Bed liner or hitch first?
TXDressageGrl
Posted 2005-06-21 4:05 PM (#26884)
Subject: Bed liner or hitch first?
Just got a new 3/4 dodge truck and I need both a spray in bedliner and the gooseneck hitch in the bed. Which should I have done first?
chadsalt
Posted 2005-06-21 5:01 PM (#26885 - in reply to #26884)
Subject: RE: Bed liner or hitch first?
1000100100100100
ask the guys who will be doing the work for their opinions.
MIfarmbabe
Posted 2005-06-21 5:46 PM (#26891 - in reply to #26884)
5002525
Have the spray-in liner done first then the hitch, otherwise they have to pull out the hitch and depending on what type of GN hitch you get, can be a PITA, plus takes longer.
I have the Rhino-liner in both of my trucks and love it. 5 years in the one truck and as good as new.
You are smart for having it put in your truck.
huntseat
Posted 2005-06-21 6:12 PM (#26893 - in reply to #26884)
1000500100100100100252525
I'm with chadsalt, ask both the hitch and the liner people who goes first.
Reg
Posted 2005-06-21 6:44 PM (#26897 - in reply to #26884)
2000500100252525
Abandon the whole bed-box thing, replace it with an alumin platform that has a trap door to the goose ball, add low sides.
Result: No height mismatch issues and trailer/tailgate or trailer/box-sides interaction. No need to spray anything on or in.
Posted 2005-06-21 7:04 PM (#26899 - in reply to #26884)
By all means ask the people that install them ... But you asked here ...
I say hitch first... and here's why.
The hole for the hitch will leave raw metal edges. Better to have them covered with liner.
The bed might have to be loosened or removed to install the hitch.  Better to have this done before the liner covers the fasteners.
Going at a truck bed with saws and drills and heavy parts? Better to cover the results with a spray in liner than have the liner damaged.
Your mileage may vary...
FTguy
Reg. Dec 2003
Posted 2005-06-21 8:29 PM (#26900 - in reply to #26884)
Hitch first, spray in liner second. They will tape off the hole where the ball goes and the spray helps cover the exposed metal. It worked well on mine, you just have to leave the U-bolts out for the safety chains until it is finished. Doesn't hurt to drill the hole out a bit before the spraying is done so that they will move easier.
FTguy
smoothride
Reg. Mar 2005
Posted 2005-06-21 9:33 PM (#26904 - in reply to #26884)
I AGREE WITH HOSSPULLER, HITCH FIRST, LINER SECOND.  ALL THE RAW EDGES ARE COVERED ON MY INSTALLATION.  TRY TO USE THE B & W TURNOVER HITCH IF YOU CAN
laxpatrick
Posted 2005-06-23 10:11 AM (#26965 - in reply to #26884)
Yep. Hitch then liner. Especially if you're traveling anywhere near the rust belt...
FordLvr
Reg. Jun 2005
Posted 2005-06-23 10:25 AM (#26968 - in reply to #26884)
I agree with hitch first then liner, When they cut opening in the bed of my truck for goosneck, they used a cutting torch. If I had liner sprayed in before hand, who knows what could have happened to liner, (fire, melting, etc, etc.)
MIfarmbabe
Posted 2005-06-23 12:32 PM (#26970 - in reply to #26884)
5002525
Well everyone else on here said hitch first then the liner while I have both of my trucks done with spray-in liner first then the hitch. Nobody told me different and I have had no problems with the hitch or truck bed. So guess it is up to the person(s) installing the liner/hitch.
xyzer
Reg. Apr 2004
Posted 2005-06-23 12:54 PM (#26973 - in reply to #26884)
Same here..I orderered the truck with the liner installed as part of the negotiation..then put in the BW. If they hole saw the hole for the hitch before they spray, and it is a good fit you will have to cut the bedliner from the I.D. of the hole for it to have a clearance fit....But in my opinion either way will work with no problem! Either way do dab a little paint on any raw metal before you install the hitch!
MBRA518
Reg. Sep 2004
Posted 2005-06-23 2:23 PM (#26978 - in reply to #26884)
1001001001002525
My hitch was done first - then the liner.
Here's how it turned out http://community.webshots.com/album/213656445VGKIiq
headhunter
Reg. Oct 2004
Posted 2005-06-23 8:05 PM (#26998 - in reply to #26884)
50010010025
My hitch installer wanted the bed liner in first. But I have rails installed, not an in-bed gooseneck receiver, because I switch between a 5th wheel (RV) and gooseneck hitch receiver.
