        Location: North Carolina | If your trailer is not level, you have torsion axles, and the the back of the trailer is lower than the front, your trailer is putting more of its weight on the rear tires. As Reg says "overload" ... Another possibility is the camber of the axle is wrong or gotten bent. Most torsion axles have a bend to create the proper tire camber. (Camber is the angle the tires are set to. Normally, the tire's top is leaning over the bottom. When the tire is rolling down the road the tire swishes out, away from the trailer center) |
