LOADING LIGHTS NOT WORKING
bzinkc
Reg. Oct 2021
Posted 2021-10-24 3:54 PM (#184957)
Subject: LOADING LIGHTS NOT WORKING
We have an Exsis 2001 horse trailer. Every light inside and out is working except for the loading/stall lights. I have made sure it was plugged into the truck tightly, running lights work, brake lights work, turn signals work, loading lights DO NOT work. I have check/changed fuses and cleaned posts. Any advice out there?
DLR
Reg. Jul 2004
Posted 2021-10-25 4:14 AM (#184958 - in reply to #184957)
Subject: RE: LOADING LIGHTS NOT WORKING
Maybe the light is "blown".  They do stop working.
RTSmith
Posted 2021-10-25 6:02 AM (#184959 - in reply to #184957)
Are the lights in the dressing room working? All of the "white" lights (loading, horse area, dress) are one one circuit that powers from the Batt or Acc in the truck plug. If the dressing room lights work, but not horse area you have a trailer problem. If the dressing room lights don't, then you likely have a truck problem.
bzinkc
Reg. Oct 2021
Posted 2021-10-25 5:26 PM (#184961 - in reply to #184957)
All of the lights are out. Thanks for the info!
RTSmith
Posted 2021-10-26 9:27 AM (#184962 - in reply to #184957)
Saw this yesterday. Interesting. A YouTube video showing Ford truck charging and not charging based on a number of variables. All could cause frustration using load lights.
 https://l.facebook.com/l.php?u=https%3A%2F%2Fyoutu.be%2FDHZRp94Bwds%3Ffbclid%3DIwAR0gvwJiYEWIuR97YV7aeiOW_acYua0kD6arpz8Azn9v5RLINWuNOY5mhxo&h=AT2OG3ziVu0iwJ60dffroGYIKgQI-k9RYbBGbc3uZdMIAY5XE-MLOkPlMzhwC3oz8DRx-WiIURL3VbT9Iu8vS6SEIlWGJO2UWWC-eWjDYVxqtRTdQ8YBb-oEFtEd67vfe6_2g-q9xkNUfQ&__tn__=R]-R&c[0]=AT1w7w_lwbqPshJB_q2Te-hctcb11CxiWGbTYlwrUeoTe474-q9mTKIZyl4CU6UC51tKabYtOtq_bs8LuIPwrXn1tMl89Rbi6t1gEDH9-RmVeyyO5F67RKrEY2xX19pmQbegg8cmtBs_31mwOWKmYX4E689TSQJa29owlRw2tzB2d4UM31gKd747zEMaPtxGj2KJzLaMZS0CmP3yTQ
