?? on F350 7.3 Powerstroke maintenance
cmdomino2000
Reg. Apr 2004
Posted 2005-07-22 6:23 AM (#28422)
Subject: ?? on F350 7.3 Powerstroke maintenance
Hi, I just bought a 95 F350 dually with the 7.3 Powerstroke diesel in it.    This truck has 110,000 miles, and runs and sounds GREAT~ but then without warning the motor will die.
It starts right back up, but I'm looking for suggestions of what might be causing this.
I am a single female, and don't know anyone who works on diesels, and was wondering if anyone has any ideas on *simple things* that I could try to fix myself?
How difficult of a job is it to change the fuel filter?   Does this motor have injectors on it that might benefit from having some cleaning stuff added to the fuel?   Or...any other ideas?
I bought it from an individual, who lives in another state, so asking them to show me things on it is not an option.
thanks, Charla
efaubert1
Posted 2005-07-22 7:34 AM (#28426 - in reply to #28422)
Subject: RE: ?? on F350 7.3 Powerstroke maintenance
50010025
Charla,
Does it die while a.Idling b.when you go to take off c.while your driving
It is likely a sensor. Either the cam position sensor, which will cost you a $100, a 10mm allen wrench, and 15 minutes to fix or possibly the sensor on the tranny which you will need Ford to get to.
Fuel filters are not hard to change, it is dead center, top of the motor. Probably under the little 7.3L cover. It's a canister type that lifts out. As for injectors, yes it does have injectors but they are most likely not the problem here.
equinetrans
Reg. Jun 2005
Posted 2005-07-22 8:55 AM (#28432 - in reply to #28422)
Subject: RE: trailer axles
Go to 'thedieselstop.com' and learn all about Ford diesels, the good, the bad and the ugly. Lots of very knowledgeable people on the sight.Jim Clark-Dawe
cmdomino2000
Reg. Apr 2004
Posted 2005-07-22 9:04 AM (#28433 - in reply to #28426)
Hi, thanks for the help...... it has died twice when idling, and twice when I was driving about 40 mph.
Thanks for telling me where the fuel filter is too... the truck came with this extremely useless book that doesn't even have the word "filter" listed in the index, lol.
Charla
cmdomino2000
Reg. Apr 2004
Posted 2005-07-22 9:07 AM (#28434 - in reply to #28432)
Thanks for the tip, Jim.    I'll go to the Dieselstop and check it out :-)    Sounds like a handy site to bookmark, and I'd never heard of it.   Charla
efaubert1
Posted 2005-07-22 10:28 AM (#28440 - in reply to #28422)
50010025
The indicators you have outlined point to the cam sensor. DO NOT buy it from FORD. It will cost you twice as much. Go to an International dealer or NAPA and pay much less. And it will be the same identical part.
SaddleSore
Reg. Dec 2004
Posted 2005-07-22 10:42 AM (#28441 - in reply to #28440)
I may be wrong,but if the cam position sensor is bad,it shouldn't start.I've never had one go out on mine,so I have no experience with it,only what I've heard.thedieselstop is a good place to gather info,as is fordtruckenthusiasts.com.
Charla,you have a PM.
SaddleSore
Edited by SaddleSore 2005-07-22 10:50 AM
efaubert1
Posted 2005-07-22 11:00 AM (#28443 - in reply to #28422)
50010025
I have had two go out over the years. When they BEGIN going bad they are hit and miss, truck dying for no apparent reason, but once it is shot to hell it never starts again until replaced.
RTSmith
Posted 2005-07-22 11:57 AM (#28447 - in reply to #28422)
You might check with previous owner & see if it ever had a chip upgrade, ala SuperChips. If so, I've had a loose chip cause this problem. If it has one, take it out & the problem should stop.
RTSmith
MrTruck
Posted 2005-07-22 12:44 PM (#28450 - in reply to #28422)
10001002525
Now that you know where the fuel filter is, you also wanting to drain the water from it monthly. That lever is by the fuel filter. You'll want to put a pan under the engine to catch the water. I'm not sure which manual you have, 3 come with the truck, the one on diesel mainenance is important, which you should be able to get from a Ford dealership or www.Helminc.com is where they get it.
cmdomino2000
Reg. Apr 2004
Posted 2005-07-22 4:03 PM (#28459 - in reply to #28422)
Wow... thanks for all the good advice & tips.
Efaubert1...:  If it's the cam sensor, would that trigger some sort of code thing that a shop could read, that would say that it is the problem?
Charla
efaubert1
Posted 2005-07-22 5:50 PM (#28464 - in reply to #28422)
50010025
Yes, the computer code will come up immediately for them if it has went out, or on and off.
martyg
Posted 2005-07-24 1:22 PM (#28509 - in reply to #28422)
My 99 had the cam position sensor go bad. My engine never died, it would just go to idle, usually when accelerating through 2nd and 3rd gears. When it first started, if I would put the truck into neutral and then the accelerator would seem to work, the engine would rev up and then it would take off again. The sensor never did put any failure codes into the computer so this is not always a valid check. I researched this issue on the web and most all indications were the cam sensor. I purchased it from International for about $85 and changed it myself. Problem went away.
FTguy
Reg. Dec 2003
Posted 2005-07-24 9:45 PM (#28518 - in reply to #28422)
FTguy
Reg. Dec 2003
Posted 2005-07-24 9:48 PM (#28519 - in reply to #28422)
I am not completely familiar with Ford, but a bad CAM sensor will prevent starting. Once it is running, etiher the Engine position sensor or the CAM can go bad and it should still run, but maybe in a limp home mode. Does anyone know if the lift pump is electrical or mechancial? It is electrical, it could be a bad wire.
FTguy
rockyrider
Reg. Jun 2004
Posted 2005-07-24 11:37 PM (#28522 - in reply to #28422)
100100100
Sounds exactly like CPS to me. Here a place with a good price and some helpful instuctions for changing it. Most of us carry a spare in glove box along with tools for the job. Keep reading on dieselsite.com and Ford Truck Enthusiasts site for other helpful maint tips.
http://www.trademotion.com/partlocator/index.cfm?siteid=214083
http://www.ford-trucks.com/article/idx/4/144/article/How_to_change_the_Camshaft_position_Sensor_on_a_73_Power_Stroke_Diesel.html
