Hauling Question
brrlrcer3
Reg. Jun 2005
Posted 2005-06-21 8:59 PM (#26902)
Subject: Hauling Question
I have a question!
I have a 2001 Dodge Ram 1500. It is a heavy duty little truck and hauls my two horse steel trailer (GAWR 2500) with two horses really well. So that is around 4500 pulling a bumper pull (with two horses)
I am looking to get a 4 horse gooseneck, but i am not sure of the GAWR, probably around 5500.  Do you think my truck would haul this ok? The people I am buying it from hauled it up to Maine from Tennessee with a truck just like mine and they said they could hardly tell it was there, but they only had furniture in it. Thank you for your input!
Edited by brrlrcer3 2005-06-21 9:00 PM
Reg
Posted 2005-06-21 9:20 PM (#26903 - in reply to #26902)
Subject: RE: Hauling Question
2000500100252525
Hi and welcome to the forum.
This question is asked and answered many times in other threads, but at a quick guess I'd say a 4 horse GN is likely to overload your truck.
The numbers you need for the truck are payload, GVWR and GCWR. The numbers you need from the trailer are GVWR, some reasonable estimate of it's laden weight with the number of horses you will carry and a fair allowance for tack, feed, water, whatever you take with you. Somewhere between 15 and 25% of that total should be "carried" on the gooseneck coupler, your truck's payload capacity needs to be able to take that (unlikely in my opinion with a 1/2 ton truck and a 4 horse GN trailer).
huntseat
Posted 2005-06-21 9:56 PM (#26905 - in reply to #26902)
1000500100100100100252525
I bet my truck on those trailer numbers being over for your truck.  If your trailer states it can haul 10K pounds your truck must also be rated to tow 10K or more.  The law won't care if you never plan on putting all of the 10K pounds in the trailer or not.  You can and may be fined and I believe it's very $$$$$!  Check your state laws and the state laws for any place you'll be towing to and through.
Posted 2005-06-21 10:03 PM (#26907 - in reply to #26902)
Welcome +1
Reg has answered your original question well.
I would add, the largest issue with a light truck hauling a heavy trailer is NOT pulling it, but stopping it.  The engines are powerful, the suspension can be upgraded with air springs, the tranny can get a honking big cooler, etc.  But, You will need to stop it eventually.  You might even want it to stop right now!  But like the Titantic, it will roll on.
TXDressageGrl
Posted 2005-06-21 10:57 PM (#26908 - in reply to #26902)
I personally would not consider pulling a four horse trailer with a 1/2 ton truck. I just purchased a 3/4 ton truck because I did not want to over load my 1/2 ton truck with my new two horse gooseneck trailer. I can't imagine pulling a four horse. However, the tow capacity on my 1/2 ton truck was 6500 pounds - yours may be more. Safety first!
Reg
Posted 2005-06-22 6:46 AM (#26911 - in reply to #26908)
2000500100252525
Originally written by TXDressageGrl on 2005-06-21 10:57 PM
Not disagreeing with you (well, maybe a bit) but the trailer should have brakes that are adequate to stop it.
I've had the plug come out and even with a 1 ton truck (about 7100 lbs) and an empty 4 horse gooseneck trailer (unknown weight, but no LQ) there just aren't enough brakes on that truck for anything more than a modest slowing down. Don't ever count on the truck's brakes to stop anything more than just the truck.
Anyway; I think the priorities are SAFETY, legality, reliability.
The OP should be aware that if overloaded (even if only "technically") one's insurance is likely to be invalidated, which could lead to all sorts of liability issues - as well as another ticket for being uninsured.
Review other posts, get the numbers for your truck and proposed trailer, have the trailer weighed if necessary and weighed at the coupler with a representative load. Going for a more modest trailer or a bigger truck may not be attractive, but could be a lot less expensive than hauling when overloaded.
chadsalt
Posted 2005-06-22 7:18 AM (#26912 - in reply to #26911)
1000100100100100
Originally written by Reg on 2005-06-22 7:46 AM
(well, maybe a bit) but the trailer should have brakes that are adequate to stop it.I've had the plug come out and even with a 1 ton truck (about 7100 lbs) and an empty 4 horse gooseneck trailer (unknown weight, but no LQ) there just aren't enough brakes on that truck for anything more than a modest slowing down. Don't ever count on the truck's brakes to stop anything more than just the truck.Anyway; I think the priorities are SAFETY, legality, reliability.The OP should be aware that if overloaded (even if only "technically") one's insurance is likely to be invalidated, which could lead to all sorts of liability issues - as well as another ticket for being uninsured.
i agree with that. the trailer will have adequate breaks if the axles are not overloaded. the ability to stop the load is one of the deciding factors when the axle is given its weight rating. my axle manual basically says the same thing. never have understood how anyone can think a bigger truck will make a difference, and i hear that alot with my smaller tow vehicle, i have to correct a lot of people. like reg said, pull the plug one time on the bigger trucks and youll see just how much the trailer brakes are doing.
chadsalt
Posted 2005-06-22 8:09 AM (#26914 - in reply to #26905)
1000100100100100
Originally written by huntseat on 2005-06-21 10:56 PM
id like to see that in print if anyone has a link please. apparently texas and detroit can fine me for just going to work....unless its different for a cdl.
hav2ride
Posted 2005-06-22 8:34 AM (#26915 - in reply to #26912)
1000500100100
Bigger trucks = bigger wheels = bigger brakes = better braking.  Of course the trailer brakes are rated for the trailer weight but I sure don't want to depend on just my trailer to stop my rig.
barry
Posted 2005-06-22 8:38 AM (#26916 - in reply to #26902)
In Missouri you are required to "tag" your truck based on total weight of truck and any trailer/load you have attached. They have 6,000 lb tags and 12,000 and over tags. Should you be weighed you can be in violation of not having the proper tag. They allow you to tag a 1/2 ton truck with a 12,000 tag because my wife purchased my first tag and thought that is what we needed. They do have two other categories for each of these weights - local meaning generally used in a 50-mile area and non-local. How this is enforced I have no clue. I check and you can drive further than 50 miles as long as it is not on a regular basis???
I have never heard of anyone being fined for their truck being under-rated for the load. I have never seen a 4-horse trailer stopped at a truck weight station either.
hav2ride
Posted 2005-06-22 8:52 AM (#26918 - in reply to #26916)
1000500100100
I personally know of some people who were stopped and fined.  Also, depending on the state, you are required to stop at the border and show health papers.  I don't think it's wise to be over the limits then either.
FordLvr
Reg. Jun 2005
Posted 2005-06-22 9:17 AM (#26920 - in reply to #26902)
I've pulled all kinds of trailers with all kinds of trucks. My biggest concern is emergency steering and stopping!! Most newer full size trucks have the power and suspension to handle the work and if not, after market products can beef any truck up to pull the load and take the weight but stopping the load, especially in an emergency situation is my biggest fear. After many trucks and many trailers we settled on a 4 horse slant load goose neck and a F350 dually. The truck is 11 years old and I got it for less that 8,000 dollars. Having that extra rubber on the road and wide rear end has made a difference as clear as night and day. While I always try and leave enough room to/for emergency steering/braking without hurting the horses, there is always that unexpected moment. I have talked to several people who have over turned their trailers in emergency situations by having their trailer brakes set to strong to compensate for a smaller truck or lost control from swerving to avoid collision. While it is always safer to leave room and drive slow, with the wide rear end of a dually and extra rubber on the road, I know from experience that it is the most stable and controllable truck to pull with. We had to settle on an older used truck because of the cost of dually's but better to be safe when comes to our family and horses
Edited by FordLvr 2005-06-22 9:20 AM
laxpatrick
Posted 2005-06-22 12:02 PM (#26930 - in reply to #26902)
As long as you're in tow/haul you should be just fine.
Just kidding.
Seriously, I wouldn't do it. You'd be overloaded and such a light truck isn't designed for such a load (also consider that your tires may be over their capacity, your axle isn't designed for that load, and a multitude of other factors).
Recommendation: 3/4 ton or larger. Preference for diesel. Opinions only of course. You'd need to run the mfg number to get the "facts".
chadsalt
Posted 2005-06-22 1:43 PM (#26934 - in reply to #26915)
1000100100100100
Originally written by hav2ride on 2005-06-22 9:34 AM
not exactly, bigger trucks mean more weight to stop when loaded to GVWR, basic physics dictate it will take longer to stop..........bigger wheels actually mean less leverage for breaking(more mass and rotating mass which is some of the reason it needs a bigger brake to start with) which may or may not matter depending on avaliable traction............and you can only fit a brake so large under a 16, 17inch wheel, i have discs just under 13" on the front and just over 13" on the back by my tape measure.
ill wager theyre not much bigger on a 1 ton. you can also only have so much "swept area" and granted a thicker disc will have more "heat sink" capability but now were getting really technical. and i wouldnt expect the trailer to stop the truck, just like the truck alone wont stop the trailer very well. both vehicles have their own brakes designed to stop their respective selves.
Edited by chadsalt 2005-06-22 5:40 PM
Terri
Posted 2005-06-22 2:17 PM (#26936 - in reply to #26905)
200050010010010025
Before I made my trip to NM I e-mailed the state troupers office (looked up their web site) and asked this quiestion.
The official response I got that the "possible" weight for the trailer/loa
With the weight ratings you provided, the driver is not required to have a
CDL, as long as the actual combination weight does not exceed 26,001 lbs
inclusive of a trailer greater than 10,001 lbs or more.
There is no problem with the weight of the vehicle as the actual weight being displaced on the vehicles is what determines the violation. This allowable weight is determined by axles and axle configurations and tire rating. So as long as the actual weight of the vehicles does not exceed the allowable gross weight allowed or the tire ratings, you should have no problems. Just keep in mind that even though your trailer is rated  at 14,000 lbs most of that weight will actually be distributed to the axles on the trailer with some portion distributed to the towing vehicle. As far as carrying livestock (horses) if you are traveling to NM for work then you would be considered in commerce (private carrier as you only transport your commodity, i.e. horses used in your job) and would be subject to Federal Motor Carrier Safety Regulations parts 390-399. If you are not “working” and do not use your vehicles for work then you are OK.
  I have a 1/2 ton Dodge with a 10,000lb trailer limit and a 4 horse slant.  I brought my 2 mares up with me and was not over on anything.  I was close, but legal.  Not that there were any scales open.
huntseat
Posted 2005-06-22 4:29 PM (#26942 - in reply to #26902)
OK, let me play "bad barn buddy."
You have a truck and 4 horse trailer.  You only plan on hauling 2 horses which may put you right at your limit.
"What are you going to do with the other two slots?  Can you take my horse?"
Yes, puts you over the limit and I'm not paying for damages...your warranty will be voided if they think you were over weight, so the maker won't pay either FYI.
No, pisses off your riding buddies because you are dragging around dead space.  The temptation to bring along another horse may be too much for you.  Worst case you'll buy another horse and now be really stuck.
Flooper
Posted 2005-06-22 4:49 PM (#26943 - in reply to #26902)
I don't see how you can make it work. I've got a 2000 Dodge 1500 Quad Cab 4WD (mechanically identical to the 2001s), and pull a similar 2H Bumper pull like you. I looked at 3H goosers, and just couldn't find one that I could really make the numbers work with. Heres' why:
My GVWR is 6600 lbs.
My ACTUALl truck weight with full fuel, my wife, me, and a few things in the bed of the truck is 5600 lbs. That leaves only 1000 lbs for payload on the truck. (6600-5600)
A typical 3 or 4 horse gooseneck weighs between 5500 to 6500 lbs empty, plus 2 horses at 1100 lbs each adds up to a typical trailer weight of around 8000 lbs. Take 20% of that as pin weight (1600 lbs) on the truck, and I'm way over the 1000 lb payload left on the truck.
Maybe you have a lighter truck (no Quad Cab and 2WD) or are looking at a much lighter trailer than I used in my example, so you could conceivably have another 500 or 600 lbs. of payload than I do...in which case you could probably make it work as long as you only carried 2 horses...but you sure would be pushing it. Just my 2 cents worth.
hav2ride
Posted 2005-06-22 7:55 PM (#26947 - in reply to #26934)
1000500100100
I personally KNOW that bigger wheels = better braking.  I had an F350 dually that I pulled a 29' box 3 H, mid tack, and LQ with.  I traded to an F450 because of the safety and legal issues.  The larger wheels/brakes on the F450 can stop my trailer on it's own, not that I would want to haul that way.  Pulling a 4H with a 1500 is just not safe in emergency situations.
chadsalt
Posted 2005-06-22 8:31 PM (#26949 - in reply to #26947)
1000100100100100
Originally written by hav2ride on 2005-06-22 8:55 PM
the smaller wheels and brakes on my pitiful little trailblazer pulling my 2h sl bp (yes im at the max GVWR) will also stop me. what is your point? are you saying your trailer brakes are or are not functioning properly? i dont understand the point of that statement.
and why is a 1/2 ton with 4h not safe IF it could be managed to the GVWR? say it is a light trailer and 2 small type horses.  youre making a rather broad statement that appears as though youre stating fact. and if, just if, you do mean it as fact....your implied experiance is showing. but if not intended as fact....then i apologize.
brrlrcer3
Reg. Jun 2005
Posted 2005-06-22 9:03 PM (#26950 - in reply to #26902)
Thank you everyone for your input.  The trailer I was looking at was sold, but I take it as a sign I wasnt supposed to buy it.  I will look into getting another truck before the trailer.  Thank you again for all the information, I will print this out for later use!
Terri
Posted 2005-06-23 4:33 PM (#26986 - in reply to #26942)
200050010010010025
I don't haul for other people.  I have 10 acres so there is no "barn buddy" and I go to the large organized rides were I know some people but everyone has their own rigs.   I have also seen people turn flatbed trailers into animal trailers by adding cattle pannels to them.  But they had a 1 ton truck.  And if your friendships are so fragile that saying no to something causes a problem, well....   People ought to be able to understand why you don't want to haul illegal without being offended.
I drove to NM in May and I weighed my trailer/truck fully loaded to make absoultely sure that I wasn't over my limits.  I had wanted to bring about 20 bales of coastal hay with me but having them in the front of the trailer would have put me over so I left them.  I was close, but under and had no problems going over the hills on I10.
Flooper
Posted 2005-06-23 5:09 PM (#26988 - in reply to #26902)
Terri,
Just curious (dont' take offense!!). What is the configuration of your Dodge 1/2 ton Ram that you have a 10,000 lb tow rating? My 2000 Quad Cab 4WD with the 5.9L and 3.55s is only rated to tow 7200...the highest rating I've seen for a Dodge 1/2 ton is 8900 lbs.
hav2ride
Posted 2005-06-23 7:44 PM (#26997 - in reply to #26949)
1000500100100
My trailer brakes function just fine, thank you.  My point is that it is not advisable to tow to the max.  Now, I know that you enjoy doing that and no one will ever convince you otherwise, but I don't think it is in the right to tell people who are inexperienced at hauling to tow near or at the max.  By the way, a few weeks ago, my brother saw an Explorer hauling a flat trailer with a car and a small boat on it  lose control because the trailer started swaying back and forth.  The trailer hit the guard rail and fliped over and the car and the boat were destroyed.  My brother watched the whole thing and said that the trailer sway caused the whole accident.  And there was no live weight on that trailer. If you want to be at the max, fine.  I just don't think you are doing the right thing by advising other to do the same.
Terri
Posted 2005-06-23 10:03 PM (#27010 - in reply to #26988)
200050010010010025
I have a 2003 2WD.  I'll have to wait until the sun comes up to get the numbers for you.  But I got the 10,000lb rating out of my manuel and e-mailed Dodge to confirm it.  I thought maybe it was a typo but they looked up my vin# and confirmed it.
chadsalt
Posted 2005-06-23 10:06 PM (#27011 - in reply to #26997)
1000100100100100
Originally written by hav2ride on 2005-06-23 8:44 PM
first of all i do not advise anyone to tow at the GVWR, aka the SAFE max allowable limit set by the people who know...the manufacturer.  i only point out it CAN be done safely.  if you are not comfortable doing so, that is of course your business. however you are expressing your opinion as if it is fact,  i am stating facts when referring to the limits set by the manufacturers, they are more qualified than you or i to set that limit.
i dont think its right, or safe, for the untrained (and years of towing dont make up for training) to get behind the wheel of 12000+ pounds and start driving, PERIOD. but you dont hear me telling them, or you, not to do it.  doing so would be elitist and arrogant. i do emphasize safety and instruction though.
and btw the trailer sway did not cause the wreck, the driver did.  the trailer is an object, it can not do anything by itself.  the driver made a mistake or possibly a series of mistakes that led to the wreck, mistakes very likely including getting behind the wheel. we need to take responsibility for our own actions, and the line of thinking...... "the trailer sway caused the whole accident."..... is not.
xyzer
Reg. Apr 2004
Posted 2005-06-27 10:00 AM (#27200 - in reply to #27010)
Originally written by Terri on 2005-06-23 8:03 PM
HMMMM.....!! Terri I have a 2003 2500 4x4 auto 3:73 CTD and I think you have a higher tow rating than mine.....???? I think my manual said 9,980 or there abouts....I think I'll go look at it again...
http://dodgeram.info/2003/load-tow/2500.html
http://dodgeram.info/2003/load-tow/1500.html
I guess mine is 10,800....but yours is a bit less??!
Edited by xyzer 2005-06-27 10:25 AM
Reg
Posted 2005-06-27 6:42 PM (#27248 - in reply to #26947)
2000500100252525
Originally written by hav2ride on 2005-06-22 7:55 PM
Ummm, UNLIKELY ! (that your F450 can stop a trailer (that probably outweighs it) in a reasonable distance using only the truck's brakes.)
Physics 101: Coefficient of friction and his/her buddies are against it.
With the truck alone on a good flat dry surface you MIGHT get to 1.0 G decel, but that requires all the mass being slowed to be ON the braking wheels.
With a (brakeless) trailer attached you have less than half the total rig's mass on the slowing wheels - ABS or locked 4 wheels, it just ain't gonna stop as quick.
It will stop, eventually, but it will be a long one.
I'm just guessing that your F450 is a bit lighter than the trailer you cited, it could be less or equal, but as a first approximation you only have half the mass to be stopped weighing down on the stopping wheels, so it doesn't matter how much "better" your brakes are, you just don't have the grip.
None of this should matter, the trailer has to have adequate brakes to stop it, so does the truck. In the event of trailer brake failure you would run into trouble quicker with the lighter vehicle - for SURE !
chadsalt
Posted 2005-06-27 7:02 PM (#27249 - in reply to #27248)
1000100100100100
Originally written by Reg on 2005-06-27 7:42 PM
Originally written by hav2ride on 2005-06-22 7:55 PM I personally KNOW that bigger wheels = better braking. I had an F350 dually that I pulled a 29' box 3 H, mid tack, and LQ with. I traded to an F450 because of the safety and legal issues. The larger wheels/brakes on the F450 can stop my trailer on it's own, not that I would want to haul that way. Pulling a 4H with a 1500 is just not safe in emergency situations.
Ummm, UNLIKELY ! (that your F450 can stop a trailer (that probably outweighs it) in a reasonable distance using only the truck's brakes.) Physics 101: Coefficient of friction and his/her buddies are against it. With the truck alone on a good flat dry surface you MIGHT get to 1.0 G decel, but that requires all the mass being slowed to be ON the braking wheels. With a (brakeless) trailer attached you have less than half the total rig's mass on the slowing wheels - ABS or locked 4 wheels, it just ain't gonna stop as quick. It will stop, eventually, but it will be a long one. I'm just guessing that your F450 is a bit lighter than the trailer you cited, it could be less or equal, but as a first approximation you only have half the mass to be stopped weighing down on the stopping wheels, so it doesn't matter how much "better" your brakes are, you just don't have the grip. None of this should matter, the trailer has to have adequate brakes to stop it, so does the truck. In the event of trailer brake failure you would run into trouble quicker with the lighter vehicle - for SURE !
youre wasting your time reg.  physics elude some people. and again we are splitting hairs, but i have nothing better to do.
if i remember correctly most unladen pickups stop from 60 mph around 150 feet a full grown 18 wheeler @80000# needs around 350 feet.  im guessing the loaded trucks were talking about fall somwhere in between. so again im speculating, were only talking about a few feet either way, between small horse rigs vs. larger horse rigs. and im still holding to heavier GCWR taking longer to stop.
i will disagree, partly, with the "trouble quicker with the lighter vehicle" statement though.  the lighter vehicle will not have any heavier a load in relation to its own weight. in fact it will likely be less percentage than the heavier 1 ton.  and again it also has less total weight to stop with probably similar sized brakes.
1/2 ton 5200# 9300# trailer = 9300/5200=1.78
1 ton 7500# 15600# trailer =15600/7500 =2.08
 the only technical advantage may be in the dually with the 2 extra contact patches.  the tires on even the smaller trucks are still in the 245mm width.
the 450 does have 15" rotors as compared to 13" on the smaller trucks. this would likely make some difference when switching from "to heavy for 350" that would be at the bottom of the 450's load capacity. which in turn would be like saying my truck stops better with a lawnmower on a utility trailer than it does with my 6000# horse trailer.  and you could go a little farther and say my truck stops really well with no trailer, does that make it safer?  (well actually it does.) an accurated statement, but not really relavant.
Edited by chadsalt 2005-06-27 7:19 PM
Terri
Posted 2005-06-27 9:44 PM (#27254 - in reply to #27200)
200050010010010025
My owner manuel says 10,000 lbs.  I don't know, but I've read on here that 4x4 adds more weight and maybe that could be the difference?
Terri
Posted 2005-06-27 9:50 PM (#27255 - in reply to #27200)
200050010010010025
 sorry, posted twice.
Edited by Terri 2005-06-27 9:53 PM
hav2ride
Posted 2005-06-28 8:22 AM (#27264 - in reply to #27248)
1000500100100
Wanna come and see for yourself?  Now, There's no way that I would ever drive that way because I would destroy my truck brakes.  But I have tested it on my property by taking the rig off the field where we park it, down the bank to the driveway, and it does stop it easily.  I do this so that the damp trailer brakes don't lock up on the grass and destroy the grass.
chadsalt
Posted 2005-06-28 8:49 AM (#27265 - in reply to #27264)
1000100100100100
Originally written by hav2ride on 2005-06-28 9:22 AM
like i said, i dont doubt it stops better(and better is relative, meaning in this situation "not much") than the 350, but thats because youre not working it as hard. but exactly what kind of "test" is that? im guessing youre not running 60mph in the field down the bank to the driveway.
Edited by chadsalt 2005-06-28 8:52 AM
xyzer
Reg. Apr 2004
Posted 2005-06-28 10:46 AM (#27269 - in reply to #26902)
A PANIC do or die STOP (like to hell with the animals I gotta stop....now!) in a full loaded situation on 6% downhill @ 55mph It will feel like it speeds up the closer you get to the target! Cause it kinda does! (been there)!The brakes on everything are extremely HOT! Then they fade! Now what? That happening without trailer brakes would be ...well... not fun!  My concept on the design is the truck brakes are sized to handle the trucks maximum payload not the trailer. Now I would haul a heavy trailer around the local area with no brakes, and drive like I had none...cause if somthing happens.....I really don't!
hav2ride
Posted 2005-06-28 11:09 AM (#27271 - in reply to #27265)
1000500100100
Oh, it's much better than the 350 was with the same trailer.  The 350 could do it but I did feel like the trailer was really pushing the truck and I had to put heavy pressure on the brakes.  The 450 handles it with ease.  Whether or not you believe what I say is irrelevant to me.
chadsalt
Posted 2005-06-28 11:09 AM (#27272 - in reply to #27269)
1000100100100100
Originally written by xyzer on 2005-06-28 11:46 AM
good post, i like to point out, though it looks like you already found out..........55mph is WAY to fast on a 6% grade if your vehicle is loaded heavy. for that matter 55mph is plenty fast period, unless youve got a big stretch of open interstate.
Edited by chadsalt 2005-06-28 11:13 AM
chadsalt
Posted 2005-06-28 11:17 AM (#27273 - in reply to #27271)
1000100100100100
Originally written by hav2ride on 2005-06-28 12:09 PM
im not questioning you, just your interpretation of the situation.
xyzer
Reg. Apr 2004
Posted 2005-06-28 11:21 AM (#27274 - in reply to #26902)
The point was a full load in a panic stop at any speed up or downhill 25-65mph will make you wish you had more brakes! Remove the trailer brakes and oh Sh*t! .....the first liar never has a chance!
HaulinHorses
Reg. Jul 2004
Posted 2005-06-28 11:49 AM (#27277 - in reply to #26902)
Maybe this is a dumb answer, or maybe it's too obvious, but I see a lot of horse folks come on this board (and on the trailer lot!) trying to match up a 1/2 ton or 3/4 ton truck with too big of a trailer.....So, instead of crunching numbers, if you want to safely haul your horses, why don't you just go trade for a 1 ton truck and be done with it???
I think if you can afford to own horses, and land, or board a horse, buy feed, equipment, entry fees, fuel, vet bills, trailers, etc, then surely you can afford a truck that hauls them safely.  I wouldn't own a 1/2 ton truck and pull ANYTHING bigger than a 2 horse BP trailer with a horse in it...sorry, but JMO.  Flame away, I have a tough hide.
xyzer
Reg. Apr 2004
Posted 2005-06-28 12:29 PM (#27282 - in reply to #26902)
Cindy
No flame here!....I agree....This thread got side tracked.....and I even helped!
gabz
Posted 2005-06-28 12:36 PM (#27283 - in reply to #27277)
1000100100100252525
Cindy of Oklahoma posted:  "So, instead of crunching numbers, if you want to safely haul your horses, why don't you just go trade for a 1 ton truck and be done with it??? "
And, as I have said before, will you make my truck, fuel, registration, and insurance payments?
By the way, I drive 44 miles round trip, everyday, for work. I only have 1 vehicle. If I had a bigger truck, I couldn't afford to have a horse and go anyplace.
Erin_CBT
Reg. Jun 2005
Posted 2005-06-28 12:46 PM (#27286 - in reply to #26902)
If you can't pull safely, DON'T PULL! That's really the bottom line. If you are worried about your truck pulling the trailer, maybe you should take it for a "test pull," most dealers will let you.
I'm not an expert on any of this, but most 19 year olds aren't. That's why I'm not saying yes or no, but it seems to me there are some people here that think they know way to much (or at least more than what they DO know). I would rather take advice from someone who has a cdl or drives trucks/trailers for a living than some know-it-all who pulls a few times a month which makes them an "expert." If you think bigger is better, more power to you, but it seems like a pretty general idea that may not always be true.
Also, just for the record: Financing for a brand new truck with no trade and no down payment: I figured using prices from a 2005 Dodge 3500 and a 2005 Dodge 2500 and a payment calculator on Fifth Third's website and the difference between the two was a whole $68.00. Doesn't seem like a whole lot to me when it comes to the safety of my horse!
Just my two cents, I'm sure some of ya'll think different, but I suppose that's why we live in America!
Edited by Erin_CBT 2005-06-28 12:59 PM
chadsalt
Posted 2005-06-28 12:48 PM (#27287 - in reply to #27277)
1000100100100100
Originally written by HaulinHorses on 2005-06-28 12:49 PM
no its not a dumb answer, but a 1 ton is certainly overkill for my 6000# loaded trailer. although ill have one directly as a 3rd vehicle, like you said "and be done with it". i dont and never will need a larger trailer, just me and the wife and the camping days are long over....but just in case. as for the other people(and myself at this present time) its simply not always fesible or necessary to have a 1 ton. skill, experiance, and personal saftey comfort levels are also different. they ride like crap so if its your primary ride that is a big turn off. additional taxes, fuel, inital investment etc all also add up. i do agree though, that the people with the larger trailers wondering if they can get by......if you need/can afford that large a trailer a larger truck is not that much more of an investment.
chadsalt
Posted 2005-06-28 12:51 PM (#27288 - in reply to #27286)
1000100100100100
Originally written by Erin_CBT on 2005-06-28 1:46 PM
I'm not an expert on any of this, but most 19 year olds aren't. That's why I'm not saying yes or no, but it seems to me there are some people here that think they know way to much (or at least more than what they DO know). I would rather take advice from someone who has a cdl or drives trucks/trailers for a living than some know-it-all who pulls a few times a month which makes them an "expert." If you think bigger is better, more power to you, but it seems like a pretty general idea that may not always be true!
dont sell yourself short, it may only take a few years to learn, some people catch on faster.......after all this is not rocket science.
Terri
Posted 2005-06-28 3:59 PM (#27306 - in reply to #27286)
200050010010010025
It's not just the $68 a month.  There is the difference between what is owed on the old truck and the trade in value, which is added to the new truck and the extra year of payments.  The extra gas driving 30 miles one way to go to work and finding a parking space at work.  I would love to have a bigger truck, but right now its not possible and since (according to dodge) I am not overloading my truck, it will have to do.
hav2ride
Posted 2005-06-28 8:22 PM (#27321 - in reply to #27286)
1000500100100
Just for the record, so you know my trailering background.  My husband started driving trucks for the business he now owns when he was in his teens.  He hauled lots of weight on a variety of roads in a variety of conditions including snow and ice.  When I started hauling horses, he taught me how.  I have been hauling horses, most times long distances, for about 27 years.  I also learned a lot from a truck driving friend who learned the ropes from her truck driving father and had a hauling business with her husband.  She has also hauled horses and has a tack store that she takes to shows.  She actually used to post here on this site but pretty much got tired of the "stuff" that goes on here.
chadsalt
Posted 2005-06-28 10:04 PM (#27326 - in reply to #26902)
1000100100100100
and i really dont have anything better to do.
crowleysridgegirl
Reg. Apr 2005
Posted 2005-06-28 11:39 PM (#27335 - in reply to #27272)
2000500100
Excellent point,chadsalt!I meet trailers all the time,heck bent for Georgia,though.They rival some 18 wheelers for speed.
chadsalt
Posted 2005-06-29 7:56 AM (#27347 - in reply to #27274)
1000100100100100
Originally written by xyzer on 2005-06-28 12:21 PM
well i dont know about that. 25 mph with a load and you should have more than suffiecent braking ability, thats the whole reason speed is supposed to be reduced. i was a little confused as to your point, your example was using a person already making a mistake. if i remember correctly the tractor/trailers are recommened to descend 6% at 35mph. but youre right, no trailer brakes would be a problem.
Edited by chadsalt 2005-06-29 7:58 AM
Erin_CBT
Reg. Jun 2005
Posted 2005-06-29 11:03 AM (#27360 - in reply to #26902)
The only point i was trying to make with the figures is can you really put a price on the safety of your horse? If you don't need a one ton, great, but some do even though they won't admit it.
gabz
Posted 2005-06-29 12:19 PM (#27368 - in reply to #27360)
1000100100100252525
Erin -
While $68 a month for 5 years might not seem like a great deal regarding the safety of my horse... I must also consider all the other related factors as others have previously pointed out. A larger vehicle means MUCH higher insurance payments, higher registration costs, more fuel (and it's not just the money of more fuel... it's all the political crap that the reliance of more fuel puts on the US and the world).
$68 a month would help me pay for a better barn that would be safer for my horse than the 150 year old one that threatens to drop on his head whenever there's a big snow storm.
$68 a month pays for my cell phone that provides safety for ME - a person living alone and on the road more than 2 hours everyday.
I trailer my horse about 10 - 15 times a year. The truck I have rides so rough when it's empty - it sucks. It's a half-ton with a tow rating of 9300 pounds. I do my best to keep my towed load under 8000 pounds.
Life is all about compromise (give & take) and taking responsibility for our actions. So, for many folks, using a 1/2 ton and towing something that's UNDER the manufacturer's stated limits and within a certain margin for error, is the compromise that we make. Knowing that we have to take responsibility for those actions. It's those that won't accept the responsibility of their risk taking that causes the lawsuits and similar stupidity in the world.
Erin_CBT
Reg. Jun 2005
Posted 2005-06-29 12:24 PM (#27369 - in reply to #26902)
Gabz-
I agree that compromise is important, and that's why i said that for those of you that DON'T need a bigger truck, great. I understand what you are saying and i agree, i just think that you misunderstood what i meant.
for someone like you that pulls 10 - 15 times a year, what you have is fine. But for someone like me that shows 40 out of 52 weekends a year, most of the time traveling by interstate, a bigger truck that can safely pull AND STOP my rig is a must. happy trails to you and your horse.
Edited by Erin_CBT 2005-06-29 12:31 PM
RichB
Posted 2005-07-01 11:52 AM (#27484 - in reply to #27011)
10010010025
Accidents or a series of mistakes or whatever you want to call it,  will happen.  Humans make mistakes.  A bigger truck can give you a safety margin to recover, if stuff happens. If the driver of the explorer was in a bigger tow vehicle, like a dually, that trailer wouldn't have had the deadly effect it did on a small, lighter vehicle.  I towed a car trailer that empty, started swaying over 55mph.  In my dually, it's irratating.  Behind my 1500 Suburban, it could be deadly.   So, IMO, buying a vehicle that allows you a greater safety margin is never a bad idea.
hav2ride
Posted 2005-07-01 12:10 PM (#27485 - in reply to #27484)
1000500100100
 "So, IMO, buying a vehicle that allows you a greater safety margin is never a bad idea."
Exactly!  I just can't understand how there is any argument over this!
chadsalt
Posted 2005-07-01 12:33 PM (#27486 - in reply to #27484)
1000100100100100
Originally written by RichB on 2005-07-01 12:52 PM
um ok, no one is disputing that its a bad idea, just is it any safer? and im not sure using a malfuctioning trailer is a good example. if it sways over 55 then get it fixed, or dont go over 55. of course if you think running substandard equiment is acceptable then by all means, do what you feel necsessary. btw that is an impressive horse in your photo.
Edited by chadsalt 2005-07-01 12:45 PM
hav2ride
Posted 2005-07-01 12:50 PM (#27487 - in reply to #27486)
1000500100100
 "and im not sure using a malfuctioning trailer is a good example."
Where in Rich's post does it state that the trailer was malfunctioning?  A trailer can be in perfect shape and still sway if the conditions are right for it.  A driver can't control wind shear, pot holes,  tractor trailer drag, etc.  Antisway bars help but are no guarantee.  As for only driving 55mph, do that in a 65 - 70mph area and you'll be pushed off the road or even ticketed for not going near the speed limit.  A larger tow vehicle does make a difference.  But you'll find that out when you get your 1 T.
chadsalt
Posted 2005-07-01 1:01 PM (#27489 - in reply to #27487)
1000100100100100
Originally written by hav2ride on 2005-07-01 1:50 PM
as i understood(which could be wrong) he said it swayed over 55mph. i took that as all the time, like i said maybe i misunderstood. "As for only driving 55mph, do that in a 65 - 70mph area and you'll be pushed off the road or even ticketed for not going near the speed limit." i do this everyday at work in a tractor tailer. never been ticketed. also do so in my baby horse rig, again, never been pushed off the road or ticketed. as a matter of fact i may video tape my next trip and as im running 55mph straight down the interstate with no hands on the steering wheel as a tractor tailer passes me at 70mph maybe you might see something of interest. maybe im just to small to get caught in the turbulence.........right. and are the newer 1 tons different than the ones from years ago? didnt think so.....guess theres nothing for me to find out then. im actually expecting a little more sway possability with the 1 ton as i likely wont mess with the equal-i-zer hitch im using now.
Edited by chadsalt 2005-07-01 1:36 PM
Terri
Posted 2005-07-01 2:33 PM (#27498 - in reply to #27484)
200050010010010025
Most car trailers manuels tell you not to go over 50mph.  Some even have a sticker on the fender that you can read in your rear view mirror.
RichB
Posted 2005-07-01 2:35 PM (#27499 - in reply to #27489)
10010010025
The trailer was rented from United Rentals, a national equipment rental yard.  Perfectly working bumper pull trailers sometimes sway, for various reasons, it could be speed, the road, highway traffic, wind, load, etc.  This trailer would sway over 55 mph, like at 56 mph.  The point is, we don't live in a perfect world where everything works perfectly and we operate it perfectly.  So allow yourself some wiggle room when you choose a rig for your trailer. Better to have excess capacity than be at or over your limit everytime.   That's an ideal.  Course we have to do the best we can with what we have.
Edited by RichB 2005-07-01 2:48 PM
hav2ride
Posted 2005-07-02 8:48 AM (#27515 - in reply to #27499)
1000500100100
"We are truck shopping and the first thing every GOOD dealer we have gone to asks is what will you be pulling? A 3 horse aluminum with one horse. ALL have said definitely not to the half ton. They all say the same thing, you can do it and dealers will tell you it's O.K. but it really isn't. I like those dealers and don't trust the ones who just worry about the sale. Normal driving, stopping O.K. but what about the unexpected!!!! Be safe and don't undertruck. While we were at one dealer an SUV went by pulling a trailer with a horse in it and when the light changed unexpectedly he really took time to get it stopped. He is probably so used to it he doesn't know the difference so he would say it hauls just fine. We all know people who do it and get by but the question is do we want to do it if we can get along with it or do we want to be as safe as we can be in case something does happen."
This was posted on the Pleasure Horse message board.  Thought it was timely.
 Here's another from the same thread.
42014.32 in reply to 42014.1
"This is to all, really.... My DH is a firefighter and he comes comes home with stories of wrecks that he has gone to and had to "clean-up" the messes of those who insist on using under rated trucks to tow with and just not horse trailers either...travel trailers, boats, utililty trailers etc.... just seeing the pictures that he has to take for reports and having to listen to him talk about having to cut people out of their trucks (or worse the innocent people that up getting caught up in the accident) or picking up body parts (and I am not talking about truck and car body parts either.... You would change your mind on using 1/2 tons to pull even 2 horse trailers with... *You* might think that you have enough stopping power....Just see what happens when someone cuts in front of you and the roads are wet and slick and you are coming down a hill......"
Edited by hav2ride 2005-07-02 8:50 AM
hconley
Reg. Feb 2005
Posted 2005-07-02 9:38 AM (#27520 - in reply to #26902)
I've come across alot of wrecks over the years and most are caused by one or a combination of the following:
7  Driver inexperience - Countless times I have seen a wheel drop off the side of the pavement and the first thing they do is stand on the brakes.
7Poor maintenance of equipment - either/both the tow or the pulling vehicle
7Improper loading - an imbalanced load and we'll see you in the ditch
know your limitations, have a safe trip
Edited by hconley 2005-07-02 10:00 AM
chadsalt
Posted 2005-07-02 10:18 AM (#27521 - in reply to #27515)
1000100100100100
Originally written by hav2ride on 2005-07-02 9:48 AM
ah yes, ive been waiting for the "red asphalt" approach.
hav2ride
Posted 2005-07-02 12:56 PM (#27523 - in reply to #27521)
1000500100100
So you think it's all a lie??
chadsalt
Posted 2005-07-02 1:58 PM (#27524 - in reply to #27521)
1000100100100100
Originally written by chadsalt on 2005-07-02 11:18 AM
i think its just more opinons. i was only commenting on how the talk had turned "bloody".
what kind of suv? how long is long? is this person qualified to judge a long stopping distance from the side of the road....i doubt anyone is. may have taken longer/gone a little far into intersection for the horses benifit.
as for the wet road on a hill....ill leave the physics out this time and just say, i guess ive got in made in my tractor trailer at work then.  got all those big wheels and brakes, must be like dropping an anchor when i stop. (sarcasm intended)
unlike that person(and some others) i know what happens when i stop in the rain, the truck stops. this is accomplished with adjusted speed for conditions, and has nothing to do with any vehicles capabilitys. and i mean for crying out loud....a wet road!! just about any piece of crap truck/trailer will lock the wheels in the rain, at that point you have little or no slowing of the rig being acomplished.
most of these examples only display the level of skill/understanding of the indiviual doing the talking.
JMO
hav2ride
Posted 2005-07-02 2:31 PM (#27525 - in reply to #27524)
1000500100100
I understood the "red Asphalt" comment.  But you disregarded the point about the wet roads.  The OP commented that she would rather have more than minimal stopping power, which is provided by having a larger truck, when something cuts in front of you on a wet road.  Of course you should drive for conditions but unexpected things happen which can cause an accident if not properly equipped.  I know my 450 stops my trailer much better than my 350 did but I still drive defensively.  You'll see a huge difference when you tow your 2H with the 1T.  But I doubt that you'll ever admit it.
chadsalt
Posted 2005-07-02 3:16 PM (#27526 - in reply to #27525)
1000100100100100
Originally written by hav2ride on 2005-07-02 3:31 PM
i still think youre unclear as to my experiance, you seem to be under the impression ive never hauled with anything other than what i have now.....anyhow i dont doubt it will tow "better(definitions will vary)", it will likely be only half the 1 ton capacity.  what happens when i load the 1 ton up with a big GN? ill be right back where i am now. sure id be "safer" with a lawnmower behind me, and id be "safer" yet with no trailer at all, so would your f450.  "saftey", at the level youre trying to discuss it at, is a moot point.
heres an example, i ride sportbikes, have done so for years. i follow the trends, specs, races etc.  now i frequently engage in discussions with people about which bike in the open class is best.  all these bikes track times are often seperated by less than tenths of a second. does this matter in the real world? absolutly not. is one better than the other? only in the eye of the beholder.
this is the same discussion we keep having, but like i said i dont have anything better to do. its too hot for me to ride.
Edited by chadsalt 2005-07-02 3:17 PM
Posted 2005-07-02 3:55 PM (#27527 - in reply to #27521)
"The Red asphalt approach"
Chadsalt: either you seem to miss the point or you're inured to highway accidents.
It's not for the low fuel mileage a larger truck is used to tow with.  Nor is the higher cost of the heavy truck used to impress the neighbors.  Or the hike from the far corners of the parking lot needed for one's health & fitness because the dually doesn't fit the drive through.  The whole point of under using the truck's tow capacity is avoiding the "red asphalt"
I would expect your attitude toward other drivers on your job and hauling your horses as "Me first, the devil take the rest of ..."
To the lurkers and newbies looking for guidance:
Avoiding "red asphalt" is really what we're talking about.  The other drivers on the road don't care that you're hauling 10,000 pounds of horses and trailer behind you.  I've seen many driver's dive into a space in front of OTR semi's just to cut into a line for the exit.  They are oblivious to the semi's 80,000 pounds mere feet away from crushing their car.
They won't think about you either, maybe less since you're only a little suv.  The horse trailer is not even in their mind.
They WILL pull out in front of you when you least expect it.  You make your choice here and now.  It'll be too late to change when it happens.  And it will.
chadsalt
Posted 2005-07-02 4:32 PM (#27528 - in reply to #26902)
1000100100100100
well now, if i could be offended, that may have done it. my attitude while driving at work is purely professional.....no middle fingers, no air horn blowing, courteous to the fact the 4 wheeler blocking my wide right turn has no idea theyre doing so. i generlly drive well under the speed limit, legally you can not run the speed limit while pulling a trailer(this is a whole other can of worms.)  and i drive the same way no matter what car, truck, etc i happen to be driving.
when i hear someone talking about how they were "pushed" though an intersection, or almost ran into the back of someone, or i just couldnt get stopped, i can all but guarantee that their experiance is lacking. barring equipment failure, they were simply traveling too fast, their attention wandered, or are not used to compenstating for a trailer behind them.
so until someone sets up a scientific test with cones and mesurements, several size test vehicles loaded to their respective GCWR with horse simulators, etc. and puts an end to this speculation and opinon......... ill just have to say, everyone be carefull. and to the guy who just cut me off,  i knew you were going to do that.
Edited by chadsalt 2005-07-02 4:45 PM
Posted 2005-07-02 4:46 PM (#27529 - in reply to #27526)
I have things I'd rather do... But I believe guidance to newbie’s important enough to sit here and type.  My wife is patiently waiting while I finish this, for us to go to a dinner party.
I'm a sum of my towing experiences like everybody else.  When I first started towing, I didn't know there was a difference in 1/2, 3/4 1 ton pick-ups.  I bought a 3/4 ton pick-up by the grace of God.  The axle ratio was terrible for fuel mileage but right for towing.  I didn't know one could get other axle ratios.  I didn't know the difference between 1/2 & 3/4 ton trucks.
I have since learned, and not been ashamed to learn further.
As for that tenth of second mentioned earlier.
It made a tremendous difference in several lives about seven years ago.  We were driving home from Mose's Cone Park in North Carolina.  The road back was a two lane road.  Out of the mountains, the road is downhill, (Duh!)  On Sunday, the tourist traffic was pretty heavy.  The truck was a C20 (3/4 ton) pulling a 2 horse steel GN straight load trailer with 2 horses.
The opposite lane was full of vehicles bumper to bumper going to the tourist area.  As we came up to the entrance to the Blue Ridge Parkway (on our right) the traffic was stopped waiting to turn left.  I had as usual, left extra distance between us and the car in front.  Safe and defensive driving you know... I had lots of distance if the traffic suddenly stopped.
The waiting cars decided my stopping zone was the perfect spot to make their turn.  Two cars made it through; the third car tried, but didn't anticipate the line of cars would stop, putting him stuck in my path.  I can still vividly remember the details. A white Honda Accord, The traffic on the left had started to move, closing off my escape to the left and his reverse escape.  The right was blocked by the cars in the entrance.  There was nothing to do but lay on the horn and stand on the brakes.  I can still see the wide eyes of the passenger in the right rear seat of the Honda.  His eyes and mine were locked together as the Parkway entrance cleared and the Honda moved out of our path.  Several lives and our horses were separated from harm by a tenth of a second and three feet.
I use a dually rated for 22,000 pounds GCVWR to pull a 3 horse gn trailer rated at 9950 pounds.  I am over trucked.
You make your choices to live with.
Edited by hosspuller 2005-07-02 4:51 PM
chadsalt
Posted 2005-07-02 5:01 PM (#27531 - in reply to #26902)
1000100100100100
im a little unclear as to how being overtrucked had a bearing in that situation.  doesnt sound like you were driving that fast, so it cant be the "little trucks wont stop" theory.  doest look like you performed any death defying slalom manuvers.  please clarify, to me(and it is likely my fault) the moral of the story.
and enjoy your dinner party.
Reg
Posted 2005-07-02 7:30 PM (#27533 - in reply to #26902)
2000500100252525
O-MI-GOSH !
Firefighters cut people out of wrecks ?
I had no idea.
All this time I had assumed they cut the wreck from around the people.
This just after supper, 'scuse me I need to go to the ba......
That was BAD !
Hey Chadsalt, maybe time to just give it up, eh ?
red ashphalt,
red cutting tools,
red sails in the sunset,
red suspenders on firefighters waders,
redi ?
Yeah, I'm outta here.
hav2ride
Posted 2005-07-03 1:21 PM (#27546 - in reply to #27526)
1000500100100
So, Chadsalt, what IS the extent of your horse hauling experiences, i.e. truck/trailer combos and # of years?
"tow "better(definitions will vary)","
Here's my definition of towing better. With the 1T, which is total overkill with a 2H because even a 3/4T could do the job very nicely, you will have more hauling power, more stability, and more braking power than with your Trailer Blazer.  Your engine and trans will not work nearly as hard, therefore lessening your chance of breakdowns.  Of course, you already know all of this but since you seemed a bit confused...
HaulinHorses
Reg. Jul 2004
Posted 2005-07-03 2:53 PM (#27555 - in reply to #27527)
Originally written by hosspuller on 2005-07-02 3:55 PM
I hope the lurkers and newbies pay close attention to what you are saying!  These are my sentiments exactly.  There should be no argument "against" having too much truck.   I'll get blasted for this, but REAL men don't eat quiche, and REAL horse people don't pull trailers with SUV's...no matter what they saw in the movie "The Horse Whisperer".
chadsalt
Posted 2005-07-03 3:37 PM (#27557 - in reply to #27555)
1000100100100100
ok youre right, im only 12 years old and ive never ever ridden a horse.
im going to take your advice reg, im out too. of course ill be there when the next guy asks if he can pull...........
Edited by chadsalt 2005-07-03 3:43 PM
Summit1
Posted 2005-07-04 2:02 PM (#27574 - in reply to #26902)
Just got back from a four day trip to the interior of BC, haven't read all of these posts but this has only been our second trip with our trailer, 4 horse gooseneck with full living quarters and mid tack.  We have a one ton Duramax dually.  My husband is thrilled with it, we had a full load (4 horses, one being a very large Percheron, full load of hay on the hay rack, 80 gallons water plus all the associated tack and kids stuff!!!), this truck pulled like a dream through the mountainous hills, up to 7% grade.  I wouldn't want to have any doubts when hauling as to whether or not the truck can pull satisfactorily or not. You know how you pat your horse and say good girl, good boy, well my husband was patting his truck saying "good boy".  Just my 2 cents worth!
Flooper
Posted 2005-07-05 8:24 AM (#27593 - in reply to #27555)
Originally written by HaulinHorses on 2005-07-03 2:53 PM
Oh puhleeeeezzzz!!! Can't we have an informed, adult discussion without stupid, arrogant and uninformed statements like this. It all comes down to weight, trailer condition, vehicle configuration and driver experience...I'd rather be sharing the road with a safe, well-maintained, within-its-weights SUV pulling a trailer it can handle than with a 1-ton pickup that's pushing it's limits, with underinflated tires, a 4H gooseneck that's dang near pointing to the sky riding mostly on its far back axle, and an idiot behind the wheel...and I've definitely seen both. An SUV that's properly matched to the trailer it's pulling is as safe as any other vehicle.
I guess I'm gonna have to tell my neighbor up the road who is a state champ can chaser and trailers her horse 40 out of 52 weeks a year to events with her Yukon that she's not a "real horse person."
Edited by Flooper 2005-07-05 8:31 AM
HaulinHorses
Reg. Jul 2004
Posted 2005-07-05 4:45 PM (#27633 - in reply to #27593)
Originally written by Flooper on 2005-07-05 8:24 AM
Originally written by HaulinHorses on 2005-07-03 2:53 PM REAL men don't eat quiche, and REAL horse people don't pull trailers with SUV's
Geesh, lighten up!.........Life's too short not to have a little fun with some of this serious stuff.......Laugh a little, it'll make you live longer.
Flooper
Posted 2005-07-05 5:05 PM (#27634 - in reply to #26902)
Hey, I have no problem lightening up...when there is a joke involved, or some sort of humor or satire. But if you are going to make insulting statments like you did, you should expect to be called on it...or back it up with facts. Your post certainly didn't seem like you were trying to be funny...you seemed very serious about your statement that "real horse people don't tow with SUVs". I don't tow with an SUV, but I have a lot of good friends that do, and do so quite safely. Seems like people on forums who get called on insulting statements always reply with the old..."gee, just lighten up."
Erin_CBT
Reg. Jun 2005
Posted 2005-07-06 10:26 AM (#27675 - in reply to #26902)
I think this thread just needs to be laid to rest. I thought the point was to help each other out with opinions and experience, not get in silly arguments over what "real" horse people pull with.
