Load light replacement and fans
TNpeanut
Reg. Oct 2019
Posted 2024-05-08 8:45 AM (#185721)
Subject: Load light replacement and fans
I'm wanting to upgrade my 2001 Sooner Revolution to all LED lights. I have taken care of the LQ and exterior lights, but what is a good replacement for the interior load lights that have a switch on outside corner? I also want to add 2 fans but didn't know if I need to run an additional wire to the fuse box. If so what size wire?
Thanks for any advice.
tobruk
Posted 2024-05-08 6:23 PM (#185722 - in reply to #185721)
Subject: RE: Load light replacement and fans
They make an oblong white light that should just swap out for your interior lights.  You'll probably want to run a separate 'hot' wire for the fans and a separate switch at the back so you can run the fans without having to turn the lights on.  Easy to do since the hot source is already at the back of the trailer for you to tap into.
Faassfarm
Reg. May 2025
Posted 2025-05-02 9:58 PM (#185897 - in reply to #185721)
Hi, I have a 2002 Sooner. I am also upgrading all my lights to LED lighting. Take a look at “Buyers Products” 5626324 Backup Light Kit w/ 24 LEDs 6 In. Oval Clear available on Amazon. They match the interior white lights. You should be able to find all the other lights in LED too. I plan to add lighting there are many options.
The lights are all “DOT” 12v lights. If you look for replacements in that category it will make your search easier.
Hope this helps.
FernandoVilla
Reg. Jun 2025
Posted 2025-06-05 5:58 PM (#185925 - in reply to #185721)
For the interior load lights, look for 12V LED dome lights with built-in switches or compatible with your trailer’s setup. For the fans, yes—run a dedicated wire to the fuse box. Use 12 AWG wire for most 12V fans to handle the load safely. Always add an inline fuse close to the power source.
I work at UNAM | I'm a marine biologist | I install acrylic roof panels | I enjoy exercising and traveling
