 Location: Picayune,MS | I am getting ready to start the LQ in my trailer. I have a 03 Exiss with a 4 ft short wall and I am going to use a room A/C unit instead of a roof mount (Cheaper). I was wondering if anybody has a similar size LQ that has pictures. I am at a loss for what I want to do with it. I am not going to have shower or tiolet but may put a sink in? I need ideas BAD....... |
 Location: Lone Oak, Tx | I have a 4 ft SW. You can check out my pics if you like. Just click on my sig at the bottom of this post.
Safe Riding,
Todd |
http://community.webshots.com/album/249894336QCbeHT
I was wondering, right below my message here do you see where it says "2004 Hart Medallion ..." If you click on that you'll get the same link as above. If you don't see that let me know.
Safe Riding,
Todd |
 Location: Picayune,MS | No I don't but I think it is this wonderful computer I am on at work...... |
      Location: south of Cowtown, TEXAS | I also have a 4' short wall. Link is in my sig as well. Sorry, have a roof mount AC tho. |
  Location: Spanaway,Wa | The trailer I just bought has the a/c unit mounted right through the front wall under the gooseneck. Looks like its been there quite a while and still works like a champ. Sorry I don't have any pics. CS |
.jpg) Expert
      Location: Southern New Mexico | I didn't see an ac in there. Did I miss it? |
Location: Palm City, FL | Dawnya your trailer gives me GREAT hope for mine!! I too am yet another person about to change my DR into a sm. LQ area. THanks for posting your pictures!!! |
 Location: Brazil, IN | I used to have a 4 ft SW before we traded up, I don't have any pics, but we stuck with a bench below the gooseneck which made a small bed. You can also use the underneath for storage. Personally, we had a fridge instead of a sink. Made less use of coolers which got in the way. I'd be glad to answer any othe ? that you have! |
   Location: Henderson, TN 38340 | Somebody on the site has a rig with the window air mounted under the neck. I looked at the pictures before I started my job. So keep checking. I have yet to install an air conditioner, but I plan on it being a roof mounted unit. If you would like to see my efforts check out my web site http://home.earthlink.net/~dheismann/ |
    Location: michigan | I don't have pictures but I do have a trailer that someone converted intoa LQ. it is a 4' sw- door is on the drivers side- when you walk in to your right is a floor mounted cabinet which hold the sink, above it is a medicine chest. Following the wall, there is a walk thru door. In the corner of the long wall is the fridge which is set about 2 feet off the floor ( there is a cupboard under the fridge). The dinette is against the long wall ( there is a small cabinet under one seat, under the other is the eletrcial box). Above that are some cupboards, one which holds the microwave. In the boot box is the water tank and small pump. You can actually put alot of stuff into a small space if you just use your imagination.
Edited by farmbabe 2005-06-19 7:14 AM
