| I have a 2002 Sooner, 2 Horse, Straight Load, Gooseneck trailer.
It’s time to replace the window and door weather seals. I am having trouble finding replacement or at least something that will leak less… My windows are all slide since the trailer is a straight load.
It’s also time to replace my ramp springs so I don’t feel like I’m training for an Olympic weight lifting event. From what I’m told ramp springs are not made the same for all ramps, they are unique, …great. That I need to replace mine with the same unless I want my ramp reworked.
Sooner Trailers still exists but has been through several new owners since the time my trailer was built, and I’m told the build records for that time period no longer exist.
Has anyone with an early 2000s Sooner Horse Trailer changed out their window or door weather seals? What did you use? Where did you find them?
Has anyone with an early 2000s Sooner Horse Trailer changed out their ramp springs? What type of springs did you use? (Brand Name/Type) Where did you find them?
If you have an owners manual for your trailer at that time, I would love a copy. (Around 2002)
Thank you for any help you may have. | |
| Many owners of early 2000s Sooner trailers have had luck with generic automotive or RV weather seals from sites like Steele Rubber or Vintage Trailer Gasket. For ramp springs, try calling trailer supply shops with your ramp’s measurements—they often match by size and tension, not just brand. You might also check with trailer repair shops for spring retrofits. Manuals are rare, but trailer forums or Facebook groups may have scans.
I work at UNAM | I'm a marine biologist | I install acrylic roof panels | I enjoy exercising and traveling | |
