     Location: Tenn/Ala. | Kiefer used 2 different latches then. 1 that used a padlock to lock, the other a black (or silver or white assembly from Bauer) with a key. If that one, there are spring loaded balls that get rusty and stick. Especially if they sit, or worse see road salt. If that's what you have, spray in the seems liberally with penetrating oil and let sit. Pull top as you push bottom. It is cast aluminum and can break, but replacements easy to get (but will be black). |
