Location: Noble IL | CAn you caulk an aluminum trailer roof leak? Or do you have to weld it or something strange like that. I am negotiating for one with leak in the roof. Thanks for any help. |
  Location: Kaufman, Texas | You will probably get a better response on your queston in the Trailer Talk forum. I have not ever repaired any leaks myself but have heard others using caulk with favorable results. |
| If you can locate the leak, caulking it will solve your problem. But keep in mind you will have to re caulk periodically due to weather, UV rays are a bummer not only on us but on vehicles,trailer,barns, everything. |
| You can get Aluminum sealer. You just take a paint brush and paint the roof seams. It only takes about 5 minutes. I got mine at RV supply store. It stopped the roof leaks on my trailer. It was not expensive at all. |
| bell what bell star stuff do you create? the cause of the leak will deside the cure good luck |
Location: Noble IL | I tie rope halters and sell them that is mostly what I create! |
