Merhow Trailer outer skin needed.
yardape1
Reg. Sep 2021
Posted 2021-09-07 1:40 PM (#183721)
Subject: Merhow Trailer outer skin needed.
Hi,
I have an old Merhow trailer which was made with walls of wood encased in fiberglass skin. The door needed to be repaired and I need to replace the skin. I am having a lot of trouble finding a replacement skin as this trailer is over 30 years old and the Merhow folks no longer have detailed records.
Any thoughts would be appreciated.
Thanks
Rich
HappyTrailsTrailers
Reg. Apr 2016
Posted 2021-09-08 7:52 AM (#183726 - in reply to #183721)
Subject: RE: Merhow Trailer outer skin needed.
Hello -
I do not think you will find the exact product - fiberglass reinforced plywood - it was not a good choice as it does rot inside out
FRP RV wall panels - you can probably find a suitable replacement - typically the doors are just camper type doors without a screen, if so you can probably get a replacement for the entire door and screw it on,,, Risa
FRP Panels | Fiber-Tech Industries
tobruk
Posted 2021-09-08 4:29 PM (#183727 - in reply to #183721)
Contact a local big trailer repair place.  This industry still uses a lot of FRP and it works pretty well because there are no cuts or intrusions into the FRP.  You'll have to replace the entire section.  The doors are semi door cores and readily available.
