| What is the Gas Grenade?
The Gas Grenade is a throwable item that releases a toxic cloud upon impact. This gas lingers in the air and drains the stamina of any Raider who enters its area of effect. This can be incredibly useful in tactical gameplay, particularly when you need to create an advantage over your enemies.
Key Stats:
Duration: The cloud lasts for 20 seconds, giving you a fair window to strategize.
Radius: The gas affects a 7.5-meter radius, enough to cover a decent area of the battlefield.
Stamina Drain: Enemies within the cloud lose 25 stamina per second. This can cripple enemy movement and prevent them from using abilities effectively.
Stackable: You can use up to three Gas Grenades simultaneously in the same area for amplified effect.
How Does the Gas Grenade Work?
When thrown, the Gas Grenade creates a cloud of toxic gas that reduces the stamina of Raiders within its vicinity. It works best in confined spaces where enemies are forced to move through or remain in the gas. However, be mindful of the grenade’s limited radius, as it requires careful placement to ensure maximum effectiveness.
In Practice:
Offensive Use: The Gas Grenade is great for disrupting enemy teams. If you know the location of an enemy group, you can throw a Gas Grenade in their direction, forcing them to either evacuate the area or suffer stamina loss.
Defensive Use: If you are being cornered or trapped, tossing a Gas Grenade can create breathing room. It’s a perfect way to cover your escape or buy time for reinforcements.
Synergy: Combine Gas Grenades with other grenades or traps to maximize your impact. For example, following up with a frag grenade after using the Gas Grenade can eliminate weakened enemies.
When to Use the Gas Grenade?
Timing is everything. The Gas Grenade is most effective when the enemies are grouped together and have limited mobility or when they are pushing into a choke point.
Best Scenarios for Use:
During a Siege: If you're defending a position, use the Gas Grenade to halt enemy advances and force them into a vulnerable position.
In Narrow Corridors: If you are in a confined space or near cover, the gas will be harder to escape from. This is ideal for ambushing enemy squads.
Chasing Down Low-Stamina Enemies: If an enemy is already low on stamina, the Gas Grenade can be the finishing blow to slow them down further and leave them vulnerable to other attacks.
Crafting the Gas Grenade
If you're interested in adding this tool to your inventory, here's what you need to know about crafting it.
Materials Required:
4× Chemicals
2× Rubber Parts
These ingredients can be gathered through scavenging or purchased from other players. Once you have the materials, you can craft the Gas Grenade at the Explosives Station. The crafting process is fairly straightforward and does not require advanced skills, making the grenade accessible to many players early on.
How to Obtain Gas Grenades
There are several ways to acquire Gas Grenades in Arc Raiders:
Scavenging: Gas Grenades can sometimes be found during expeditions or in loot crates. Be on the lookout for them as you explore different areas.
Crafting: If you're in need of more Gas Grenades, you can craft them as outlined above.
Purchasing from Apollo: You can also purchase Gas Grenades directly from Apollo if you have enough in-game currency.
Is It Worth Crafting Gas Grenades?
Gas Grenades are valuable tools for controlling space and managing combat flow. They may not be the most versatile grenade in the game, but they are effective when used in the right situations. If you’re someone who enjoys taking a tactical approach to combat, Gas Grenades are definitely worth crafting and keeping in your arsenal.
Moreover, if you have extra Gas Grenades and need some extra cash, you can sell Arc Raiders blueprints for cash. This can help you fund your operations and craft other essential gear.
Common Mistakes to Avoid
Even experienced players can sometimes misjudge the use of the Gas Grenade. Here are a few common mistakes to avoid:
Throwing Too Early: Gas Grenades need to be used when enemies are in the right position. If you throw it prematurely, you might waste it. Be patient and wait for your moment.
Not Knowing When to Retreat: While the Gas Grenade is effective for controlling space, it doesn’t always guarantee a kill. Make sure you’re prepared to follow up with additional attacks or plan an escape if the grenade doesn’t turn the tide.
Using in Open Areas: The Gas Grenade is less effective in open spaces where enemies can simply move out of its range. Use it where cover and choke points are present to ensure its full impact.
The Gas Grenade is a reliable and strategic tool for Raiders looking to control the battlefield and manipulate the flow of combat. By draining stamina and disorienting enemies, it opens up opportunities for offense and defense alike. If you’re a tactical player, this grenade should definitely be part of your gear.
Remember, timing, placement, and synergy with other tools are key to mastering the use of the Gas Grenade. Whether you’re defending a position, ambushing an enemy, or creating an escape route, this grenade can tilt the balance in your favor. Don’t forget: you can always sell Arc Raiders blueprints for cash to get additional resources for crafting or other valuable items.
[Station Material Bundles] Explosives Station 1 to 2 | Global | |
