framing, not the wall skin.
Edited by hosspuller 2005-12-08 3:17 PM
| Originally written by Distarte on 2005-12-08 12:31 PM
I would first need YOUR definition of "best" (-:
I dislike having to drill, I sometimes dislike where the fastener comes out on the other side. However hard you might find this to believe, there really ARE double sided sticky tapes that will do this job and do it very well. For THIS job MY choice would be the double sided tape that trailer manufacturers use to hold the outer skin to the frame (among other things) and avoid rows of rivets at every upright post. It is also good for hanging mirrors on tack/dr doors, but I've said that before and been laughed at (-:
I'll dig up the name if you're interested. |
 Location: TX | Originally written by Reg on 2005-12-08 10:15 PM Originally written by Distarte on 2005-12-08 12:31 PM I have a new 2006 Exiss 304 Weekender that I ordered at Congress and just took delivery of a couple weeks ago. I bought a medicine cabinet with a mirror to attach to the wall that divides the living area from the horses. What's the best method of attaching it? I have both toggle bolts and metal hollow wall anchors. I would first need YOUR definition of "best" (-: I dislike having to drill, I sometimes dislike where the fastener comes out on the other side. However hard you might find this to believe, there really ARE double sided sticky tapes that will do this job and do it very well. For THIS job MY choice would be the double sided tape that trailer manufacturers use to hold the outer skin to the frame (among other things ) and avoid rows of rivets at every upright post. It is also good for hanging mirrors on tack/dr doors, but I've said that before and been laughed at (-: I'll dig up the name if you're interested. Reg - I would like to know the name of that kind of tape and where it can be purchased. Thanks
Edited by barrelsnpcs 2005-12-10 2:00 PM
| I got it from 4-Star, they call it "vhb tape", which I've taken to mean very high bonding - and it IS !
I sent a personal message to someone about this; be VERY CAREFUL where you put this stuff and be darned sure that you are putting the cabinet (or whatever) exactly where you want it. There is NO chance to square things up if you get them a bit off level or square, so rig a temporary shelf to get the cab level and properly positioned so all you have to do is slide it back carefully and squarely. I suggest putting it ONLY at sides and corners where you know you will have utility knife access if you ever want/need to cut it out.
4-Star WILL sell parts and raw materials to whoever calls them, they don't quiz you for model, year and serial number. The prices are reasonable, I think the tape was about 95c a foot. Might as well get 20ft. as you'll probably pay a minimum shipping charge anyway.
OK, another plug for 4-Star: If you see hinges, door latches, whatever other fittings and fixtures that you like on a 4-Star trailer, call 'em up and ask for a price. Get the year and model number from the owner if you can and the serial number might help you get the EXACT part.
    Location: Kansas | Reg and gang-I contacted 4-star. He did not recommend the VHB for anything but metal to metal or metal to plastic. Now, would it work ok but he didn't feel comfortable saying so because that's not a recommended usage? I don't know. I can't see why it wouldn't work fine, but have never used it yet so.... |
Location: Yellow Springs, OH | Thanks everybody for the suggestions. I ended up hanging the cabinet on two metal hollow wall anchors and then using some self drilling metal screws through the back of it. It seems very secure and I even got it centered and level. I then hung up a coat rack under it and it looks great. Thanks again. |
