Bison 8310 and 3/4 ton pickup
roadranger
Reg. Oct 2005
Posted 2005-10-12 10:51 AM (#31629)
Subject: Bison 8310 and 3/4 ton pickup
Gettin' ready to pull the trigger on a Bison 8' wide, 3 horse, 10' Lq all aluminum trailer. Trailer light weight is 8900 lbs, and I'll be loading ~3000 lbs into it, for a trailer GVW of 11,900. I'll be pulling it with the Dodge 3/4 ton listed in sig. Trailer is way below the Dodge rating of a 13,200 lb trailer OK for this truck. Have seen these trucks hauling HUGE 5th wheel RV's- much bigger/heavier than this Bison.
What do y'all think of this combination?
Edited by roadranger 2005-10-12 10:56 AM
chadsalt
Posted 2005-10-12 3:02 PM (#31639 - in reply to #31629)
Subject: RE: Bison 8310 and 3/4 ton pickup
1000100100100100
i "think" it will pull it fine, but i also "think" youll be close/over on the trucks GVWR. why do you ask?
Edited by chadsalt 2005-10-12 3:04 PM
Posted 2005-10-12 3:13 PM (#31640 - in reply to #31629)
Originally written by roadranger on 2005-10-12 9:51 AM
Don't be impressed by the size of those RV trailers.  Horse trailers have much more weight in their structure than an RV.  Consider the cargo... Two or more 1500 pound beasts standing on 4 or 2 spots on the floor.  The floor loading in an RV is nothing compared to that.
Run the "all" numbers from the truck and trailer manufacturers.
Make sure your hitch weight is within your payload too.
huntseat
Posted 2005-10-12 3:38 PM (#31646 - in reply to #31629)
1000500100100100100252525
You state your truck is slightly bombed...if you have treated it badly, you'll get your come-upins at the worst possible time.
Are your tires rated to carry this load?
Have you "run your numbers" as Hoss stated?  Payload included?
If it is too much can you buy another truck?  Or will you be streching your dollar to it's limit with this deal?  If so I'd bail on the money problems first...you'll lose big money on the trailer if you try and sell it.  Check the resale on Bison's...
I'd go slow and know EXACTLY what you are doing before you sign that bottom line.
MIfarmbabe
Posted 2005-10-12 4:13 PM (#31653 - in reply to #31629)
5002525
I was wondering what "slightly bombed" meant....could mean a lot things, but didn't want to go there.
N2ridin
Posted 2005-10-12 6:04 PM (#31658 - in reply to #31629)
50010025
See. . . .. .  I told ya
roadranger
Reg. Oct 2005
Posted 2005-10-12 8:03 PM (#31667 - in reply to #31653)
Originally written by MIfarmbabe on 2005-10-12 3:13 PM
LOL! Bomb = Better Off Modified Baby
It means there is a fueling chip for the diesel, a HD replacement clutch, bigger air filter, 4 in. exhaust, and 19.5 Rickson wheels w/Dunlop tires rated at 4500 lbs each, and 4 leaf 2500 lb helper springs in the rear.
This truck is currently hauling a 4100 lb truck camper and towing a 7000 lb bumper pull trailer with a combined overall weight of 19,000 lbs, for 40k miles so far.
I'm lookin' to go gooseneck to get weight off the truck- should loose about 1200 lbs this way. Yeah, I'd still be over the trucks GVW, but only half as much as I am now.
Can't get rid of the the truck, what with all of the time and money I've got sunk into it, so this gooseneck is the answer.
I was asking the opinion of this forum, as you guys (and gals) have the experience of gooseneck hauling, where NO one else does.
You mean nobody hauls these goosenecks around with a 3/4 ton truck?
Posted 2005-10-12 8:26 PM (#31668 - in reply to #31667)
Originally written by roadranger on 2005-10-12 7:03 PM
 LOL! Bomb = Better Off Modified Baby It means there is a fueling chip for the diesel, a HD replacement clutch, bigger air filter, 4 in. exhaust, and 19.5 Rickson wheels w/Dunlop tires rated at 4500 lbs each, and 4 leaf 2500 lb helper springs in the rear. This truck is currently hauling a 4100 lb truck camper and towing a 7000 lb bumper pull trailer with a combined overall weight of 19,000 lbs, for 40k miles so far. I'm lookin' to go gooseneck to get weight off the truck- should loose about 1200 lbs this way. Yeah, I'd still be over the trucks GVW, but only half as much as I am now. Can't get rid of the the truck, what with all of the time and money I've got sunk into it, so this gooseneck is the answer. I was asking the opinion of this forum, as you guys (and gals) have the experience of gooseneck hauling, where NO one else does. You mean nobody hauls these goosenecks around with a 3/4 ton truck?
Having made my share of mistakes... be careful of the trailer neck-over height. if your truck is lifted over stock or even stock... with the wrong trailer, your tailgate or bed side is likely to be crushed.
Dunoir
Posted 2005-10-13 7:14 AM (#31689 - in reply to #31629)
50010025
A friend of mine hauls a 3H GN LQ Steel Charmack (I think that's the brand)  trailer with a F250 Diesel - don't know the particulars of the truck, but this trailer has gotta be very heavy.  The LQ's are very large - probably 12'.  They haul 2 horses and used to live in CA.  Moved to Fla 2 years ago and travel around the state going to Mounted Shooting Matches.  He's also traveled the SE.  I do know he got an extender for the GN hitch as it was too close for comfort when turning.  I can email him and find out more particulars on the truck.
efaubert1
Posted 2005-10-13 7:42 AM (#31692 - in reply to #31629)
50010025
Roadranger,
 That truck should pull the 8310 pretty well. I'm a Ford man, but the cummins and the spring packs you have should handle it.
cupid
Reg. Dec 2004
Posted 2005-10-13 10:17 AM (#31702 - in reply to #31629)
When someone says something is in their sig, how do you see it? Haven't figured this one out yet. Also sometimes they will say there is a link at the bottom (?of their message or their sig, I'm not sure?) and I won't see that either. Help?
roadranger
Reg. Oct 2005
Posted 2005-10-13 11:27 AM (#31709 - in reply to #31668)
Originally written by hosspuller on 2005-10-12 7:26 PM
Having made my share of mistakes... be careful of the trailer neck-over height. if your truck is lifted over stock or even stock... with the wrong trailer, your tailgate or bed side is likely to be crushed.</P>
I hear ya Hosspuller. These Dodge's already have a 5 in. tall block between the axle and springpack. There's no other lift on the truck, and the 19.5 tires are only 1/2 in taller than stock. I know Bison will do a 2 inch suspension lift on the trailer, and Dodge has a re-fit kit to swap the 5 in. blocks for 2.5 in. blocks...
What do you recommend for minimal gooseneck/truckbed clearance? 6 inches?
figero
Reg. Oct 2004
Posted 2005-10-13 8:51 PM (#31731 - in reply to #31629)
If you have a question about the actual weight of your trailer ask the dealer for a weight ticket from a scale. I have pulled a bison, 8900lbs. seems light. It might be heavy on the gooseneck for a 3/4 ton. If you have it weighted ask for total trailer weight and the weight on the axles.
xyzer
Reg. Apr 2004
Posted 2005-10-13 10:22 PM (#31734 - in reply to #31702)
Roadranger....I read your post and kinda got confussed for a bit....I replyed on the Dodge site about the load range of the tires...for a minute I was having a senior moment...
Originally written by cupid on 2005-10-13 8:17 AM
Cupid if I did this right you will see my "sig"=signature  after this...This is a "link" or website  http://www.dieseltruckresource.com/dev/index.php
goz63
Reg. Dec 2011
Posted 2012-04-08 5:19 PM (#142899 - in reply to #31731)
I think you will be just fine. I have a F250 diesel and pull a 15ft short wall Lakota that is 8900 empty. It pulls it just fine. The only thing I added was an air lift kit to make it easy to level. It won't allow you to hall more weight but it does make it nice for balance and since I don't have a dually, it is better on corners.
We went to TX and back from St Louis with ours last month and had no issues.
Enjoy.
goz63
Reg. Dec 2011
Posted 2012-04-08 5:21 PM (#142900 - in reply to #31731)
Enjoy.
trot-on
Reg. Dec 2009
Posted 2012-04-08 8:18 PM (#142902 - in reply to #31629)
Just because others are pulling with such trucks, does not mean that is is the best / safest option.
What does your truck weigh loaded with fuel, people, and anything else before the trailer? What is the combined rating of the truck for the whole rig?
Posted 2012-04-09 2:42 AM (#142906 - in reply to #31667)
Originally written by roadranger on 2005-10-12 8:03 PM
Larger wheels means you've LOWERED the effective rear end ratio...
dkhunter04
Reg. Oct 2008
Posted 2012-04-09 6:55 AM (#142910 - in reply to #31629)
I wonder if the original poster from 2005 still owns the same truck and trailer?
SILVER
Reg. Feb 2010
Posted 2012-04-09 1:59 PM (#142927 - in reply to #31629)
we have a Cherokee, 3 stall slant with a 13 foot short wall and 8 feet wide. we pull it with a 2004 3/4 ton Dodge diesel. No problem. Good pulling truck, with the cummins engine. But hubby did put air bags on it, which really makes a difference. Hope this helps.
trot-on
Reg. Dec 2009
Posted 2012-04-09 6:57 PM (#142936 - in reply to #142910)
Originally written by dkhunter04 on 2012-04-09 6:55 AM
Details details. lol
Hey, if it makes someone consider their rig, and if they are safe, then its al good
Posted 2012-04-09 9:45 PM (#142945 - in reply to #142910)
Wow...missed the OP date completely...I wonder how someone found the thread...since the search only goes back a year...
RedParrotRodeo
Reg. May 2012
Posted 2012-05-18 8:18 AM (#144025 - in reply to #31629)
We have been pulling a Titan all steel 3h slant with 4.5' weekender lq and our 2 full sized horses (occassionally also with the 2 mini winnies in the 3rd stall for quick transport to vet clinics, into town for parades, etc) hay, water, supplies for some years with no problem using a 2000 Chev K2500HD with the tow/haul package.   That trailer is a beast but still pulls nicely.  I was shocked when I found that many of the newer aluminum lq trailers that are larger are lighter than my Titan.  I didn't think it made that much difference.  Get the dry/curb weight of the trailer then add all the other stuff - many places we checked don't have that off the top of their heads, only the GVRW I always make them go look it up when looking at new trailers.
Ideally, we would buy a new 1ton pickup too, but not everyone can afford the trailer and the pickup.
Posted 2012-05-18 9:38 AM (#144026 - in reply to #31629)
Since the original poster probably made his decision 7 years ago, We might get lucky and hear how it turned out.
But to other buyers considering these types of question. I suggest you hook up and run across a scale.  If it over loads the rating of the truck  ( in any of the several areas)  Then sell the truck and buy a different one,  There are tons of trucks for sale on the market, It would be very easy to sell the 3/4 and buy a 1 ton or even a dually of the same year and model and it wouldn't cost that much more.  In fact I bet you could sell a 3/4 ton and if you were a smart used car buyer, Buy a same year dually for the same money.
Once the trucks are used.  The difference in price between a 3/4  a 1 ton or a dually are almost non existant.
paintcrazytexan
Reg. Feb 2008
Posted 2012-05-18 8:15 PM (#144039 - in reply to #31629)
