what adhesive to use??
appy4me
Reg. Jul 2005
Posted 2005-09-28 1:09 PM (#31086)
Subject: what adhesive to use??
What type of adhesive/glue would you use to adhere the black matting to the walls of your trailer. We would rather not use any type of rivot or screw! We bought a used LQ GN, and the black matting is falling off the walls. We had a terribly HOT summer with lots of humidity, so thus the adhesive failed!! We are going to re-apply the matting, so any help would be appreciated! (The trailer is 4 years old)
Thanks
Diane
maccwall
Reg. May 2004
Posted 2005-09-28 1:37 PM (#31088 - in reply to #31086)
Subject: RE: what adhesive to use??
500
I've used the PL Construction Adhesive to adhere wood to the metal surfae of our trailer but you would have to clamp it someway to get it to work. One I've heard of that's really good but I haven't used is the Loctite Power Grab Adhesive. It supposedly sticks without clamps. You can get both from Home Depot or Lowes.
Safe Riding,
Todd
terri s
Posted 2005-09-28 4:59 PM (#31098 - in reply to #31088)
500100100100
Locktite is good. I had pretty good luck with a simple silicone caulk; it has good adhesive qualities and still allows a little movement. Also used it to glue carpet over my saddle racks. Good longevity from both projects.
MR.ED
Posted 2005-09-28 8:09 PM (#31102 - in reply to #31086)
i know if your walls are painted some adhesives will eat the paint and cause them to fall off or using to much. and your right dont add screws
