Logan trailer
tjwilsall
Reg. Oct 2021
Posted 2021-10-14 6:55 PM (#184935)
Subject: Logan trailer
Anybody successfully put 10,000lb axles under a newer living quarters Logan trailer without changing the fender wells? Presently has 8,000lb axles. Logan Trailers says it can’t be done without changing the fender wells?
RTSmith
Posted 2021-10-15 7:12 AM (#184936 - in reply to #184935)
Subject: RE: Logan trailer
I can't speak for the Logan, but a 10K axle has a much larger swing arm than the 8K. Any trailer I've ever seen had much larger inner fenders and a different axle box underneath if it had 10Ks. So unless Logan used those components anyway, there will likely be a fair amount of fabrication to make a change from 8s to 10s.
akinstrailers
Reg. Apr 2009
Posted 2021-10-25 2:15 PM (#184960 - in reply to #184935)
Logan is correct.  We thought we could make it work but ended up having to rebuild the fender wells.
TwistedK
Reg. Jul 2014
Posted 2021-10-27 11:44 AM (#184969 - in reply to #184935)
 Mounting brackets are completely different. The inner fenders will most definitely have to be rebuilt.
